Recommended Layers Structure for Smart Importer
This page will explain how best to set up items so that they and their internal group items are automatically detected as controls when importing Adobe Photoshop (.psd)/Adobe XD (.xd)/Figma (.fig) files with the Smart Importer.
Controls that can be automatically assigned are limited to those found in the the Touchable and Common categories.
For Adobe Photoshop(.psd)Files
Making controls from photoshop layer data can be in the following way way
  1. Create a group item for the control to be assigned and name it "SC_<name of control>". In the example below, in order to make a TextButton control, the top layer has been named "SC_TextButton" (see blue box).
  2. Make property layers that the desired control contains underneath the group item made in step 1 (see red and green boxes).
  3. Use the names of the control properties for the names of these photoshop layers. Note that any spaces in photoshop layer names should be deleted (see green boxes for comparison)
After observing the above method, select the finished photoshop file from the Scene Composer toolbar [Import] > [Smart Importer] > [From Local File...]. The Smart Importer panel will open, and the file will be loaded in line with the .psd file layers that were set. As seen in the image below, the TextButton control has already been confirmed and subsequently applied.
Each property on the Appearance and Basic Property tabs will also reflect the layers that were set in the .psd file.
This will also be reflected on the property panel after importing is complete.
The size of the imported control will conform to the width and height of the largest image layer applied.
When importing nodes with mismatching layers and properties, new group nodes are created, and additional properties are added as child elements.
For Adobe XD(.xd)Files
The preparation needed for .xd files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Adobe XD items to match the structure and property names of controls to be automatically applied.
For Figma(.fig)Files Files
The preparation needed for .fig files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Figma items to match the structure and property names of controls to be automatically applied.
Layer Structure and Naming Guideline for Controls
  • AnalogClock
    • SecondsNeedleImage
    • MinutesNeedleImage
    • HoursNeedleImage
    • FaceImage
  • Breadcrumb
    • Name
    • EllipsisText
  • Button
    • NormalImage
    • PressedImage
    • FocusImage
  • CheckBox
    • NormalImage
    • PressedImage
    • SelectedImage
    • SelectedPressedImage
    • FocusedImage
  • CircularSlider
    • BackgroundImage
    • ActiveImage
    • ThumbImage
    • ThumbImagePressed
    • FocusImage
  • Gauge
    • NeedleImage
    • BackgroundImage
  • GroupBox
    • BackgroundImage
  • IconButton
    • NormalImage
    • PressedImage
    • FocusedImage
    • IconNormalImage
    • IconPressedImage
    • IconFocusedImage
  • InputField
    • CaretImage
    • BackgroundImage
    • FocusedImage
  • Menu Icon
    • Image
    • BackgroundImage
  • Menu Item
    • FocusImageOnSelection
    • FocusImageOnDragging
    • DeleteButtonNormalImage
    • DeleteButtonPressedImage
    • Image
  • Menu Screen
    • BackgroundImage
    • FocusBorderImage
  • Mesh2D
    • Image
  • MultiStateButton
    • ButtonState1Bmp
    • ButtonState2Bmp
    • ButtonState3Bmp
    • ButtonState4Bmp
    • FocusedImage
  • PageIndicator
    • PressedImage
    • SelectedIndicatorImage
    • IndicatorImage
    • SelectedIndicatorPressedImage
    • IndicatorPressedImage
  • RadioButton
    • NormalImage
    • PressedImage
    • SelectedImage
    • FocusedImage
  • Roll
    • DecorationImage
    • TextEditBackground
  • SpinBox
    • BackgroundImage
    • ArrowUpNormalImage
    • ArrowUpPressedImage
    • ArrowDownNormalImage
    • ArrowDownPressedImage
  • TextButton
    • Text
    • NormalImage
    • PressedImage
    • FocusedImage
  • ToggleButton
    • FirstImage
    • FirstPressedImage
    • SecondImage
    • SecondPressedImage
    • FocusedImage
  • TouchIndication
    • Image
