False Color Mipmap
False Color Mipmap
"False Color MipMap" can also be enabled from the Configuration menu.
Mipmapping is a texturing technique for reducing artifacts caused by mapping a large texture onto a small area in screen space. It is accomplished by creating pre-downsized versions of the texture. A mipmap level is a single downsized version of the original texture, at some resolution.
In the false-color mipmap technique each mip level has a different contrasting color. This can be seen in the image bellowbellow:
The displaystextures of the Tunnelground objectsurface thatand the car's exterior are configured with Mipmap Filter "MipMapNearest". "False color mipmap" is referencedenabled in the Preferences window. False color mapmap visualizes different sectionsmipmap oflevels currentby document,different aftercolors in Scene Editor panel as well as in the false-colordisplay mipmap had been applied.view.
