Value Processing Behaviors
Content List
Diagnostics Value Processing Behaviors
      Frame Measurement Effects Value Processing Behaviors
        Frame Measurement
        Transformation Value Processing Behaviors AnimationMeter
        Arithmetic Operation
        Clock
        Dial
        Filter
        Forward Value
        Interpolate Value
        Map Value
        Map Value normalizedNormalized
        Process Value Changed Event Render a Range
        Send ChangeValue onOn receivingReceiving ProcessValue eventEvent
        Set Selected State
        Smooth Value
        Render Child Nodes
        Format String
        Track Angle on Drag
        Drag on Track to Value
        Action on Value
        Value
        Animation Value Processing Behaviors
        Jump to Animation Keyframe
        Common Properties
        Animation Candera::MemoryManagement::SharedPointer<Candera::Animation::AnimationPlayer> The animation controlled. AnimationProcessValueBehavior sets the animation to the frame corresponding to the value it receives.
        Advanced Properties
        Property Name Type Description SequenceStartTime FeatStd::Optional<Candera::Animation::SequenceTimeType> The start point of the animation. [ms] SequenceDurationTime FeatStd::Optional<Candera::Animation::SequenceTimeType> The duration of the animation. [ms] ControlNode
        Candera::AbstractNodePointer
        Back to the menu
        Set Alpha Value
        Example Usage
        Common Properties
        Property Name Type Description Target Node Node2D* The Node which gets the resulting alpha value. If not set, then the node where the behavior is attached to, will be modified.
        Back to the menu
        Switch Image
        Supports
          Controls:
            FlipBook
            Example Usage
            Common Properties
            Property Name Type Description Upload Strategy Enum (OnInit, OnDemand) Specifies if images are uploaded on demand or when the behavior is instantiated. OnInit may cause an initial delay and keeps all images loaded. OnDemand avoids an initial delay and only keeps one image loaded. Target Node RenderNode * The Render Node SwitchImageProcessValueBehaviorwill switch images on.
            Back to the menu
            Switch Text
            Common Properties
            Property Name Type Description Target Node RenderNode * The Render Node SwitchTextProcessValueBehaviorwill switch the text on.
            Back to the menu
            Zoom Effect
            Common Properties
            Property Name Type Description Alpha Factors Vector2 Min/Max transparency factors Zoom Factors Vector2 Min/Max zoom factors Zoom Distribution Float Distribution of Zoom/Alpha to each side of the selection. Group Node Node2D* The node whose children are enabled or disabled by ZoomProcessValueBehavior.
            Back to the menu
            Frame Measurement
            Class Reference
            Common Properties
            RenderTarget Candera::GraphicDeviceUnit* The render target which FPS should be monitored.
            Output OutputType::Enum Specifies which information will be output.
            DispatchThreshold FeatStd::Optional< FeatStd::Variant > Specifies how much the Output has to change to dispatch an event to its receivers.
            Receivers
            Back to the menu
            Set Alpha Value
            Common Properties
            Property Name Type Description Target Node Candera::AbstractNodePointer The Node which gets the resulting alpha value. If not set, then the node where the behavior is attached to, will be modified.
            Back to the menu
            Switch Image
            Supports
              Controls:
                FlipBook
                Example Usage
                Common Properties
                Possible values: OnInit, OnDemand
                Target Node RenderNode * The Render Node SwitchImageProcessValueBehaviorwill switch images on. Images
                SharedPointer<Candera::Image2D>
                A list of images which should be available for selection.
                Textures
                SharedPointer<Candera::TextureImage>
                OutOfBoundsHandlingMode
                OutOfBoundsHandlingMode::Enum
                Behavior when an index greater than the number of images is given.
                Possible values: Hold, Clamping
                Back to the menu
                Switch Text
                Common Properties
                Property Name Type Description Target Node Candera::AbstractNodePointer The Render Node SwitchTextProcessValueBehaviorwill switch the text on. Texts
                ArrayProperty<FeatStd::String> Use list of texts (strings) and switch between them.
                Back to the menu
                Zoom Effect
                Common Properties
                Candera::AbstractNodePointer The node whose children are enabled or disabled by ZoomProcessValueBehavior. If not set, then the node where the behavior is attached to will be considered. Alpha Factors Vector2 Min/Max transparency factors Zoom Factors Vector2 Min/Max zoom factors Zoom Distribution Float Distribution of Zoom/Alpha to each side of the selection.
                Back to the menu
                Resize Group Node
                Common Properties
                AffectXAxis AbstractNodePointerbool Enables or disables scaling in horizontal direction.
                AffectYAxis Enum (AxisX, AxisY)bool Enables or disables scaling in vertical direction.
                Mode
                Mode::Enum (Absolute, Relative) Determines how the received value will be interpreted.
