How to Import Resources
    Import File Formats
    Import Operations
      Menu Bar
      Context menu
      Drag and Drop
        Image, font, shader, FBX, and script file formats
        Icon file format
        SVG file format
        glTF file format
        Import File Formats
        • Image files (*.bmp, *.jpg, *.jpeg, *.gif, *.tga, *.png, *.dds, *.ktx, *.hdr, *.exr)
        • Font files (*.ttf, *.otf, *.fnt, *.fbm)
        • Shader files (*.vert, *.frag)
        • SVG files (*.svg)
        • FBX files (*.fbx)
        • glTF files (*.gltf, *.glb)
        • Icon files (*.bmp, *.ico, *.jpg, *.png)
        • Script files (*.lua)
        glTF file format
        FBXSceneComposer andsupports following glTF file importformats operationswhen areimporting:
        not
        available
          glTF: This points to external binary data (geometry, key frames, skins), and images. glTF-Embedded: This embeds base64-encoded binary data, and images inline using data URIs. glTF-Binary: In Binary glTF, a glTF asset (JSON, .bin, and images) can be stored in a binary blob.
          For more detailed information on OpenGLthe ES1.1file platformsformats, suchplease assee Traveo2.the Khronos website: GLB File Format Specification.
          About .ktx File Format
          • Etc2CompressedRgbFormat
          • Etc2CompressedSrgbFormat
          • Etc2Alpha1CompressedRgbaFormat
          • Etc2Alpha1CompressedSrgbaFormat
          • Etc2EacCompressedRgbaFormat
          • Etc2EacCompressedSrgbaFormat
          • Texgenpack
          • Mali Texture Compression tool
          • Ericcson Texture Compression Tool
          About Bitmap Font
          • .fnt (windows font files) - are converted to bitmap fonts
          • .fbm - already converted bitmap font files
          • Source file names: specifies the name of the file which was imported - helps the user identify a font
          FBX and glTF file import operations are not available on OpenGL ES1.1 platforms such as Traveo2.
          Import Operation
          Menu Bar
          Context menu
          Drag and Drop
            • glTF file can also be imported by drag-and-drop to any folder under Solution in Solution Explorer.
            • Note that shader files (*.vert, *.frag) and SVG files (*.svg) cannot be imported by drag-and-drop in OpenGL ES1.1 environment.
            • When an image file format (*.bmp, *.jpg, *.png) that can be imported as an icon is dragged and dropped into any folder under Solution in Solution Explorer, the dialog box will appear as shown below, allowing you to select whether to import it as an image or icon resource. You can choose whether to import it as an image or an icon.
            After saving the solution, the Import Resources dialog is opened, where you can select one or more resource files to be imported. Select your files to import and press OK.
              You can search for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog. You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.
              After choosing your files to import, an Import dialog will be displayed depending on the file types you are importing (Image, Font, FBX, Shader…).
                See Import Dialog Options for a description of the settings on the dialog screen.
                Configure import settings to your needs and click "OK" button.
                  The file will be imported as a resource in the Solution Explorer in the location corresponding to the settings on the dialog screen.
                  Icon files
                  1. When the import process is executed, Scene Composer will display a message to save any unsaved changes in the solution. Press OK to proceed. If you do not want this dialog to appear during the import process, uncheck the "Always show this dialog" checkbox.
                  2. After saving the solution, the Import Resources dialog is opened, where you can select one or more resource files to be imported. Select your files to import and press OK.
                    • You can search for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog.
                    • You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.
                  3. After choosing your files to import, an Import dialog will be displayed depending on the file types you are importing (Image, Font, FBX, Shader…).
                  4. Configure import settings to your needs and click "OK" button.
                    • The file will be imported as a resource in the Solution Explorer in the location corresponding to the settings on the dialog screen.
                  SVG
                  Icon files
                  See Icon Picker for information on how to use imported icon resources.
                  After saving the solution, the Import Resources dialog will open. Select the target file and press OK. If the selected file format is "*.ico", the [ Import Icons ] dialog will appear as shown below.
                    The path of the selected file is displayed in the [ Selected files ] field. To re-select a file, press the [ Select File... ] button.
                    In [ Destination folder ], specify the location where the file will be imported as a resource.
                    As explained in the Drag and Drop section, if you drag and drop an image file format that can be imported as an icon (*.bmp, *jpg, *.png), the above dialog will appear and you can import it as an icon.
                    Click "OK" button to complete the import operation.
                    SVG files
                      After saving the solution, the Import Resources dialog is opened, where you can select one or more resourceSVG files to be imported. Select your files to import and press OK.
                      You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.once.
                      After choosing your files to import, an ImportSVG Importer dialog will be displayed depending on the file types you are importing (Image, Font, FBX, Shader…).displayed.
                      • "ImportedScenes" and "Scenes" folders have been created at the destination folder chosen in "Solution Explorer". The former holds data imported as template scenes, while the latter holds data imported as actual scenes.
                      If multiple SVG files have been imported, the Scene Editor will display the actual scene for what was the topmost SVG file in the SVG Importer.
                        Transform > Position > X = 0, Y = 0 will be the item's initial position.
                        Copy group nodes within imported asscenes a resource ininto the Solutiondesired Explorerscene inand theuse location corresponding to the settings on the dialog screen.them.
                        glTF files
                          - Skinning
                          - Morping
                          - Vertex Buffer Streams
                          - Sparse Accessors
                          - Multiple UV Maps
                        There
                        is a supplement on the handling of glTF files. Please check this page as well.
                        Images, fonts, shaders, FBXs, script files
                        3. You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.once.
                        4. After choosing your files to import, an Import dialog will be displayed depending on the file types you are importing (Image, Font, FBX, Shader…).
                          • IBL settings are also available in Solution Options. See IBL Texture for more information on the settings.
                        5. These three values must be defined when using IBL. They cannot be reconfigured after import.
                        If you do not want to use the IBL settings, uncheck the "Use Image Based Lighting (IBL)" checkbox.
                        Then, "Import GLTF" dialog will be displayed.
                          IBL settings cannot be changed on the Import Dialog.
                          See Import Dialog Options for ainformation descriptionon ofsetting the settingsitems on the dialog screen.
