64-bit support Scene Composer
Since CGI3.13, Scene Composer has become a 64-bit support application. As a result, the following benefits are expected when compared to the 32-bit Scene Composer
  • Enables creation of complex, large-scale HMI solutions that exceed 32-bit memory limitations
  • Ability to import and memory process large, complex assets via the Smart Importer
On the other hand, the C++ SCHost.dll used for launching Scene Composer has to be built as well in 64-bit mode. For this reason, CGI 3.14 or later has a function to automatically check if SCHost.dll is properly built when starting Scene Composer. If you are using SCHost.dll built in 32-bit, the following error dialog will be displayed.
The two buttons on the dialog perform the following actions.
[ OK ] button Closes the Scene Composer.
[ Open... ] button Opens the Scene Composer log file with any editor.
PleaseThe save32/64bit thecompatibility logtable filefor displayedeach byversion clickingof theCGI [Studio Open...is ]shown button with any file name and provide it to our support team to resolve the above error message.
below.
CGI Version Scene Composer and SCHost.dll CGI Player
Up to CGI3.3 32bit required 32bit required
From CGI3.4 to CGI3.12 32bit required 32bit or 64bit  required
CGI3.13 and later 64bit required 32bit or 64bit  required
