Integration of Monotype
- Font engine: iType
The font engine: iType
- adding prebuilt libraries
- add the third party code into the build process
CGIStudio supports both by CMake settings.
Cache support
Overview: CMake settings
| Flag | Value |
| CANDERA_FONTENGINE | Monotype |
If HarfBuzz is selected as the current TextShaper, the flag CANDERA_TEXTSHAPER automatically will change to WorldType-Shaper. Shaping can also be disabled.
HarfBuzz requires Freetype and is not available for iType.
This flag is called Monotype to switch to the available Monotype engines. The concrete font engine will be iType.
The flag MONOTYPE_USE_BINARIES can be used to switch between the different building modes.
Build process: iType as source code
For this mode, MONOTYPE_USE_BINARIES has to be disabled.
- ONOTYPE_FONT_ENGINE_SRC_PATH - This path defines the location where to find the source code for iType. By default this will be cgi_studio_3psw/src/Monotype/iType and the folder structure may look like the following:
The FileList.txt which defines all the files should contain the following three Lists:- MONOTYPE_PUBLIC_HEADERS
- MONOTYPE_PRIVATE_HEADERS
- MONOTYPE_SOURCES
It does not matter how the source code is distributed on these lists. Only the names should be in use
- MONOTYPE_FEATSTD_PORT_ENABLED - This flag toggles the port API implementation between a CGIStudio version and the default win32_lib including the settings which are required for Candera. The win32_lib represents a default implementation of the framework, separated from any Candera relations. This enables an easy possibility to build iType in a separated environment and link it to Candera.
- MONOTYPE_FONT_ENGINE_PORT_PATH - This path is directly links to the port API which shall be used for the build. By default it links to the default location of the default CGIStudio implementation: cgi_studio_3psw/src/Monotype/iType/source/port/CGIStudio However, this can be changed to different implementations, too. If MONOTYPE_FEATSTD_PORT_ENABLED is false, this will link to the win32_lib definition.
Build process iType as prebuilt library
For this mode, MONOTYPE_USE_BINARIES has to be enabled.
The flags MONOTYPE_FEATSTD_PORT_ENABLED, MONOTYPE_FONT_ENGINE_PORT_PATH and MONOTYPE_FONT_ENGINE_SRC_PATH are equal in usage as in the source code version. The only difference is, that the prebuilt library only requires header files.
MONOTYPE_ITYPE_LIBRARY_FILEPATH is the path to the prebuilt library. And has to be defined by the user.
