How to Import Resources
This section describes import operations for the following file formats.
  • Image files (*.bmp, *.jpg, *.jpeg, *.gif, *.tga, *.png, *.dds, *.ktx, *.hdr, *.exr)
  • Font files (*.ttf, *.otf, *.fnt, *.fbm)
  • Shader files (*.vert, *.frag)
  • SVG files (*.svg)
  • FBX files (*.fbx)
  • glTF files (*.gltf, *.glb)
  • Icon files (*.bmp, *.ico, *.jpg, *.png)
  • Script files (*.lua)
About .ktx File Format
  • Etc2CompressedRgbFormat
  • Etc2CompressedSrgbFormat
  • Etc2Alpha1CompressedRgbaFormat
  • Etc2Alpha1CompressedSrgbaFormat
  • Etc2EacCompressedRgbaFormat
  • Etc2EacCompressedSrgbaFormat
  • Texgenpack
  • Mali Texture Compression tool
  • Ericcson Texture Compression Tool
About Bitmap Font
  • .fnt (windows font files) - are converted to bitmap fonts
  • .fbm - already converted bitmap font files
  • Source file names: specifies the name of the file which was imported - helps the user identify a font
Import Operation
  • Select [Import] > [Import Resources...] from the menu bar. .
  • Right-click on any folder in Solution Explorer and select [Import] > [Resource...] from the context menu that appears.
  • Drag and drop the target file to be imported into any folder in Solution Explorer.
  • Image, font, shader, FBX, and script files
  • glTF files
  • Icon files
  • SVG files
Images, fonts, shaders, FBXs, script files
  1. When the import process is executed, Scene Composer will display a message to save any unsaved changes in the solution. Press OK to proceed. If you do not want this dialog to appear during the import process, uncheck the "Always show this dialog" checkbox.
  2. After saving the solution, the Import Resources dialog willis open.opened, where you can select one or more resource files to be imported. Select theyour targetfiles fileto import and press OK.
    • You can search for supported file formats by specifyingselecting them in the drop-down menu at the bottom right of the fileImport selectionResources dialog.
      Multiple
    You can import multiple files canat be imported togetheronce as long as theytheir arefile informat belong to the same category, such as an Image file formator (images,a fonts,Font etc.).file.
    AnAfter importchoosing your files to import, an Import dialog will appearbe displayed depending on the file formattypes you are importing (images,Image, fonts,Font, shaders,FBX, etc.Shader…).
    to
    be imported.
    Configure import settings asto neededyour needs and click "Import.OK" button.
      The file will be imported as a resource in the Solution Explorer in the location corresponding to the settings on the dialog screen.
      glTF file
      Once the import process is complete, Scene Composer will display a message to save any unsaved changes to the solution
