How to Import Resources
This section describes how to import operationsresources forusing [ Import Resources... ] from [ Import ] on the followingmenu bar. The file formats.formats to be imported when using this menu are as follows
  • Image files (*.bmp, *.jpg, *.jpeg, *.gif, *.tga, *.png, *.dds, *.ktx, *.hdr, *.exr)
  • Font files (*.ttf, *.otf, *.fnt, *.fbm)
  • Shader files (*.vert, *.frag)
  • SVG files (*.svg)
  • FBX files (*.fbx)
  • glTF files (*.gltf, *.glb)
  • Icon files (*.bmp, *.ico, *.jpg, *.png)
  • Script files (*.lua)
FBX and glTF file import operations are not available on OpenGL ES1.1 platforms such as Traveo2.
About .ktx File Format
  • Etc2CompressedRgbFormat
  • Etc2CompressedSrgbFormat
  • Etc2Alpha1CompressedRgbaFormat
  • Etc2Alpha1CompressedSrgbaFormat
  • Etc2EacCompressedRgbaFormat
  • Etc2EacCompressedSrgbaFormat
  • Texgenpack
  • Mali Texture Compression tool
  • Ericcson Texture Compression Tool
About Bitmap Font
  • .fnt (windows font files) - are converted to bitmap fonts
  • .fbm - already converted bitmap font files
  • Source file names: specifies the name of the file which was imported - helps the user identify a font
Import Operation
    Menu
    Bar
    Select [Import] > [Import Resources...] from the menu bar. .
    Context menu
    Drag and Drop
      • glTF file can also be imported by drag-and-drop to any folder under Solution in Solution Explorer.
      • Note that shader files (*.vert, *.frag) and SVG files (*.svg) cannot be imported by drag-and-drop in OpenGL ES1.1 environment.
      • When an image file format (*.bmp, *.jpg, *.png) that can be imported as an icon is dragged and dropped into any folder under Solution in Solution Explorer, the dialog box will appear as shown below, allowing you to select whether to import it as an image or icon resource. You can choose whether to import it as an image or an icon.
        Image, font, shader, FBX, and script files glTF files Icon files SVG files
        Images, fonts, shaders, FBXs, script files
        1. When the import process is executed, Scene Composer will display a message to save any unsaved changes in the solution. Press OK to proceed. If you do not want this dialog to appear during the import process, uncheck the "Always show this dialog" checkbox.
        2. After saving the solution, the Import Resources dialog is opened, where you can select one or more resource files to be imported. Select your files to import and press OK.
          • You can search for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog.
          • You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.
        3. After choosing your files to import, an Import dialog will be displayed depending on the file types you are importing (Image, Font, FBX, Shader…).
        4. Configure import settings to your needs and click "OK" button.
          • The file will be imported as a resource in the Solution Explorer in the location corresponding to the settings on the dialog screen.
        glTF
        file
        Once
        Icon files
          When the import process is complete,executed, Scene Composer will display a message to save any unsaved changes in the solution. Press OK to proceed. If you do not want this dialog to appear during the import process, uncheck the "Always show this dialog" checkbox.
            You can search for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog. You can import multiple files at once as long as their file format belong to the solutionsame category, such as an Image file or a Font file.
              See Import Dialog Options for a description of the settings on the dialog screen.
                SVG files
                    You can search for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog. You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.
                        glTF files
