Axure RP Importing example
In this section, explain how to import Axure RP file format, direct or indirect. If you import indirectly file format, you need to set-up the environment of Intermediate Language (IML) in advance. Please refer to the Intermediate Language Exporters.
You can get the Axure RP file described below in the PDF file at the following location.
"...\cgi-studio-root\cgi_studio_docs\Documentation\AxureRPImport.pdf"
Indirect import
At first, create *.xscil file (Intermediate Language file) by using Axure2IML.exe. Then move the following step. Please refer to the Intermediate Language Exporters to get how to create in detail.
Direct import
CGI Studio ver.3.11 allows you to import *.rp file directrly via Smart Importer. Move the following step.
How to import
Click Scene 2 under “Scenes” on the right side to show page 2.
Set the desired Import settings. Click OK.
A pop-up message will appear asking whether to import the State Machine as Global. If set to global, this will become the main State Machine.
Run in CGI Player. When the button is clicked, the scene should display page 2.
