A simple configurable plugin
Creating a plugin that registers a configuration and uses the default configuration editor.
The Plugin class.
The first step is to create a class that implements the IPluginService interface. This is the type that will be instantiated by Scene Composer.
public class SimpleConfigurablePlugin : IPluginService
Implementing IPlugin
Next we must implement the IPluginService interface members.
public string Name { get { return return this.GetType().Name; } } public string Description { get { return "A plugin that has configuration"; } } public string Version { get { return "1.1.1"; } } public IEnumerable<int> FeatureIds { get { return null; } }
The Initialize method
First we need to register a custom cinfiguration interface and register to recieve an event when the configuration is loaded.
... var loader = unityContainer.Resolve<IConfigurationManager>().RegisterConfigurationInterface<ISimpleConfiguration>(); loader.ConfigLoaded += loader_ConfigLoaded; ...
Then we need to registter a defualt configuration definition of our custom type with the UI definition manager
unityContainer.Resolve<UIDefinitionManager>().RegisterUIElement ( new DefaultConfigDefinition<ISimpleConfiguration>(category: OptionCategories.Plugins, name: "Default Config") );
The full code for the example with extra info:
SimpleConfigurablePlugin.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Feat.UIComposition.UIConfiguration;
using FTC.SDKInterface.Plugins;
using FTC.SDKInterface.Services;
using Feat.UIComposition.Config;
using System.ComponentModel;
using Feat.UIComposition;
using Feat.UIComposition.Commanding;
using Feat.UIComposition.Menus;
using FTC.SDKInterface.Constants;
using Feat.Metadata.PropertyGrid;
namespace UIPlugins
/// <summary>
/// This examples demos a simple plugin that registers a configuration with FTC
/// and uses the default configuration editor in scene composer.
/// </summary>
public string Name
get { return this.GetType().Name; }
public void Initialize(IUnityContainer unityContainer)
// We register the configuration interface with the configuration manager.
// The object that is returned allow access to the config instance, allows the saving and loading of the configuration
// and allows the registration of events pertinent to the configuration, such as the loading of the config or a property change.
// Explicit loading or saving of the configuration is not necessary, as FTC will load the config the first time
// it is accessed, and will save it when the application closes.
// The plugin developer can however explicitly save the configuration or reload it from disk if necessary.
//We register to receive events when the configuration is loaded.
// We register with the ui definition manager a default configuration definition with the type of our custom config interface.
// We also specify the category in which to place the configuration, and the name to use for the section.
/// <summary>
/// Event handler for when the configuarion is loaded.
/// </summary>
/// <param name="sender"></param>
/// <param name="e"></param>
void loader_ConfigLoaded(object sender, ConfigLoadedEventArgs<ISimpleConfiguration> e)
// If the configuration was not loaded successfully, either this is the first time it it has been created
// and there was no configuration to load, or the configuration file was corrupted.
// Either way we initialize complex configuration properties, that could not be initialized with the DefaultValue attribute.
if (!e.ConfigLoadedSuccessfully)
e.Instance.OtherParameters = new List<string>
"Param1 "
/// <summary>
/// The configuration interface. This interface will be implemented by Scene Composer and offered to the plugin
/// when it is registered with the Configuration manager service.
/// </summary>
/// All properties declared in the configuration interface must conform to standard .NET XMLSerializer standards.
/// If we use the default editor for configurations then we can control how the property grid displays the content.
/// The CategoryDisplayInfo attribute specifies that the default category should have no header. \n
/// The DefaultValue attribute specifies the default value to be used for the property, either when resetting the value or
/// when the configuration is first created. \n
/// The Category attribute dictates the category in which the property grid will display the property. \n
/// The DisplayName attribute specifies what name the property grid should use for this property, if the attribute is not specified,
/// Scene composer will use the actual property name.\n
/// The Browsable attribute allows the hiding of properties in the property grid.
[CategoryDisplayInfo("", StyleKey = PropertyGridConstants.NoHeaderCategory)]
public interface ISimpleConfiguration : IConfiguration
[DefaultValue("format C:")]
string CommandToExecute { get; set; }
[DefaultValue(true)]
[DisplayName("Show confirmations")]
[Category("Options")]
bool Confirm { get; set; }
[DefaultValue(false)]
bool Silent { get; set; }
[Browsable(false)]
List<string> OtherParameters { get; set; }
