Axure RP Importing example
In this section, explain how to import Axure RP file format using Smart Importer.
You can get the Axure RP file described below at the following location.
"...\cgi-studio-root\cgi_studio_content\Resources\AxureRP\AxureTest.rp"
- The sample Axure RP file contains a button that links to page 2, an image, a text, a checkbox and a radiobutton.
Direct import
CGI Studio ver.3.11 allows you to import *.rp file directly via Smart Importer. Move the following step.
How to import
- In SceneComposer, open a solution file, and select Import > Smart Importer from the main menu. And select your import target file (.xscil, .xd, .rp and .sketch).
- Browse to the *.xscil file that was generated.
- In case a font used in the Axure file was not imported to Scene Composer, a pop-up message will appear. Click OK to proceed a default font will be used in such a case.
- Click on the items in layer tree and check the detected controls you want to assign to each in the Controls List. For this sample, the detected controls don’t need any manual assignment.
Click Scene 2 under “Scenes” on the right side to show page 2.
Set the desired Import settings. Click OK.
A pop-up message might appear asking whether to import the State Machine as Global. If set to global, this will become the main State Machine.
Run in CGI Player. When the button is clicked, the scene should display page 2.
