General Options
Enable Detailed Logging
SceneComposer Customization can be done via "File" > "Preferences" menu.
"Enable detailed logging" option from the Environment section of Preferences dialog will cause more details info to be written in the log files of SceneComposer. This is useful for debugging on possible errors.
Make All Suppressed Dialogs
"Make all suppressed dialogs" option enables the display of the dialog boxes asking confirmations for generate asset and import FBX files option. One can disable the option of displaying these dialog boxes by un-checking the "Always show this dialog" option.
Automatically Tick Camera
If the preference option "Automatically tick camera in the Rendered Cameras panel when the camera is linked to a render target" is enabled it means that whenever a camera is linked to a render target, this camera will be automatically enabled in the Rendered Cameras panel. Already existing settings(done by the user) in the rendered cameras panel mustn't be affected by switching the preference option. It only affects new camera-rendertarget links.
Disable Previews
It is possible to enable/disable previews by checking/unchecking the "Disable Previews" checkbox from Preferences. If this option is used, none of the images previews will be available. In this way the performances of the application can be improved - especially when there are many imported images.
Search Tolerance
The percent value given to the option "Search Tolerance" is taken in to account during the search operation for properties of type Float, Color when the operator "about equal" is used.
Screenshot Output Folder
In some conditions the user might need to see exactly the content visible in an opened display. To fulfill such a need, SceneComposer provides the possibility to take screenshots of every display. For this, the desired display has to be opened by double-clicking on the display in the render target tab. The screenshot can be taken by right-clicking on the display in the render target tab and selecting "Save Screenshot" in the context menu or by pressing F12.
After taking a screenshot the destination folder will be opened instantly.
The default screeshot output folder is C:\Users\...\AppData\Roaming\SceneComposer\Screenshots This default setting can be changed in one of the following ways:
Help File
To use the Help file the user can use the F1 shortcut. But, if the path to the .chm Help file is not properly set, the user has to set the right path. This is possible in two different ways:
- By writing inside the field the path and the name of the .chm Help file;
- By browsing the Help file.
Tab Options
The user can change the tab size and decide if tabs should be changed to spaces. This option is available for editing shaders in the Shader Editor panel ("View" > "Editors" > "Shader Editor").
There are platforms which do not allow shaders editing operation.
Easy Mode Configuration File
The user can set the right path to the easy mode configuration files. This is possible in two different ways:
- By writing inside the field the path and the name of the config file;
- By browsing the configuration file.
