Mixed Reality Behaviors
Contents List
Internal
    Poi Metadata Handler
      DistanceAlphaFading Navigation Path Poi Configuration Poi Manager Pose Tracking
      Internal
      Behavior that handles the meta data of a single poi.
      Common Properties
      Property Name Type Description IconNodes ArrayProperty<Candera::AbstractNodePointer> A process value event is sent to this nodes, if a respective poi update event arrives. NameNodes
      ArrayProperty<Candera::AbstractNodePointer> A process value event is sent to this nodes, if a respective poi update event arrives. OpenNowNodes
      ArrayProperty<Candera::AbstractNodePointer> A process value event is sent to this nodes, if a respective poi update event arrives. RatingNodes
      ArrayProperty<Candera::AbstractNodePointer> A process value event is sent to this nodes, if a respective poi update event arrives. PriceLevelNodes
      ArrayProperty<Candera::AbstractNodePointer> A process value event is sent to this nodes, if a respective poi update event arrives. InfoTextNodes
      Back to the menu
      Distance Alpha Fading
      Distance Alpha Fading is a Behavior Building Block available in Construction Kit.
      It receives a value representing the camera position and performs arithmetic operations on it to calculate target node alpha value.
      The following operations are performed on input value:
      • Map (scale) value from initial range (default 0.00..100.00) to target range (default 0.00..1.00)
      • Negate scaled value (changes the range to 0.00..-1.00) by multiplication (default multiplicand is -1.00)
      • Increase negated value (changes the range to 1.00..0.00) by addition (default addend is +1.00)
      • Sets calculated alpha value on target node using Set Alpha Value
      Common Properties
      Input Min FeatStd::Optional<FeatStd::Variant>, FeatStd::Float expected
      This minimum value has to be set for input value scaling to take effect.
      FeatStd::Float expected.
      Input Max FeatStd::Optional<FeatStd::Variant>, FeatStd::Float expected
      This maximum value has to be set for input value scaling to take effect.
      Multiplication Value FeatStd::Variant, FeatStd::Float expected
      Multiplies received value by this number (after scaling).
      Addition Value FeatStd::Variant, FeatStd::Float expected
      Adds this number to received value (after multiplication).
      Target Node Candera::AbstractNodePointer Target node that will have its alpha value set.
      Back to the menu
      Navigation Path
      Registers to navigation points and displays them as mesh in world space.
      Common Properties
      Property Name Type Description ColorMode ColorMode::Enum
      Select how color is displayed.
      Possible values: Color, RGBA
      Color
      Candera::Color Determines the color of the mesh.
      Width
      FeatStd::Float Determines the width of the mesh. Length
      FeatStd::Float Determines the length of the mesh YOffset
      FeatStd::Float Applies y-offset to the mesh. InputPoints
      ListPropertyType< CgiStudioControl::Internal::AR::ArPoint> This property is used to bind input points. InputPointHandling
      InputPointHandling::Enum
      Determines how new input points are used for the mesh.
      Possible values. Attach, Replace
      InterpolationType
      InterpolationType::Enum
      Determines which interpolation method is used.
      Possible values: Linear, Bezier, Spline, None
      MeshType
      MeshType::Enum
      Determines which primitive type is used.
      Possible values: Solid, Points
      IsAdvanced
      bool
      Enables advanced settings of the behavior.
      Advanced Properties
      Property Name Type Description Red
      FeatStd::UInt32
      Red color channel.
      This property is only available if 'ColorMode' is set to 'RGBA'.
      Green
      FeatStd::UInt32
      Green color channel.
      Blue
      FeatStd::UInt32
      Blue color channel.
      Alpha
      FeatStd::UInt32
      Alpha color channel.
      InputPointMinDistance
      FeatStd::Float
      Minimum distance of two control points. Input points that are closer together will be rejected.
      This property is only available if 'IsAdvanced' is checked.
      ReqFragmentSize
      FeatStd::SizeType
      Size of the fragment that is requested from the input point list.
      ReqThresholdDistance
      FeatStd::Float
      If the distance between camera and the last point is below this threshold, request a new fregment of input points.
      PointSize
      FeatStd::Float
      Determines the point size.
      This property is only available if 'MeshType' is set to 'Points'.
      NumOfRowsPerInputPoint
      FeatStd::UInt32
      Determines how many vertex rows are used to interpolate between two input points. Increasing this value makes the mesh smoother, but will also shorten the distance of the overlay, as number of vertices per row remain constant.
      This property is only available if 'IsAdvanced' is checked and 'InterpolationType' is set to 'None'.
      NumOfVertexRows
      FeatStd::UInt32
      Amount of vertical vertices in the mesh.
      NumOfVertexColums
      FeatStd::UInt32
      Amount of horizontal vertices in the mesh.
      Back to the menu
      Poi Configuration
      Behavior that configures the mapping of a name to a assetId, such that it can be found by the PoiFactory.
      Common Properties
      Property Name Type Description PoiName FeatStd::UInt32 Name of this poi. PoiControlAssetId
      FeatStd::UInt32 ID of the control that is assosiated with PoiName.
      Back to the menu
      Poi Manager
      Manager of the poi control nodes.
      Common Properties
      Property Name Type Description StreetPoints ListPropertyType<CgiStudioControl::Internal::AR::ArPoint> List of points of the street. Used to align the rotation of pois. StreetPointsMinDistance FeatStd::Float Minimum distance between two street points. Street points that are closer together will be rejected. ReqDistance FeatStd::Float The distance in which pois are requested from the model. ReqThresholdDistance FeatStd::Float Once the camera has moved this specified distance a new request will be sent. PoiMetaData ArrayProperty<FeatStd::String> Use databinding to receive metadata updates for the POIs
      Back to the menu
      Pose Tracking
      Behavior that sets the pose of a target node.
      Common Properties
      Property Name Type Description Position Candera::Vector3 Position on the target node. Rotation Candera::Vector3 Rotation on the target node. EnableUserControl bool
      Enable to use WASD control to navigate the camera instead of databinding. EventReceivers ArrayProperty<Candera::AbstractNodePointer> List of nodes that will receive position and rotation update events.
      Back to the menu