                ScaleVector
                Vector2
                This vector is multiplied by the received value and specifies the magnitude by which the node is scaledscaled.
                Back to the menu
                Set Node Size
                Common Properties
                Target Node Candera::AbstractNodePointer The target node which is modified. if not set, then the node where the behavior is attached to, will be modified.
                Size Axis AxisType2D::Enum (AxisX, AxisY)
                The axis along which the size is set.
                Possible values: AxisX, AxisY
                Back to the menu
                Set Position
                Example Usage
                Common Properties
                Translation Axis 2D
                The axis along PositionProcessValueBehavior2Dwhich translatesthe Positionposition Nodeis node.set.
                Translation Axis 3D
                AxisType3D::Enum
                The axis along which the position is set.
                Possible values: AxisX, AxisY,, AxisZ
                Back to the menu
                Set Rotation
                Example Usage
                Common Properties
                RotationAxis
                AxisType3D::Enum
                The axis to rotate the node around.
                Back to the menu
                Set Scale
                Expects a Float value as an event. Scales Scaled Node by the received (scalar) value multiplied by Vector (X Y (x value for horizontal scaling, yY value for vertical scaling). Scaling along either axis can be enabled or disabled.
                Example Usage
                Common Properties
                TargetNode TargetNodeType&Candera::AbstractNodePointer The Node which is modified. If not set, then the node where the behavior is attached to, will be modified.
                ScaleAlongX ScaleAlongXType (bool)bool Enables or disables scaling in horizontal direction.
                ScaleAlongY ScaleAlongYType (bool)bool Enables or disables scaling in vertical direction.
                ScaleAlongZ ScaleAlongZType (bool)bool
                Enables or disables scaling in Z-direction.
                ScaleVector2D ScaleVector3DType& (Vector2)Vector2
                This vector is multiplied by the received value and specifies the magnitude by which the node is scaled.
                ScaleVector3D ScaleVector3DType& (Vector3)Vector3
                Back to the menu
                Move Node
                Expects a Float value as an event. Translates Translated Node by the received (scalar) value multiplied by Vector X Y.Y (Z).
                Example Usage
                Common Properties
                Target Node Node2D *Candera::AbstractNodePointer The node TranslateProcessBehavior moves.
                Multiplied Vector XY Vector2Vector3 This vector is multiplied by the value TranslateProcessValueBehavior receives and specifies direction and magnitude by which TranslateProcessValueBehavior moves Translated Node. If not set, then the node where the behavior is attached to, will be modified.
                Back to the menu
                AnimationMeter
                DescriptionThis behavior is a Behavior Block. It can be dragged&dropped on nodes just like any Behavior.
                Controls an animation according to the passed value.
                Back to the menu
                Arithmetic operation behavior allows to perform additon,addition, subtraction, multiplication and division operations on the passed value.
                Common Properties
                Operation CgiStudioControl::ArithmeticOperationType::Enum
                Arithmetic operation to be performed.
                Possible values: Addition, Subtraction, Multiplication, Division, Modulo, Absolute
                Operand FeatStd::Variant A number to be used as addend/subtrahend/multiplicant/divisor on provided value.
                OutputType FeatStd::VariantValueType::Enum
                Type of the Variant forwarded as result.
                Possible values: FloatValue, Int32Value, UInt32Value, BoolValue, DoubleValue, Int8Value, Int16Value,  Int64Value, UInt8Value, UInt16Value, UInt64Value, StringValue
                Receivers
                Back to the menu
                Clock
                Common Properties
                SecondsProcessValueBehavior Candera::ProcessValueBehavior*
                The behavior that receives the seconds.
                MinutesProcessValueBehavior Candera::ProcessValueBehavior*
                The behavior that receives the minutes.
                HoursProcessValueBehavior Candera::ProcessValueBehavior*
                The behavior that receives the hours.
                OffsetInMinutes FeatStd::Int32 Offset in minutes to add to time (i.e. for different time zones).
                ShowFull24Hours bool If true, hours will be shown from 0-23, otherwise in AM/PM format.
                AMText FeatStd::String The string of the AM label.
                PMText FeatStd::String The string of the PM label.
                AMPMTextBehavior Candera::Behavior*
                Sets text 'AM' or 'PM'.
                ShowSeconds bool If true, seconds will be shown.
                SecondsNode Candera::AbstractNodePointer The node that will be turned off if showing of seconds is disabled.
                Back to the menu
                Dial
                Common Properties
                CurrentValue FeatStd::Int32 Current value for the dial.
                MinimumRotation FeatStd::Float Minimum rotation of the dial.
                MaximumRotation FeatStd::Float Maximum rotation of the dial.
