Mixed Reality Behaviors
Distance Alpha Fading
Distance Alpha Fading is a Behavior Building Block available in Construction Kit.
It receives a value representing the camera position and performs arithmetic operations on it to calculate target node alpha value.
The following operations are performed on input value:
  • Map (scale) value from initial range (default 0.00..100.00) to target range (default 0.00..1.00)
  • Negate scaled value (changes the range to 0.00..-1.00) by multiplication (default multiplicand is -1.00)
  • Increase negated value (changes the range to 1.00..0.00) by addition (default addend is +1.00)
  • Sets calculated alpha value on target node using Set Alpha Value
Common Properties
Input Min FeatStd::Optional<FeatStd::Variant>, FeatStd::Float expected This minimum value has to be set for input value scaling to take effect.
Input Max FeatStd::Optional<FeatStd::Variant>, FeatStd::Float expected This maximum value has to be set for input value scaling to take effect.
Multiplication Value FeatStd::Variant, FeatStd::Float expected Multiplies received value by this number (after scaling).
Addition Value FeatStd::Variant, FeatStd::Float expected Adds this number to received value (after multiplication).
Target Node Candera::AbstractNodePointer Target node that will have its alpha value set.
Back to the menu
