How to Import Resources
Import File Formats
  • Image files (*.bmp, *.jpg, *.jpeg, *.gif, *.tga, *.png, *.dds, *.ktx, *.hdr, *.exr)
  • Font files (*.ttf, *.ttc,*.otf, *.fnt, *.fbm)
  • Shader files (*.vert, *.frag)
  • SVG files (*.svg)
  • FBX files (*.fbx)
  • glTF files (*.gltf, *.glb)
  • Icon files (*.bmp, *.ico, *.jpg, *.png)
  • Script files (*.lua)
glTF file format
  • glTF: This points to external binary data (geometry, key frames, skins), and images.
  • glTF-Embedded: This embeds base64-encoded binary data, and images inline using data URIs.
  • glTF-Binary: In Binary glTF, a glTF asset (JSON, .bin, and images) can be stored in a binary blob.
For more detailed information on the file formats, please see the Khronos website: GLB File Format Specification.
About .ktx File Format
  • Etc2CompressedRgbFormat
  • Etc2CompressedSrgbFormat
  • Etc2Alpha1CompressedRgbaFormat
  • Etc2Alpha1CompressedSrgbaFormat
  • Etc2EacCompressedRgbaFormat
  • Etc2EacCompressedSrgbaFormat
  • Texgenpack
  • Mali Texture Compression tool
  • Ericcson Texture Compression Tool
About Bitmap Font
  • .fnt (windows font files) - are converted to bitmap fonts
  • .fbm - already converted bitmap font files
  • Source file names: specifies the name of the file which was imported - helps the user identify a font
Import Operation
Menu Bar
Context menu
Drag and Drop
    • glTF file can also be imported by drag-and-drop to any folder under Solution in Solution Explorer.
    • Note that under OpenGLES1.1 environment, shader files (*.vert, *.frag), SVG files (*.svg), FBX files, and glTF files cannot be imported by drag-and-drop operation.
    • When an image file format (*.bmp, *.jpg, *.png) that can be imported as an icon is dragged and dropped into any folder under Solution in Solution Explorer, the dialog box will appear as shown below, allowing you to select whether to import it as an image or icon resource. You can choose whether to import it as an image or an icon.
  1. When the import process is executed, Scene Composer will display a message to save any unsaved changes in the solution. Press OK to proceed. If you do not want this dialog to appear during the import process, uncheck the "Always show this dialog" checkbox.
  2. After saving the solution, the Import Resources dialog is opened, where you can select one or more resource files to be imported. Select your files to import and press OK.
    • You can search for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog.
    • You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.
  3. After choosing your files to import, an Import dialog will be displayed depending on the file types you are importing (Image, Font, FBX, Shader…).
  4. Configure import settings to your needs and click "OK" button.
    • The file will be imported as a resource in the Solution Explorer in the location corresponding to the settings on the dialog screen.
Icon files
  2. After saving the solution, the Import Resources dialog will open. Select the target file and press OK. If the selected file format is "*.ico", the [ Import Icons ] dialog will appear as shown below.
    • The path of the selected file is displayed in the [ Selected files ] field. To re-select a file, press the [ Select File... ] button.
    • In [ Destination folder ], specify the location where the file will be imported as a resource.
    • As explained in the Drag and Drop section, if you drag and drop an image file format that can be imported as an icon (*.bmp, *jpg, *.png), the above dialog will appear and you can import it as an icon.
  3. Click "OK" button to complete the import operation.
SVG files
  2. After saving the solution, the Import Resources dialog is opened, where you can select one or more SVG files to be imported. Select your files to import and press OK.
    • You can import multiple files at once.
  3. After choosing your files to import, an SVG Importer dialog will be displayed.
  4. Configure import settings to your needs and click "Import" button.
    • "ImportedScenes" and "Scenes" folders have been created at the destination folder chosen in "Solution Explorer". The former holds data imported as template scenes, while the latter holds data imported as actual scenes.
    • If multiple SVG files have been imported, the Scene Editor will display the actual scene for what was the topmost SVG file in the SVG Importer.
      • Transform > Position > X = 0, Y = 0 will be the item's initial position.
    • Copy group nodes within imported scenes into the desired scene and use them.
glTF files
  - Skinning
  - Morping
  - Vertex Buffer Streams
  - Sparse Accessors
  - Multiple UV Maps
    • IBL settings are also available in Solution Options. See IBL Texture for more information on the settings.
    • These three values must be defined when using IBL. They cannot be reconfigured after import.
    • If you do not want to use the IBL settings, uncheck the "Use Image Based Lighting (IBL)" checkbox.
  4. Then, "Import GLTF" dialog will be displayed.
    • IBL settings cannot be changed on the Import Dialog.
    • See Import Dialog Options for information on setting items on the dialog screen.
  5. Configure import settings to your needs and click "OK" button.