                StepSize FeatStd::Float Step size in degrees.
                KnobNode Candera::AbstractNodePointer Knob node which will be rotated.
                Receivers
                Back to the menu
                Filter
                Common Properties
                Condition Candera::ConditionBehavior* ConditionBehavior for passing the value to the next process value behavior.
                Receivers
                Back to the menu
                Forward Value
                Forwards a received value.value Associatedto the associated target (associated controls with a value propertyproperty). receiveReceives a ValueChanged-Event (change notification) and forwards it as a ChangeValue-Event(change request) to the value.target. The common usecase is to send the Value from a Value behavior to another Value behavior(or Control with a Value).
                Note that the target Value - Behavior must have 'Accept Value Event' property enabled.
                Example Usage
                Common Properties
                Event Dispatch Strategy EventDispatchStrategyType::Enum (Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior)
                The way the event gets sent.
                Target Node Candera::AbstractNodePointer The target node to which the events are routed. If this property is not set, the event will be routed to the node of the behavior.
                Dedicated Behavior
                Back to the menu
                Interpolate Value
                Expects a Float value as an event. InterpolateProcessValueBehaviorThis behavior holds an internal Float value. It changes this internal value with given speed (Units Per Second) until it reaches the received value. Unless received value matches internal value, it sends internal value to a Process Value Behavior every frame.
                Example Usage
                Common Properties
                ReceiversAnimation Mode ReceiversTypeInterpolationAnimationMode::Enum The process
                Animation valuemode behaviorssets thata willspecific receiveinterpolation thetype.
                value
                Possible asvalues: nextSpeedBaesd, inTimeBased, theInstant
                Units Per Second Float Speed at which InterpolateProcessValueBehavior changes its internal value.
                Interpolation Time
                UInt32
                Time in ms the InterpolateProcessValueBehavior changes its internal value. Filter Time Constant Float The moment before InterpolateProcessValueBehavior’s internal value reaches the received value, the speed at which the former is changing slows down. This prevents a sudden end of movement that can be felt as artificial in some cases. Receivers
                Back to the menu
                Map Value
                Common Properties
                InputMin FeatStd::Optional< FeatStd::Variant > [Optional] Smallest value of the interval to check. If Minimum is given as greater than Maximum then the values are internally swapped.
                InputMax FeatStd::Optional< FeatStd::Variant > [Optional] Largest value of the interval to check. If Maximum is given as smaller than Minimum then the values are internally swapped.
                OutputMin FeatStd::Float Smallest value of the interval mapped to.
                OutputMax FeatStd::Float Largest value of the interval mapped to.
                Receivers
                Back to the menu
                Maps the numeric value received via 'ProcessValueEvent' within an arbitrary range to the normalized range from 0.0 to 1.0 and dispatachesdispatches the result locally to its receivers. Receivers of this Behavior must therefore be value processing behaviors operating on normalized values.
                Common Properties
                Reverse bool Toggles the mapping direction. If this property is true, the received value is assumed to be within range from 0.0 to 1.0 and the emitted value is mapped accordingly.
                ValueForRange ValueBehaviorBase*
                The input value behavior for defining the mapped range.
                Receivers
                Back to the menu
                This
                The ProcessValueChangedBehaviorbehavior handles ValueChanged events and processes the new value within a set of ProcessValueBehaviors chains. By default ProcessValueChangedBehavior does consume the event, which will result in dispatching the event any further in the dispatching strategy. If further dispatching of the ValueChangedEvent is required set the ConsumeEvent flag to false.
                Example Usage
                Common Properties
                Sender Candera::AbstractNodePointer The node for which the event shall be emitted. If it is not set then the TargetNode or Node (if TargetNode is not set) will be taken instead.
                Minimum boolOptional<FeatStd::Variant> Minimum threshold of the processed values.
                Maximum
                Maximum threshold of the processed values.
                ConsumeEvent
                bool
                Receivers
                ProcessValueBehavior ArrayProperty
                Back to the menu
                Render a Range
                Renders a range of nodes according to the passed value.
                Back to the menu
                Send ChangeValue on receiving ProcessValue event
                Common Properties
                ChangeValue ChangeValue::Enum How the event value shall be handled by the recieving behavior
                Target Node
                This property is only visible if EventDispatchStrategy is set to "Direct", "Broadcast", "Bubble" or "Tunnel".
                This property only visible if EventDispatchStrategy is set to "DedicatedBehavior".
                Receivers
                Back to the menu
                Set Selected State
                Back to the menu
                Smooth Value
                Class Reference
                Common Properties
                SmoothingFactor FeatStd::Float The factor how fast the outputtedoutput value should adapt to the input value. Valid values are between 0.0 and 1.0
                Receivers
                Back to the menu
                Render Child Nodes
                Example Usage
                Common Properties
                Levels FeatStd::UInt8 Number of levels to step down through groups. Default is zero.
