Mixed Reality Behaviors
Contents List
Internal
Internal
Poi Metadata Handler
Behavior that handles the meta data of a single poi.
Common Properties
| IconNodes | ArrayProperty<Candera::AbstractNodePointer> | A process value event is sent to this nodes, if a respective poi update event arrives. |
| NameNodes |
| OpenNowNodes |
| RatingNodes |
| PriceLevelNodes |
| InfoTextNodes |
Distance Alpha Fading
Distance Alpha Fading is a Behavior Building Block available in Construction Kit.
It receives a value representing the camera position and performs arithmetic operations on it to calculate target node alpha value.
The following operations are performed on input value:
- Map (scale) value from initial range (default 0.00..100.00) to target range (default 0.00..1.00)
- Negate scaled value (changes the range to 0.00..-1.00) by multiplication (default multiplicand is -1.00)
- Increase negated value (changes the range to 1.00..0.00) by addition (default addend is +1.00)
Sets calculated alpha value on target node using Set Alpha Value
Common Properties
| Input Min | FeatStd::Optional<FeatStd::Variant> |
This minimum value has to be set for input value scaling to take effect. FeatStd::Float expected. |
| Input Max | FeatStd::Optional<FeatStd::Variant> |
This maximum value has to be set for input value scaling to take effect. FeatStd::Float expected. |
| Multiplication Value | FeatStd::Variant |
Multiplies received value by this number (after scaling). FeatStd::Float expected. |
| Addition Value | FeatStd::Variant |
Adds this number to received value (after multiplication). FeatStd::Float expected. |
| Target Node | Candera::AbstractNodePointer | Target node that will have its alpha value set. |
Navigation Path
Common Properties
| ColorMode | ColorMode::Enum |
Select how color is displayed. Possible values: Color, RGBA |
| Color |
Candera::Color | Determines the color of the mesh. |
| Width |
FeatStd::Float | Determines the width of the mesh. |
| Length |
FeatStd::Float | Determines the length of the mesh |
| YOffset |
FeatStd::Float | Applies y-offset to the mesh. |
| InputPoints |
ListPropertyType< CgiStudioControl::Internal::AR::ArPoint> | This property is used to bind input points. |
| InputPointHandling |
InputPointHandling::Enum |
Determines how new input points are used for the mesh. Possible values. Attach, Replace |
| InterpolationType |
InterpolationType::Enum |
Determines which interpolation method is used. Possible values: Linear, Bezier, Spline, None |
| MeshType |
MeshType::Enum |
Determines which primitive type is used. Possible values: Solid, Points |
| IsAdvanced |
bool |
Enables advanced settings of the behavior. |
Advanced Properties
| Red |
FeatStd::UInt32 |
Red color channel. This property is only available if 'ColorMode' is set to 'RGBA'. |
| Green |
FeatStd::UInt32 |
Green color channel. This property is only available if 'ColorMode' is set to 'RGBA'. |
| Blue |
FeatStd::UInt32 |
Blue color channel. This property is only available if 'ColorMode' is set to 'RGBA'. |
| Alpha |
FeatStd::UInt32 |
Alpha color channel. This property is only available if 'ColorMode' is set to 'RGBA'. |
| InputPointMinDistance |
FeatStd::Float |
Minimum distance of two control points. Input points that are closer together will be rejected. This property is only available if 'IsAdvanced' is checked. |
| ReqFragmentSize |
FeatStd::SizeType |
Size of the fragment that is requested from the input point list. This property is only available if 'IsAdvanced' is checked. |
| ReqThresholdDistance |
FeatStd::Float |
If the distance between camera and the last point is below this threshold, request a new fregment of input points. This property is only available if 'IsAdvanced' is checked. |
| PointSize |
FeatStd::Float |
Determines the point size. This property is only available if 'MeshType' is set to 'Points'. |
| NumOfRowsPerInputPoint |
FeatStd::UInt32 |
Determines how many vertex rows are used to interpolate between two input points. Increasing this value makes the mesh smoother, but will also shorten the distance of the overlay, as number of vertices per row remain constant. This property is only available if 'IsAdvanced' is checked and 'InterpolationType' is set to 'None'. |
| NumOfVertexRows |
FeatStd::UInt32 |
Amount of vertical vertices in the mesh. This property is only available if 'IsAdvanced' is checked. |
| NumOfVertexColums |
FeatStd::UInt32 |
Amount of horizontal vertices in the mesh. This property is only available if 'IsAdvanced' is checked. |
Poi Configuration
Behavior that configures the mapping of a name to a assetId, such that it can be found by the PoiFactory.
Common Properties
| PoiName | FeatStd::UInt32 | Name of this poi. |
| PoiControlAssetId |
FeatStd::UInt32 | ID of the control that is assosiated with PoiName. |
Poi Manager
Manager of the poi control nodes.
Common Properties
| StreetPoints | ListPropertyType<CgiStudioControl::Internal::AR::ArPoint> | List of points of the street. Used to align the rotation of pois. |
| StreetPointsMinDistance | FeatStd::Float | Minimum distance between two street points. Street points that are closer together will be rejected. |
| ReqDistance | FeatStd::Float | The distance in which pois are requested from the model. |
| ReqThresholdDistance | FeatStd::Float | Once the camera has moved this specified distance a new request will be sent. |
| PoiMetaData | ArrayProperty<FeatStd::String> | Use databinding to receive metadata updates for the POIs |
Pose Tracking
Behavior that sets the pose of a target node.
Common Properties
| Position | Candera::Vector3 | Position on the target node. |
| Rotation | Candera::Vector3 | Rotation on the target node. |
| EnableUserControl | bool |
Enable to use WASD control to navigate the camera instead of databinding. |
| EventReceivers | ArrayProperty<Candera::AbstractNodePointer> | List of nodes that will receive position and rotation update events. |
