The example file of Figma
This section describes how to use the instrument cluster as a Figma design file exsample. The exsample file is stored in the following location.
<root>/cgi_studio_content/Figma/AI_Cluster_Sample.fig
Due to technical limitations, Figma design files cannot be opened directly in CGI Studio. For this reason, the first step is to import them into your personal Figma account.
  1. Log-in your Figma account.
  2. In your Figma account, click on "Import Files" and load the AI_Cluster_Sample.fig file.
  3. The AI_Cluster_Sample.fig will be uploaded to your account.
  4. After uploading, you will see AI_Cluster_Sample in the file.You can open and edit this exsample file directly in Figma if necessary.
To import this sample file using the Smart Importer, select the Import from Cloud option from the menu and follow the settings. See Figma for import instructions.
