Value Processing Behaviors
Content List
    Animation Value Processing Behaviors
      Jump to Animation Keyframe
      Diagnostics Value Processing Behaviors
          Frame Measurement Effects Value Processing Behaviors
            Set Alpha Value
            Switch Image
            Switch Text Zoom Effect Transformation Value Processing Behaviors
              Resize Group Node Set Node Size
              Set Position
              Set Rotation
              Set Scale Move Node
              AnimationMeter
              Arithmetic Operation
              Clock
              Dial
              Filter
              Forward Value
              Interpolate Value
              Map Value
              Map Value Normalized
              Process Value Changed Event Render a Range
              Send ChangeValue On Receiving ProcessValue Event
              Set Selected State
              Smooth Value
              Render Child Nodes
              Format String
              Track Angle on Drag
              Drag on Track to Value
              Action on Value
              Value
              Common Properties
              Animation SharedPointer<Candera::Animation::AnimationPlayer> The animation controlled. AnimationProcessValueBehavior sets the animation to the frame corresponding to the value it receives.
              SequenceStartTime FeatStd::Optional<Candera::Animation::SequenceTimeType> The start point of the animation. [ms]
              SequenceDurationTime FeatStd::Optional<Candera::Animation::SequenceTimeType> The duration of the animation. [ms]
              ControlNode
              Candera::AbstractNodePointer
              Back to the menu
              Frame Measurement
              Class Reference
              Common Properties
              RenderTarget Candera::GraphicDeviceUnit* The render target which FPS should be monitored.
              Output OutputType::Enum Specifies which information will be output.
              DispatchThreshold FeatStd::Optional< FeatStd::Variant > Specifies how much the Output has to change to dispatch an event to its receivers.
              Receivers
              Back to the menu
              Set Alpha Value
              Common Properties
              Target Node Candera::AbstractNodePointer The Node which gets the resulting alpha value. If not set, then the node where the behavior is attached to, will be modified.
              Back to the menu
              Switch Image
              Supports
              Example Usage
              Common Properties
              Upload Strategy Enum (OnInit, OnDemand)
              Specifies if images are uploaded on demand or when the behavior is instantiated. OnInit may cause an initial delay and keeps all images loaded. OnDemand avoids an initial delay and only keeps one image loaded.
              Possible values: OnInit, OnDemand
              Target Node RenderNode * The Render Node SwitchImageProcessValueBehaviorwillSwitchImageProcessValueBehavior will switch images on.
              Images
              SharedPointer<Candera::Image2D>
              A list of images which should be available for selection.
              Textures
              SharedPointer<Candera::TextureImage>
              OutOfBoundsHandlingMode
              OutOfBoundsHandlingMode::Enum
              Behavior when an index greater than the number of images is given.
              Possible values: Hold, Clamping
              Back to the menu
              Switch Text
              Common Properties
              Target Node Candera::AbstractNodePointer The Render Node SwitchTextProcessValueBehaviorwillSwitchTextProcessValueBehavior will switch the text on.
              Texts
              ArrayProperty<FeatStd::String> Use list of texts (strings) and switch between them.
              Back to the menu
              Zoom Effect
              Common Properties
              Target Node
              Candera::AbstractNodePointer The node whose children are enabled or disabled by ZoomProcessValueBehavior. If not set, then the node where the behavior is attached to will be considered.
              Alpha Factors Vector2 Min/Max transparency factors
              Zoom Factors Vector2 Min/Max zoom factors
              Zoom Distribution Float Distribution of Zoom/Alpha to each side of the selection.
              Back to the menu
              Resize Group Node
              Common Properties
              AffectXAxis bool Enables or disables scaling in horizontal direction.
              AffectYAxis bool Enables or disables scaling in vertical direction.
              Mode
              Mode::Enum Determines how the received value will be interpreted.
              ScaleVector
              Vector2
              This vector is multiplied by the received value and specifies the magnitude by which the node is scaled.
              Back to the menu
              Set Node Size
              Common Properties
              Target Node Candera::AbstractNodePointer The target node which is modified. if not set, then the node where the behavior is attached to, will be modified.
              Size Axis AxisType2D::Enum
              The axis along which the size is set.
              Possible values: AxisX, AxisY
              Back to the menu
              Set Position
              Example Usage
              Common Properties
              Translation Axis 2D
              AxisType2D::Enum
              The axis along which the position is set.
              Translation Axis 3D
              AxisType3D::Enum
              Possible values: AxisX, AxisY,, AxisZ
              Back to the menu
              Set Rotation
              Example Usage
              Common Properties
              RotationAxis
              AxisType3D::Enum
              The axis to rotate the node around.
              Back to the menu
              Set Scale
              Example Usage
              Common Properties
              ScaleAlongX bool Enables or disables scaling in horizontal direction.
              ScaleAlongY bool Enables or disables scaling in vertical direction.
              ScaleAlongZ bool
              Enables or disables scaling in Z-direction.
              ScaleVector2D Vector2
              ScaleVector3D Vector3
              Back to the menu
              Move Node
              Example Usage
              Common Properties
              Target Node Candera::AbstractNodePointer The node TranslateProcessBehavior moves.
