General Options
Enable Detailed Logging
SceneComposer Customization can be done via "File"menu bar [ File > "Preferences"Preferences... menu.].
"Enable
detailed
Hide logging"warnings optionand messages from theimports Environmentin sectionProblems ofpanel
Preferences
If dialogenabled, willwarnings causeand moremessages detailsfrom info to be writtenimports in the logProblem filespanel ofwill SceneComposer.be This is useful for debugging on possible errors.hidden.
Make All Suppressed Dialogs Visible Again
"Make all suppressed dialogs visible again" option enables the display of the dialog boxes asking confirmations for generate asset and import FBX files option. One can disable the option of displaying these dialog boxes by unchecking the "Always show this dialog" option.
Automatically Tick Camera
If the preference option "Automatically tick camera in the Rendered Cameras panel when the camera is linked to a render target" is enabled it means that whenever a camera is linked to a render target, this camera will be automatically enabled in the Rendered Cameras panel. Already existing settings(done by the user) in the rendered cameras panel mustn't be affected by switching the preference option. It only affects new camera rendertarget links.
Disable Previews
It is possible to enable/disable previews by checking/unchecking the "Disable Previews" checkbox from Preferences. If this option is used, none of the images previews will be available. In this way the performances of the application can be improved - especially when there are many imported images.
Enable
SearchDetailed ToleranceLogging
The"Enable percentdetailed valuelogging" givenoption from the Environment section of Preferences dialog will cause more details info to be written in the log files of SceneComposer. This is useful for debugging on possible errors.
File
This is the path to the optiondetailed "Searchlog Tolerance"file.
Configuration folder
This is takenthe inpath to account during the searchfolder operationwhere forall propertiesScene ofComposer typeconfiguration Float,files Colorare when the operator "about equal" is used.saved.
Screenshot Output Folder
In some conditions the user might need to see exactly the content visible in an opened display. To fulfill such a need, SceneComposer provides the possibility to take screenshots of every display. For this, the desired display has to be opened by double-clicking on the display in the render target tab. The screenshot can be taken by right-clicking on the display in the render target tab and selecting "Save Screenshot" in the context menu or by pressing F12.
After taking a screenshot (e.g. via the context menu in the display window, which can be opened through the menu "View > Display > Display-0") the destination folder will be opened instantly.
The default screenshot output folder is C:\Users\...\AppData\Roaming\SceneComposer\Screenshots. This default setting can be changed in one of the following ways:
  • In the menu select "File - Preferences". In the Environment preferences change the "Screenshot output folder" to your desired location.
  • Take a screenshot and browse to your preferred location when the destination folder is displayed.
Help file
This is the path to this document (CGI Studio Documentation).
Search Tolerance
The percent value given to the option "Search Tolerance" is taken in to account during the search operation for properties of type Float, Color when the operator "about equal" is used.
Tab Optionssize / Replace tabs with spaces
The user can change the tab size and decide if tabs should be changed to spaces. This option is available for editing shaders in the Shader Editor panel ("View" > "Editors" > "Shader Editor").
There are platforms which do not allow shaders editing operation.
Number of visible recently opened solutions
Sets the maximum number of recently opened solutions to be displayed in the Startup panel (maximum: 20).
