Mixed Reality Behaviors
Contents List
Internal
Internal
Poi Metadata Handler
Behavior that handles the meta data of a single poi.
Common Properties
IconNodes ArrayProperty<Candera::AbstractNodePointer> A process value event is sent to this nodes, if a respective poi update event arrives.
NameNodes
OpenNowNodes
RatingNodes
PriceLevelNodes
InfoTextNodes
Back to the menu
Distance Alpha Fading
Distance Alpha Fading is a Behavior Building Block available in Construction Kit.
It receives a value representing the camera position and performs arithmetic operations on it to calculate target node alpha value.
The following operations are performed on input value:
  • Map (scale) value from initial range (default 0.00..100.00) to target range (default 0.00..1.00)
  • Negate scaled value (changes the range to 0.00..-1.00) by multiplication (default multiplicand is -1.00)
  • Increase negated value (changes the range to 1.00..0.00) by addition (default addend is +1.00)
  • Sets calculated alpha value on target node using Set Alpha Value
Common Properties
Input Min FeatStd::Optional<FeatStd::Variant>
This minimum value has to be set for input value scaling to take effect.
FeatStd::Float expected.
Input Max FeatStd::Optional<FeatStd::Variant>
This maximum value has to be set for input value scaling to take effect.
Multiplication Value FeatStd::Variant
Multiplies received value by this number (after scaling).
Addition Value FeatStd::Variant
Adds this number to received value (after multiplication).
Target Node Candera::AbstractNodePointer Target node that will have its alpha value set.
Back to the menu
Navigation Path
Registers to navigation points and displays them as mesh in world space.
Common Properties
ColorMode ColorMode::Enum
Select how color is displayed.
Possible values: Color, RGBA
Color
Candera::Color Determines the color of the mesh.
Width
FeatStd::Float Determines the width of the mesh.
Length
FeatStd::Float Determines the length of the mesh
YOffset
FeatStd::Float Applies y-offset to the mesh.
InputPoints
ListPropertyType< CgiStudioControl::Internal::AR::ArPoint> This property is used to bind input points.
InputPointHandling
InputPointHandling::Enum
Determines how new input points are used for the mesh.
Possible values. Attach, Replace
InterpolationType
InterpolationType::Enum
Determines which interpolation method is used.
Possible values: Linear, Bezier, Spline, None
MeshType
MeshType::Enum
Determines which primitive type is used.
Possible values: Solid, Points
IsAdvanced
bool
Enables advanced settings of the behavior.
Advanced Properties
Red
FeatStd::UInt32
Red color channel.
This property is only available if 'ColorMode' is set to 'RGBA'.
Green
FeatStd::UInt32
Green color channel.
Blue
FeatStd::UInt32
Blue color channel.
Alpha
FeatStd::UInt32
Alpha color channel.
InputPointMinDistance
FeatStd::Float
Minimum distance of two control points. Input points that are closer together will be rejected.
This property is only available if 'IsAdvanced' is checked.
ReqFragmentSize
FeatStd::SizeType
Size of the fragment that is requested from the input point list.
ReqThresholdDistance
FeatStd::Float
If the distance between camera and the last point is below this threshold, request a new fregment of input points.
PointSize
FeatStd::Float
Determines the point size.
This property is only available if 'MeshType' is set to 'Points'.
NumOfRowsPerInputPoint
FeatStd::UInt32
Determines how many vertex rows are used to interpolate between two input points. Increasing this value makes the mesh smoother, but will also shorten the distance of the overlay, as number of vertices per row remain constant.
This property is only available if 'IsAdvanced' is checked and 'InterpolationType' is set to 'None'.
NumOfVertexRows
FeatStd::UInt32
Amount of vertical vertices in the mesh.
NumOfVertexColums
FeatStd::UInt32
Amount of horizontal vertices in the mesh.
Back to the menu
Poi Configuration
Behavior that configures the mapping of a name to a assetId, such that it can be found by the PoiFactory.
Common Properties
PoiName FeatStd::UInt32 Name of this poi.
PoiControlAssetId
FeatStd::UInt32 ID of the control that is assosiated with PoiName.
Back to the menu
Poi Manager
Manager of the poi control nodes.
Common Properties
StreetPoints ListPropertyType<CgiStudioControl::Internal::AR::ArPoint> List of points of the street. Used to align the rotation of pois.
StreetPointsMinDistance FeatStd::Float Minimum distance between two street points. Street points that are closer together will be rejected.
ReqDistance FeatStd::Float The distance in which pois are requested from the model.
ReqThresholdDistance FeatStd::Float Once the camera has moved this specified distance a new request will be sent.
PoiMetaData ArrayProperty<FeatStd::String> Use databinding to receive metadata updates for the POIs
Back to the menu
Pose Tracking
Behavior that sets the pose of a target node.
Common Properties
Position Candera::Vector3 Position on the target node.
Rotation Candera::Vector3 Rotation on the target node.
EnableUserControl bool
Enable to use WASD control to navigate the camera instead of databinding.
EventReceivers ArrayProperty<Candera::AbstractNodePointer> List of nodes that will receive position and rotation update events.
Back to the menu