              Multiplied Vector Vector3 This vector is multiplied by the value TranslateProcessValueBehavior receives and specifies direction and magnitude by which TranslateProcessValueBehavior moves Translated Node. If not set, then the node where the behavior is attached to, will be modified.
              Back to the menu
              AnimationMeter
              Controls an animation according to the passed value.
              Back to the menu
              Common Properties
              Operation ArithmeticOperationType::Enum
              Arithmetic operation to be performed.
              Possible values: Addition, Subtraction, Multiplication, Division, Modulo, Absolute
              Operand FeatStd::Variant A number to be used as addend/subtrahend/multiplicant/divisor on provided value.
              OutputType VariantValueType::Enum
              Type of the Variant forwarded as result.
              Possible values: FloatValue, Int32Value, UInt32Value, BoolValue, DoubleValue, Int8Value, Int16Value,  Int64Value, UInt8Value, UInt16Value, UInt64Value, StringValue
              Receivers
              Back to the menu
              Clock
              Common Properties
              SecondsProcessValueBehavior Candera::ProcessValueBehavior*
              The behavior that receives the seconds.
              MinutesProcessValueBehavior Candera::ProcessValueBehavior*
              The behavior that receives the minutes.
              HoursProcessValueBehavior Candera::ProcessValueBehavior*
              The behavior that receives the hours.
              OffsetInMinutes FeatStd::Int32 Offset in minutes to add to time (i.e. for different time zones).
              ShowFull24Hours bool If true, hours will be shown from 0-23, otherwise in AM/PM format.
              AMText FeatStd::String The string of the AM label.
              PMText FeatStd::String The string of the PM label.
              AMPMTextBehavior Candera::Behavior*
              Sets text 'AM' or 'PM'.
              ShowSeconds bool If true, seconds will be shown.
              SecondsNode Candera::AbstractNodePointer The node that will be turned off if showing of seconds is disabled.
              Back to the menu
              Dial
              Common Properties
              CurrentValue FeatStd::Int32 Current value for the dial.
              MinimumRotation FeatStd::Float Minimum rotation of the dial.
              MaximumRotation FeatStd::Float Maximum rotation of the dial.
              StepSize FeatStd::Float Step size in degrees.
              KnobNode Candera::AbstractNodePointer Knob node which will be rotated.
              Receivers
              Back to the menu
              Filter
              Common Properties
              Condition Candera::ConditionBehavior* ConditionBehavior for passing the value to the next process value behavior.
              Receivers
              Back to the menu
              Forward Value
              Note that the target Value - Behavior must have 'Accept Value Event' property enabled.
              Example Usage
              Common Properties
              Event Dispatch Strategy EventDispatchStrategyType::Enum
              The way the event gets sent.
              Target Node Candera::AbstractNodePointer The target node to which the events are routed. If this property is not set, the event will be routed to the node of the behavior.
              Dedicated Behavior
              Back to the menu
              Interpolate Value
              If the Animation Mode property is set to Instant, no interpolation will be taking place - the received value will be applied immediately.
              Example Usage
              Common Properties
              Animation Mode InterpolationAnimationMode::Enum
              Animation mode sets a specific interpolation type.
              Units Per Second Float
              Speed at which InterpolateProcessValueBehavior changes its internal value.
              This property can only be set when AnimationMode is set to "SpeedBased".
              Interpolation Time
              UInt32
              Time in ms the InterpolateProcessValueBehavior changes its internal value.
              This Property can only be set when AnimationMode is set to "TimeBased"
              Filter Time Constant Float
              The moment before InterpolateProcessValueBehavior’s internal value reaches the received value, the speed at which the former is changing slows down. This prevents a sudden end of movement that can be felt as artificial in some cases.
              This property can only be set when AnimationMode is set to either "SpeedBased" or "Timebased".
              Receivers
              Back to the menu
              Map Value
              Common Properties
              InputMin FeatStd::Optional< FeatStd::Variant > [Optional] Smallest value of the interval to check. If Minimum is given as greater than Maximum then the values are internally swapped.
              InputMax FeatStd::Optional< FeatStd::Variant > [Optional] Largest value of the interval to check. If Maximum is given as smaller than Minimum then the values are internally swapped.
              OutputMin FeatStd::Float Smallest value of the interval mapped to.
              OutputMax FeatStd::Float Largest value of the interval mapped to.
              Receivers
              Back to the menu
              Common Properties
              Reverse bool Toggles the mapping direction. If this property is true, the received value is assumed to be within range from 0.0 to 1.0 and the emitted value is mapped accordingly.
              ValueForRange ValueBehaviorBase*
              The input value behavior for defining the mapped range.
              Receivers
              Back to the menu
              Example Usage
              Common Properties
              Sender Candera::AbstractNodePointer The node for which the event shall be emitted. If it is not set then the TargetNode or Node (if TargetNode is not set) will be taken instead.
              Minimum Optional<FeatStd::Variant> Minimum threshold of the processed values.
              Maximum
              Maximum threshold of the processed values.
              ConsumeEvent
              bool
              Receivers
              ProcessValueBehavior ArrayProperty
              Back to the menu
              Render a Range
              Renders a range of nodes according to the passed value.
