Importing resources (Smart Importer)
Import contents into each scene in the solution using the Smart Importer, which uses AI to analyze Photoshop files to detect, suggest, and create controls for the Scene Composer solution. This step describes the operation of assigning appropriate controls to images on a resource using the Smart Importer.
Gauge Control
  1. From the menu bar, select "Import" and then "Smart Importer > From Local File..." and, select the resource to be imported.
    imported
    • A file selection dialog will appear.be
        opened
    • If your solution contains unsaved changes you have not saved the solution yet, a dialog will appearbe prompting youprompted to save theyour filesolution first.
    before importing. Clicking In this tutorial, "Car_Cluster.psd" saved[OK] in the followingprompt folderwill issave used.your solution.
    Resource to be Imported Path Filename \cgi_studio_content\2D\PSDPSD\ Car_Cluster.psd
    In the Smart Importer file selection dialog choose the resource to be imported as specified in the table below, then click [Open].
    • The Smart Importer dialog box appears.
      will
        be
      • opened.
        For more information on the Smart Importer dialog box, click click here.
      TheBefore clicking the [ OK ]OK] button at the bottom of the Smart Importer dialog boxbox, isfollow pressedthe whenconfiguration allinstructions settingsin arethe completesteps and performing import.below.
      Expand "Cluster" in the Layer tree ofIn the Smart Importer dialogdialog's Layer tree expand "Cluster" by clicking on the white triangle on its left and select "Gauge Left".
      • A control list appears on the right side of the dialog, listing the available controls.
      • The number displayed to the right of each control indicates the AI's detection rateconfidence byfor thethat AI.specific item.
      PressIn the Control list press the [ Apply ]Apply] button foron the right side of the Gauge control from Control list.control.
      • The Gauge control is assigned to "Gauge Left"left" onwill thebe layerdisplayed treein ("Gaugea Left"different text color changeswith toa blue).different icon. This indicates a successful assignment of a Scene Composer control.
      • The Appearance tab will be automatically selectselected on the right side of the dialog.
      SetConfigure the following settings inunder [ Appearance ]Appearance] and [ Basic PropertiesProperties] ]sections of "Gauge Left".
      • For the specifications and specific operation for [ Appearance ]Appearance] and [ Basic Properties ]Properties], please refer to here.
      • Note
        If that ifno "BackgroundImage" is not set for layer mapping, the standarddefault background of the Gauge control iswill be used instead of the image onfrom the Photoshop file.
        Gauge left
        Target Tab Target Item Setting Value
        Appearance
        SelectTo configure the image properties, select [Select layers] from the pull-drop-down menumenu. andThis setwill asopen follows.a dialog where the appropriate ImageLayers can be selected.
        After selecting the image, check [Pivot Point].
        BackgroundImage
        Scala kmh
        Gauge Background
        NeedleImage
        NeedleImage
        Basic Properties
        Name
        InputMax
        RotationMax
        SpeedGauge
        240
        225
      ApplyIn the Smart Importer dialog's Layer tree select the Text "000" which can be found directly below "Speed Gauge". In the Control List apply the control "Text Value" and configure its properties according to the Texttable in the "Gauge Left" and set the following.
      below.
      Gauge left
      Basic properties
      Name
      SpeedValue
      Perform the step 2 through step 6 above for theConfigure "Gauge Right" asin well.the same manner by following the instructions from step 3 through step 7. Apply the settings provided in the table below.
      • The settingsconfiguration forof the Gauge and Text Value controls areis shownnow in the table below.
        complete.
        Gauge Control
        Appearance
        BackgroundImage
        Scala rpm
        Gauge Background
        NeedleImage
        NeedleImage
        Basic Properties
        Name
        InputMax
        RPMGauge
        8000
        Text Value control
        Basic Properties
        Name
        RPMValue
      Duplicate and setConfigure up scenesScenes
      Transitions between scenes are made using State Machine Editor function described below. In this section, duplicate the "Car_Cluster"Smart Importer's Layer Tree expand the Cluster > Middle group. There you can see that the photoshop file to whichbe imported provides 3 scenarios for the controlsmiddle havepart: been
      applied
      upCar toCar theStatus previousIncoming sectionCall. and create a separate scene.
      The following operations are performed on the right sidegoal of the Smartfollowing Importersteps dialogis box,to [create Importseparate Settingsscenes ]for tab.each of the 3 scenarios.
      1. SelectIn the Smart Importer's "Import Settings" section under "Scenes" right-click on the Car_Cluster inscene [ Scene Name ] and choose [ Duplicate Scene... ] from the context menu.
        • The [ Clone Scene... ] dialog appears.will be opened.
      2. Enter "Car_Status" asIn the name"Clone ofScene..." dialog enter the scene toname beas duplicated andspecified pressin the table below, then click [ OK ] button.OK].
        • A new scene namedconfiguration has been created.
      3. In the "Import Settings" tab the new "Car_Status" isscene createdwill be displayed and displayedactively inselected.
      The Preview window displays the Car_Status scene. The Layer Treetree anddisplays Preview.
      the Car_Status scene's layers.
      Clone Scenes... Property Value Name Car_Status
      With the "Car_Status" scene selected,selected in the "Import Settings" tab under "Scenes", expand "Cluster" > "Middle" fromin the Layer Tree.
      • The checkThere is a checked checkbox in placefront on theof "Car". The checkboxes of "Car Status" and "Incoming Call" are unchecked.
      UncheckIn "Car"the Layer Tree uncheck and checkuncheck "Carthe Status".
      checkboxes as specified in the image and table below.
      • The centerSmart ofImporter's Preview window will be updated accordingly, displaying the imagechecked displayedand inhiding the Previewunchecked section changes.
        layers.
        Scene "Car_Status": Cluster > Middle Layer Checkbox Car unchecked Car Status checked Incoming Call unchecked
      Repeat operations 1 through 4 above, this time addingchecking anand "Incomingunchecking Call"the scene.Layers as provided in the table below.
      • InThere stepare 4,3 checkscenes in the "Import Settings" tab's Scenes section: Car_Cluster, Car_Status and Incoming_Call.
      The import configuration is completed.
      Clone Scenes... Property Value Name Incoming Call"Calls checkbox.
      Scene "Incoming_Call": Cluster > Middle Layer Checkbox Car unchecked Car Status unchecked Incoming Call checked In
      Thethe resourceScene's preparationsection workof isthe completed.Import ClickSettings tab select each scene and verify its content in the Preview. Once all of the scenes have been reviewed, click the [ OK ]OK] button in the Smart Importer dialog box to performinitiate the import.
