Recommended Photoshop (.PSD) Layers Structure for Smart Importer
This page will explain how best to set up items so that they and their internal group items are automatically detected as controls when importing Adobe Photoshop (.psd)/Adobe XD (.xd)/Figma (.fig) files with the Smart Importer.
Controls that can be automatically assigned are limited to those found in the Touchable and Common categories.
For Adobe Photoshop(.psd)Files
Making controls from photoshop layer data can be in the following way
  1. Create a group item for the control to be assigned and name it "SC_<name of control>". In the example below, in order to make a TextButton control, the top layer has been named "SC_TextButton" (see blue box).
  2. Make property layers that the desired control contains underneath the group item made in step 1 (see red and green boxes).
  3. Use the names of the control properties for the names of these photoshop layers. Note that any spaces in photoshop layer names should be deleted (see green boxes for comparison)
After observing the above method, select the finished photoshop file from the Scene Composer toolbar [Import] > [Smart Importer] > [From local file...]. The Smart Importer panel will open, and the file will be loaded in line with the .psd file layers that were set. As seen in the image below, the TextButton control has already been confirmed and subsequently applied.
Each property on the Appearance and Basic Property tabs will also reflect the layers that were set in the .psd file.
This will also be reflected on the property panel after importing is complete.
The size of the imported control will conform to the width and height of the largest image layer applied.
When importing nodes with mismatching layers and properties, new group nodes are created, and additional properties are added as child elements.
For Adobe XD(.xd)Files
The preparation needed for .xd files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Adobe XD items to match the structure and property names of controls to be automatically applied.
For Figma(.fig)Files
The preparation needed for .fig files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Figma items to match the structure and property names of controls to be automatically applied.
以降は、英訳の必要はありません。無視してください。
These are the recommended steps for Photoshop layers' naming and structure of a Control when creating a PSD file with Adobe Photoshop. This procedure makes it easier to apply properties to a Control via the Smart Importer.
    Create a group for the target Control - in this case, a TextButton (blue highlight in Figure 1 below) Create layers for the properties of the Control under the group created in step 1. (red and green highlight in Figure 1) Set the names of the layers to be the same as the property names of the target Control. (layers names in Figure 1 correspond to property names in Figure 2)
      The group name is arbitrary. For the layer name, use the property name but remove the spaces. For example, "Normal Image" becomes "NormalImage".
      The below image shows the Smart Importer dialog when a PSD file following the correct format is opened.
      In the Smart Importer dialog, if you apply the TextButton control to the TextButton node, the layers of the PSD file will be reflected in each property as shown in the below image.
      The below image shows the Properties panel after import settings shown in the above image. The contents/layers of the PSD file are reflected in the Properties panel.
      In the below image, when Button is applied instead of TextButton, Text property is not applied correctly since a Button control does not have this property.
      Layer Structure and Naming Guideline for Controls
      • AnalogClock
        • SecondsNeedleImage
        • MinutesNeedleImage
        • HoursNeedleImage
        • FaceImage
      • Breadcrumb
        • Name
        • EllipsisText
      • Button
        • NormalImage
        • PressedImage
        • FocusImage
      • CheckBox
        • NormalImage
        • PressedImage
        • SelectedImage
        • SelectedPressedImage
        • FocusedImage
      • CircularSlider
        • BackgroundImage
        • ActiveImage
        • ThumbImage
        • ThumbImagePressed
        • FocusImage
      • Gauge
        • NeedleImage
        • BackgroundImage
      • GroupBox
        • BackgroundImage
      • IconButton
        • NormalImage
        • PressedImage
        • FocusedImage
        • IconNormalImage
        • IconPressedImage
        • IconFocusedImage
      • InputField
        • CaretImage
        • BackgroundImage
        • FocusedImage
      • Menu Icon
        • Image
        • BackgroundImage
      • Menu Item
        • FocusImageOnSelection
        • FocusImageOnDragging
        • DeleteButtonNormalImage
        • DeleteButtonPressedImage
        • Image
      • Menu Screen
        • BackgroundImage
        • FocusBorderImage
      • Mesh2D
        • Image
      • MultiStateButton
        • ButtonState1Bmp
        • ButtonState2Bmp
        • ButtonState3Bmp
        • ButtonState4Bmp
        • FocusedImage
      • PageIndicator
        • PressedImage
        • SelectedIndicatorImage
        • IndicatorImage
        • SelectedIndicatorPressedImage
        • IndicatorPressedImage
      • RadioButton
        • NormalImage
        • PressedImage
        • SelectedImage
        • FocusedImage
      • Roll
        • DecorationImage
        • TextEditBackground
      • SpinBox
        • BackgroundImage
        • ArrowUpNormalImage
        • ArrowUpPressedImage
        • ArrowDownNormalImage
        • ArrowDownPressedImage
      • TextButton
        • Text
        • NormalImage
        • PressedImage
        • FocusedImage
      • ToggleButton
        • FirstImage
        • FirstPressedImage
        • SecondImage
        • SecondPressedImage
        • FocusedImage
      • TouchIndication
        • Image
