Recommended Photoshop (.PSD) Layers Structure for Smart Importer
These are the recommended steps for Photoshop layers' naming and structure of a Control when creating a PSD file with Adobe Photoshop. This procedure makes it easier to apply properties to a Control via the Smart Importer.
  1. Create a group for the target Control - in this case, a TextButton (blue highlight in Figure 1 below)
  2. Create layers for the properties of the Control under the group created in step 1. (red and green highlight in Figure 1)
  3. Set the names of the layers to be the same as the property names of the target Control. (layers names in Figure 1 correspond to property names in Figure 2)
  • The group name is arbitrary.
  • For the layer name, use the property name but remove the spaces. For example, "Normal Image" becomes "NormalImage".
The below image shows the Smart Importer dialog when a PSD file following the correct format is opened.
In the Smart Importer dialog, if you apply the TextButton control to the TextButton node, the layers of the PSD file will be reflected in each property as shown in the below image.
The below image shows the Properties panel after import settings shown in the above image. The contents/layers of the PSD file are reflected in the Properties panel.
In the below image, when Button is applied instead of TextButton, Text property is not applied correctly since a Button control does not have this property.
Layer Structure and Naming Guideline for Controls
  • AnalogClock
    • SecondsNeedleImage
    • MinutesNeedleImage
    • HoursNeedleImage
    • FaceImage
  • Breadcrumb
    • Name
    • EllipsisText
  • Button
    • NormalImage
    • PressedImage
    • FocusImage
  • CheckBox
    • NormalImage
    • PressedImage
    • SelectedImage
    • SelectedPressedImage
    • FocusedImage
  • CircularSlider
    • BackgroundImage
    • ActiveImage
    • ThumbImage
    • ThumbImagePressed
    • FocusImage
  • Gauge
    • NeedleImage
    • BackgroundImage
  • GroupBox
    • BackgroundImage
  • IconButton
    • NormalImage
    • PressedImage
    • FocusedImage
    • IconNormalImage
    • IconPressedImage
    • IconFocusedImage
  • InputField
    • CaretImage
    • BackgroundImage
    • FocusedImage
  • Menu Icon
    • Image
    • BackgroundImage
  • Menu Item
    • FocusImageOnSelection
    • FocusImageOnDragging
    • DeleteButtonNormalImage
    • DeleteButtonPressedImage
    • Image
  • Menu Screen
    • BackgroundImage
    • FocusBorderImage
  • Mesh2D
    • Image
  • MultiStateButton
    • ButtonState1Bmp
    • ButtonState2Bmp
    • ButtonState3Bmp
    • ButtonState4Bmp
    • FocusedImage
  • PageIndicator
    • PressedImage
    • SelectedIndicatorImage
    • IndicatorImage
    • SelectedIndicatorPressedImage
    • IndicatorPressedImage
  • RadioButton
    • NormalImage
    • PressedImage
    • SelectedImage
    • FocusedImage
  • Roll
    • DecorationImage
    • TextEditBackground
  • SpinBox
    • BackgroundImage
    • ArrowUpNormalImage
    • ArrowUpPressedImage
    • ArrowDownNormalImage
    • ArrowDownPressedImage
  • TextButton
    • Text
    • NormalImage
    • PressedImage
    • FocusedImage
  • ToggleButton
    • FirstImage
    • FirstPressedImage
    • SecondImage
    • SecondPressedImage
    • FocusedImage
  • TouchIndication
    • Image