                Back to the menu
                Format String
                'Format String' modifies the Text of a TextNode Node and provides the Text as property for Controls. It supports formatedformatted text that can display one variable.
                Example Usage
                Common Properties
                Text String Text that TextBehavior will change the Node to. Supports formatting for one variable that corresponds to the value TextProcessValueBehavior2D receivers.
                Style SharedPointer <Candera::TextRendering::SharedStyle> The style that will be set to the Text Node.
                Alignment Enum (Auto, Left, Center, Right, Justified)TextNode2DLayouter::TextAlignment
                Possible values: Auto, Left, Center, Right
                Multiline Boolbool If multi line is disabled, then the new line control characters will be ignored and text will always be rendered in one line.
                Line Spacing PixelSize (UInt16) Defines the distance between the baselines of successive lines of type.
                Word Wrap Bool If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines.
                Trimming Enum (None, Ellipsis, CustomText)TextNode2DLayouter::Trimming
                Possible values: None, Ellipsis, CustomText
                TrimmingText FeatStd::String
                This property is only visible if Trimming is set to "CustomText".
                Back to the menu
                Track Angle on Drag
                Common Properties
                TouchNode Candera::AbstractNodePointer A node that is used to collect information about the touch.
                Receivers
                Back to the menu
                Common Properties
                TargetNode
                Candera::AbstractNodePointer The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified. UseCenter bool If true, the center value defined for the knob bitmap is used to align the knob to the value position, otherwise the calculated center. TrackDirection TrackDirection::Enum
                Defines if the position will be tracked horizontally or vertically
                LeftTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the left border of the knob. The size is given in percentage of the knob width. Positive values extend, negative values shrink the area. RightTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the right border of the knob. The size is given in percentage of the knob width. Positive values extend, negative values shrink the area. TopTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the top border of the knob. The size is given in percentage of the knob height. Positive values extend, negative values shrink the area. BottomTouchMargin FeatStd::Float Defines the size for extending or shrinking the touch-sensitive area at the bottom border of the knob. The size is given in percentage of the knob height. Positive values extend, negative values shrink the area. OnKnobDragOnly bool The position will only be updated when the Knob gets dragged, otherwise clicking on the control will move the knob to the position. UseExcclusiveMode
                bool
                Enabling the option prevents some controls (e.g. Slider) from loosing the touch when leaving the node area.
                DraggedNode
                Defines the node to move along the track, to determine the hit area and to determine the position change relative to its center.
                Receivers
                Back to the menu
                Action on Value
                Example Usage
                Common Properties
                Condition ConditionBehavior* The ConditionBehavior that TriggerBehavior passes a value to and expect a response from to see if Action needs to be invoked.
                Actions ActionBehaviorArrayProperty The set of ActionBehaviors that TriggerBehavior invokes in the event that it receives a positive response form Condition.
                Consume Event Boolbool Set this flag to false if the event should not be consumed by the trigger. By default it is set to true and if the trigger evaluates to true the event will not be routed to any other behavior.
                Back to the menu
                Value
                Example Usage
                Common Properties
                Minimum FeatStd::Optional< FeatStd::Variant >
                Minimum of the Variant value. If Minimum is given as greater than Maximum then the values are internally swapped.
                Maximum FeatStd::Optional< FeatStd::Variant > Maximum of the Variant value. If Maximum is given as smaller than Minimum then the values are internally swapped.
                IntervalHandling IntervalHandling::Enum
                Select how the behavior should react when the minimum or maximum limit is exceeded.
                Possible values: Limit, Cycle, Ignore
                AcceptValueEvent bool Set this flag to true to make the value changeable by events/actions.
                BroadcastProcessValueEvent bool Set this flag to true to broadcast ProcessValue event even if value did not change.
                DispatchStrategy
                By default the event that indicates that this value behavior has been changed (ValueChangedEvent) is dispatched only on the node to which the value behavior is attached (CgiStudioControl::EventDispatchStrategyType::Direct). To change this you have to select a different dispatch strategy.
                DedicatedBehavior
                Candera::Behavior*
                The dedicated behavior that will receive ValueChangedEvent when DedicatedBehavior dispatch strategy is selected.
                This property is only visible if DispatchStrategy is set to "DedicatedBehavior".
                TargetNode
                The node on which the for which the EventDispatchStrategy will be applied. If it is not set then the Node will be taken instead.
                This property is only visible if DispatchStrategy is set to "Direct", "Broadcast", "Bubble" or "Tunnel".
                Variant
                Candera::Variant Specifies the type and the value to pass onto Process Value Behavior. Receivers
                Back to the menu