              Back to the menu
              Send ChangeValue on receiving ProcessValue event
              Common Properties
              ChangeValue ChangeValue::Enum How the event value shall be handled by the recievingreceiving behavior
              Target Node
              This property is only visible if EventDispatchStrategy is set to "Direct", "Broadcast", "Bubble" or "Tunnel".
              This property only visible if EventDispatchStrategy is set to "DedicatedBehavior".
              Receivers
              Back to the menu
              Set Selected State
              Back to the menu
              Smooth Value
              Class Reference
              Common Properties
              SmoothingFactor FeatStd::Float The factor how fast the output value should adapt to the input value. Valid values are between 0.0 and 1.0
              Receivers
              Back to the menu
              Render Child Nodes
              Common Properties
              Levels FeatStd::UInt8 Number of levels to step down through groups. Default is zero.
              Back to the menu
              Format String
              Example Usage
              Common Properties
              Text String Text that TextBehavior will change the Node to. Supports formatting for one variable that corresponds to the value TextProcessValueBehavior2D receivers.
              Style SharedPointer <Candera::TextRendering::SharedStyle> The style that will be set to the Text Node.
              Alignment TextNode2DLayouter::TextAlignment
              Possible values: Auto, Left, Center, Right
              Multiline bool If multi line is disabled, then the new line control characters will be ignored and text will always be rendered in one line.
              Line Spacing PixelSize (UInt16) Defines the distance between the baselines of successive lines of type.
              Word Wrap Bool If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines.
              Trimming TextNode2DLayouter::Trimming
              Possible values: None, Ellipsis, CustomText
              TrimmingText FeatStd::String
              This property is only visible if Trimming is set to "CustomText".
              Back to the menu
              Track Angle on Drag
              Common Properties
              TouchNode Candera::AbstractNodePointer A node that is used to collect information about the touch.
              Receivers
              Back to the menu
              Common Properties
              UseCenter bool If true, the center value defined for the knob bitmap is used to align the knob to the value position, otherwise the calculated center.
              TrackDirection TrackDirection::Enum
              Defines if the position will be tracked horizontally or vertically
              LeftTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the left border of the knob. The size is given in percentage of the knob width. Positive values extend, negative values shrink the area.
              RightTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the right border of the knob. The size is given in percentage of the knob width. Positive values extend, negative values shrink the area.
              TopTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the top border of the knob. The size is given in percentage of the knob height. Positive values extend, negative values shrink the area.
              BottomTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the bottom border of the knob. The size is given in percentage of the knob height. Positive values extend, negative values shrink the area.
              OnKnobDragOnly bool The position will only be updated when the Knob gets dragged, otherwise clicking on the control will move the knob to the position.
              UseExcclusiveMode
              bool
              Enabling the option prevents some controls (e.g. Slider) from loosing the touch when leaving the node area.
              DraggedNode
              Defines the node to move along the track, to determine the hit area and to determine the position change relative to its center.
              Receivers
              Back to the menu
              Action on Value
              Example Usage
              Common Properties
              Condition ConditionBehavior* The ConditionBehavior that TriggerBehavior passes a value to and expect a response from to see if Action needs to be invoked.
              Actions ActionBehaviorArrayProperty The set of ActionBehaviors that TriggerBehavior invokes in the event that it receives a positive response form Condition.
              Consume Event bool Set this flag to false if the event should not be consumed by the trigger. By default it is set to true and if the trigger evaluates to true the event will not be routed to any other behavior.
              Back to the menu
              Value
              Example Usage
              Common Properties
              Minimum FeatStd::Optional< FeatStd::Variant >
              Minimum of the Variant value. If Minimum is given as greater than Maximum then the values are internally swapped.
              Maximum FeatStd::Optional< FeatStd::Variant > Maximum of the Variant value. If Maximum is given as smaller than Minimum then the values are internally swapped.
              IntervalHandling IntervalHandling::Enum
              Select how the behavior should react when the minimum or maximum limit is exceeded.
              Possible values: Limit, Cycle, Ignore
              AcceptValueEvent bool Set this flag to true to make the value changeable by events/actions.
              BroadcastProcessValueEvent bool Set this flag to true to broadcast ProcessValue event even if value did not change.
              DispatchStrategy
              By default the event that indicates that this value behavior has been changed (ValueChangedEvent) is dispatched only on the node to which the value behavior is attached (CgiStudioControl::EventDispatchStrategyType::Direct). To change this you have to select a different dispatch strategy.
              DedicatedBehavior
              Candera::Behavior*
              The dedicated behavior that will receive ValueChangedEvent when DedicatedBehavior dispatch strategy is selected.
              This property is only visible if DispatchStrategy is set to "DedicatedBehavior".
              TargetNode
              The node on which the for which the EventDispatchStrategy will be applied. If it is not set then the Node will be taken instead.
              This property is only visible if DispatchStrategy is set to "Direct", "Broadcast", "Bubble" or "Tunnel".
              Variant
              Candera::Variant Specifies the type and the value to pass onto Process Value Behavior.
              Receivers
              Back to the menu
