Optimize Shader Program Coding
Avoid if-else Constructs in the Shader
The use of if-else statements for non-constant variables (attributes, varyings and local variables) should generally be minimized or avoided in shaders, as they might lead to synchronization penalties due to different processing times while parallel processing.
Reduce Calculations in the Shader Program
Reduce complex calculations in shader. Uniform calculations can be done outside of the shader. Attribute calculation must be done in the shader anyway.
For example rather give a pre-calculated model-view-projection matrix to the shader than combining the model view projection matrices within a shader, as each calculation is done for each vertex in the vertex shader. Candera pre-calculates uniforms set by Candera ShaderParamSetters automatically before given to the shader (like model-view-projection transformation, light vectors, reflection matrix, etc...).
Minimize the Number of (temporary) Variables
Remove Superfous Assignments
Consider that each assignment to a variable in a shader is executed for each vertex (in vertex shader) or fragment (in fragment shader). Thus, reduce the number of assignments to a right-minded minimum.
Minimize Variable Lifetime
Don't allocate variables across a large code range. Instead minimize their lifetime by scopes or by instantiation directly before usage.
use Lowest Precision Possible
Choose the lowest precision possible (without rendering artifacts) on vertices, normal, color and texture coordinates. Lower precision data requires less bandwidth to be transferred from VRAM to the graphics chip.
The shader performs most of the arithmetic calculations much faster in mediump than in highp precision. When using mediump precision for vertex attributes, make sure the data in memory is stored in half-float format as well. Otherwise the driver has to convert the precision every time the object is drawn. Mediump precision should be the default precision in the fragment shader and for varyings.
Perform Vector Based Operations
If possible, make use of vector based operations like in the following example.
    vec2 x1 = (in1 + in1) / 2;
    vec2 x2 = (in2 + in2) / 2;
Better:
    vec4 x.xy = in1;
    x.zw = in2;
    x = (x+x) * 0.5;
Use Multiplication instead of Division
Better rephrase division by x as multiplication by 1.0/x, as this can be computed faster, generally.
