Enabling Warping
Following are the display settings required to enable warping in Candera:
    Enable warping Set warp matrix Set warp image bounds Apply display settings
    Candera’s Display class uses a transaction based execution model for setting properties. Several changes can be queued. Changes have to be applied explicitly via a call to Display::ApplyChanges(). Warping matrix data from the warping library can be used directly in Candera.
