Anti-Aliasing
Enable anti-aliasing
Enables anti-aliasing effect.
Anti Aliasing is a technique of adjusting pixel positions or setting pixel intensities so that there is a more gradual transition between the color of a line and the background color in order to give a smoother appearance of the object. The image bellow illustrates the Antialiasing effect on an object.
The changing of the anti aliasing will only take effect after the application is restarted.
Dithering
Dithering option when enabled activates the dithering in the render device.
