Mixed Reality Behaviors
Content List
Mixed Reality Internal Behaviors > Poi Metadata Handler
Behavior attached to a poi control template to handle the meta data (i.e. the actual look of the poi) at runtime. The metadata is represented by a JSON string and sent from the PoiManager control. (see also Poi Manager 3D).
The message itself (a JSON string) is parsed by the Poi Manager. The model can directly sent the metadata via the dedicated binding source.
Each JSON message consists of two objects: A receiver, and the actual metadata.
The Poi Manager receives the JSON message (or a list of messages) via data binding and forwards it to the respective POI (taken from the “receiver” object in the message)
However, also in the PoiData structure is space for a metadata string. The latter is used for initialization of the POI, when it is first requested. Using metadata updates could also be used to track the position of POIs, if they were moving.
Within the metadata JSON object the currently supported objects are:
Identifier
Type
JSON example
name
string
{ “name”: “Main Street” }
icon
string
{ “icon”: “Hotel” }
open_now
bool
{ “open_now”: true }
rating
double [0;5]
{ “rating”: 3.1 }
price_level
double [0;3]
{ “price_level”: 2.6 }
info_text
string
{ “info_text”: “whatever” }
This can be arbitrarily extended by a custom PoiManager behavior.
Common Properties
Property Name
Type
IconNodes
FeatStd::IconNodeTypes
A process value event is sent to this nodes, if a respective poi update event arrives.
NameNodes
NameNodesType
OpenNowNodes
OpenNowNodesType
A process value event is sent to this nodes, if a respective poi update eventarrives.
RatingNodes
RatingNodesType
PriceLevelNodes
PriceLevelNodesType
InfoTextNodes
InfoTextNodesType
Back to the menu
Distance Alpha Fading
Distance Alpha Fading is a Behavior Building Block available in Construction Kit.
It receives a value representing the camera position and performs arithmetic operations on it to calculate target node alpha value.
The following operations are performed on input value:
Common Properties
| Property Name |
Type |
Description |
| Input Min |
FeatStd::Optional<FeatStd::Variant>, FeatStd::Float expected |
This minimum value has to be set for input value scaling to take effect. |
| Input Max |
This maximum value has to be set for input value scaling to take effect. |
| Multiplication Value |
FeatStd::Variant, FeatStd::Float expected |
Multiplies received value by this number (after scaling). |
| Addition Value |
Adds this number to received value (after multiplication). |
| Target Node |
Candera::AbstractNodePointer |
Target node that will have its alpha value set. |
Back to the menu
Navigation Path
Class Reference
Registers to navigation points and displays them as mesh in world space.
Common Properties
Property Name
Type
ColorMode
ColorMode::Enum
Select how color is displayed
Color
Candera::Color
Determines the color of the mesh.
Width
FeatStd::Float
Determines the width of the mesh.
Length
FeatStd::Float
Determines the length of the mesh.
YOffset
FeatStd::Float
Applies y-offset to the mesh.
InputPoints
CgiStudioControl::Internal::AR::ArPoint
This property is used to bind input points.
InputPointMinDistance
FeatStd::Float
Minimum distance of two control points. Input points that are closer together will be rejected.
InputPointHandling
InputPointHandling::Enum
Determines how new input points are used for the mesh.
ReqFragmentSize
FeatStd::SizeType
Size of the fragment that is requested from the input point list.
ReqThresholdDistance
FeatStd::Float
If the distance between camera and the last point is below this threshold, request a new fregment of input points.
InterpolationType
InterpolationType::Enum
Determines which interpolation method is used.
MeshType
MeshType::Enum
Determines which primitive type is used.
PointSize
FeatStd::Float
Determines the point size.
NumOfRowsPerInputPoint
FeatStd::SizeType
Determines how many vertex rows are used to interpolate between two input points. Increasing this value makes the mesh smoother, but will also shorten the distance of the overlay, as number of vertices per row remain constant.
NumOfVertexRows
FeatStd::SizeType
Amount of vertical vertices in the mesh.
NumOfVertexColums
FeatStd::SizeType
Amount of horizontal vertices in the mesh.
IsAdvanced
bool
Enables advanced settings of the behavior.
Back to the menu
Poi Configuration
Class Reference
Behavior that configures the mapping of a name to a assetId, such that it can be found by the PoiFactory.
Common Properties
Property Name
Type
PoiName
FeatStd::String
Name of this poi
PoiControlAssetId
Candera::Id
ID of the control that is assosiated with PoiName.
Back to the menu
Poi Manager
Class Reference
Manager of the poi control nodes.
Common Properties
Property Name
Type
StreetPoints
List of points of the street. Used to align the rotation of pois.
StreetPointsMinDistance
FeatStd::Float
Minimum distance between two street points. Street points that are closer together will be rejected.
ReqDistance
FeatStd::Float
The distance in which pois are requested from the model.
FeatStd::Float
Once the camera has moved this specified distance a new request will be sent.
PoiMetaData
Candera::ArrayProperty<FeatStd::String>
Use databinding to receive metadata updates for the POIs
Back to the menu
Pose Tracking
Class Reference
The behavior receives rotation and position updates via data binding and apply these values directly to its own position and rotation.
Common Properties
Property Name
Type
TargetNode
On this node the pose update will be applied. If nothing is specified the current node will be used as target.
Position
Candera::Vector3
Position on the target node.
Rotation
Candera::Vector3
Rotation on the target node.
EnableUserControl
bool
Enable to use WASD control to navigate the camera instead of databinding.
EventReceivers
Candera::ArrayProperty<Candera::AbstractNodePointer>
List of nodes that will receive position and rotation update events
