Menu bar
Each feature of Scene Composer can be selected and executed from the menu bar. The menu bar contains "File," "Edit," "View," and other major items, and each feature and various settings are arranged under these major items, just as in a general application. Each feature and setting can also be executed using the key commands at the right end of the menu bar. This page explains the functions and various settings for each major item.
File
| Menu name |
Description |
Note |
| New Solution... |
Create a new solution. |
[ Detail ] |
| Open Solution... |
Opens an existing solution. |
[ Detail ] |
| Close Solution |
Closes the currently open solution. |
ー |
| Source Control |
Import/checkout source control. |
[ Detail ] |
| Save Solution |
Overwrites the currently open Solution. |
[ Detail ] |
| Save Solution As... |
Save the currently open solution as. |
[ Detail ] |
| Clear Solution Cache |
Clears the solution cache. |
[ Detail ] |
| Recent Soltions |
Displays recently opened solutions. |
[ Detail ] |
| Solution Reports... |
Displays the Solution Report. |
[ Detail ] |
| Preferences... |
Opens the "Preferences" dialog. |
[ Detail ] |
| Solution Options... |
Opens the "Solution Options" dialog. |
[ Detail ] |
| Generate Asset Library... |
Generate Asset Library |
[ Detail ] |
| Export SCL... |
Exports SCLs (Shared Component Libraries). |
[ Detail ] |
| Automation Scripts... |
Sets up automatic execution of user-defined scripts. |
[ Detail ] |
| Export Symbolic Names... |
Exports a header file (.h) with a list of symbolic names. |
[ Detail ] |
| Define application specification |
Sets up application specifications (definitions for the connection between the Scene Composer solution and the CGI Panel).
[ Detail ] |
| Set External Resources Path… |
Sets the folder where external resources will be placed. |
[ Detail ] |
| Synchronize with HMI Contract... |
Set up the HMI contract files to be synchronized. |
[ Detail ] |
| Set visualState project... |
Set up the visualState project to communicate with. |
[ Detail ] |
| Exit |
Exit Scene Composer. |
ー |
Edit
| Menu name |
Description |
Note |
| Undo |
Undo the previous operation. |
[ Detail ] |
| Redo |
Redo the previous operation. |
[ Detail ] |
| Go To Previous Element |
Moves to the previous element. |
ー |
| Do Layout |
Apply layout. |
ー |
| Go To Next Element |
Moves to the next element. |
ー |
| Search |
Displays the search panel. |
[ Detail ] |
| Text Search |
Displays the text search panel. |
[ Detail ] |
View
| Menu name |
Description |
Note |
| New perspective |
Saves a new perspective (Scene Composer layout). |
[ Detail ] |
| Delete Perspective |
Deletes the active perspective. |
[ Detail ] |
| Restore Default Layout |
Resets the Scene Composer layout to default. |
ー |
| Toolbar |
Shows/hides the icons related to the navigation/editor profile/scripting system contained in the toolbar.
[ Detail ] |
| 2D Editing Utilities |
Enables/disables various features of the 2D scene editor. |
[ Detail ] |
| 3D Editing Helpers |
Enables/disables various 3D scene editor features. |
[ Detail ] |
| Panels |
Display/Hide various panels. |
[ Detail ] |
The Render Slots panel cannot be used unless Safety function is enabled. For more information about the Safety function, please contact our representative.
Platform
| Menu name |
Description |
Note |
| New Display... |
Add a new display. |
[ Detail ] |
| New Render Target... |
Add a new render target. |
[ Detail ] |
| Manage Render Targets... |
Opens the Manage Render Targets dialog included in the solution. |
[ Detail ] |
| Device Capabilities... |
The specifications of the simulation device and target device are displayed |
[ Detail ] |
| SCHost Information... |
SCHost information is displayed. |
[ Detail ] |
Shader
| Menu name |
Description |
Note |
| New Shader... |
Add a new shader. |
[ Detail ] |
| New Shader Program... |
Add a new shader program. |
[ Detail ] |
| Compile Shader |
Compile shaders. |
[ Detail ] |
Script
| Menu name |
Description |
Note |
| New Script... |
Create a new script. |
[ Detail ] |
| Validate Script |
Validate a script. |
[ Detail ] |
| Start | Pause Script System |
Runs a script system or pauses a running script system. |
[ Detail ] |
| Stop Script System |
Stops the script system from running. |
[ Detail ] |
Import
| Menu name |
Description |
Note |
| Import Resources.... |
Imports various resources. |
[ Detail ] |
| Import Raw Resources... |
Import raw resources. |
[ Detail ] |
| Import Benchmarks... |
Import render benchmarks (.crsms) exported from CGI Analyzer. |
[ Detail ] |
| Import From Solution... |
mport various resources from existing solution files. |
[ Detail ] |
| Smart Importer |
Import various graphics resources via the Smart Importer. |
[ Detail ] |
| Configure Automatic Imports,,, |
Set up automatic import (image and fbx files only).
[ Detail ] |
| Image Update... |
Import images from any folder at once. |
[ Detail ] |
| Delete Unused Imports... |
Delete imported but unused items. |
[ Detail ] |
Scene
| Menu name |
Description |
Note |
| New 2D Scene... |
Create a new 2D scene. |
[ Detail ] |
| New 3D Scene... |
Create a new 3D scene. |
[ Detail ] |
| Refresh Scene |
Reload the active scene. |
[ Detail ] |
Animation
| Menu name |
Description |
Note |
| New Animation Group... |
Creates a new animation group. |
[ Detail ] |
| Start Animation |
Start an existing animation. |
[ Detail ] |
| New Animation... |
Create a new animation. |
[ Detail ] |
| Stop Animation |
Stops an existing animation that is starting. |
[ Detail ] |
State Machine
| Menu name |
Description |
Note |
| New State Machines... |
Create a new state machine. |
ー |
| Attach... |
Make a TCP connection to the application. |
ー |
| Validate Active State Machine |
Validate the active state machine. |
ー |
Report
| Menu name |
Description |
Note |
| HMI Report... |
[ Detail ] |
| Text Size Report... |
[ Detail ] |
Language
| Menu name |
Description |
Note |
| Culture Solution Options... |
Opens the Culture Solution option. |
[ Detail ] |
| Export Languages... |
Open the Select Cultures dialog. Select the language for output. |
[ Detail ] |
| Import languages |
Opens the Import Languages dialog. Select the file to import.
[ Detail ] |
| Language Usage... |
[ Detail ] |
| Language Table... |
[ Detail ] |
Help
| Menu name |
Description |
Note |
| Help |
Open the CGI Studio help documentation (this document). |
[ Detail ] |
| Video Tutorials |
Open the video tutorial on basic CGI Studio usage. |
[ Detail ] |
| Quick Start Guide |
Open the CGI Studio Basic Usage tutorial. |
[ Detail ] |
| Welcom Screen |
Opens the Welcome to Scene Composer dialog. |
ー |
| Hot keys.,, |
Opens a list of shortcut keys. |
[ Detail ] |
| Licenses... |
Opens the License dialog. |
[ Detail ] |
| Visit Lighthouse |
Opens the Lighthouse (support/forums page). |
ー |
| Feedback |
Opens a dialog for submitting feedback about CGI Studio. |
ー |
| About... |
Displays information about Scene Composer. |
ー |
