Mixed Reality Behaviors
Content List
  • Mixed Reality Internal Behaviors > Poi Metadata Handler
  • Distance Alpha Fading
  • Navigation Path
  • Poi Configuration
  • Poi Manager
  • Pose Tracking
Behavior attached to a poi control template to handle the meta data (i.e. the actual look of the poi) at runtime. The metadata is represented by a JSON string and sent from the PoiManager control. (see also Poi Manager 3D).
Metadata (as JSON message)
  • The message itself (a JSON string) is parsed by the Poi Manager. The model can directly sent the metadata via the dedicated binding source.
  • Each JSON message consists of two objects: A receiver, and the actual metadata.
  • The Poi Manager receives the JSON message (or a list of messages) via data binding and forwards it to the respective POI (taken from the “receiver” object in the message)
  • However, also in the PoiData structure is space for a metadata string. The latter is used for initialization of the POI, when it is first requested. Using metadata updates could also be used to track the position of POIs, if they were moving.
Within the metadata JSON object the currently supported objects are:
Identifier Type JSON example
name string { “name”: “Main Street” }
icon string { “icon”: “Hotel” }
open_now bool { “open_now”: true }
rating double [0;5] { “rating”: 3.1 }
price_level double [0;3] { “price_level”: 2.6 }
info_text string { “info_text”: “whatever” }
This can be arbitrarily extended by a custom PoiManager behavior.
Common Properties
IconNodes FeatStd::IconNodeTypes A process value event is sent to this nodes, if a respective poi update event arrives.
NameNodes NameNodesType A process value event is sent to this nodes, if a respective poi update event arrives.
OpenNowNodes OpenNowNodesType A process value event is sent to this nodes, if a respective poi update eventarrives.
RatingNodes RatingNodesType A process value event is sent to this nodes, if a respective poi update eventarrives.
PriceLevelNodes PriceLevelNodesType A process value event is sent to this nodes, if a respective poi update event arrives.
InfoTextNodes InfoTextNodesType A process value event is sent to this nodes, if a respective poi update event arrives.
Distance Alpha Fading is a Behavior Building Block available in Construction Kit.
It receives a value representing the camera position and performs arithmetic operations on it to calculate target node alpha value.
The following operations are performed on input value:
  • Map (scale) value from initial range (default 0.00..100.00) to target range (default 0.00..1.00)
  • Negate scaled value (changes the range to 0.00..-1.00) by multiplication (default multiplicand is -1.00)
  • Increase negated value (changes the range to 1.00..0.00) by addition (default addend is +1.00)
  • Sets calculated alpha value on target node using Set Alpha Value
Common Properties
Input Min FeatStd::Optional<FeatStd::Variant>, FeatStd::Float expected This minimum value has to be set for input value scaling to take effect.
Input Max FeatStd::Optional<FeatStd::Variant>, FeatStd::Float expected This maximum value has to be set for input value scaling to take effect.
Multiplication Value FeatStd::Variant, FeatStd::Float expected Multiplies received value by this number (after scaling).
Addition Value FeatStd::Variant, FeatStd::Float expected Adds this number to received value (after multiplication).
Target Node Candera::AbstractNodePointer Target node that will have its alpha value set.
Navigation Path
Class Reference
Registers to navigation points and displays them as mesh in world space.
Common Properties
ColorMode ColorMode::Enum Select how color is displayed
Color Candera::Color Determines the color of the mesh.
Width FeatStd::Float Determines the width of the mesh.
Length FeatStd::Float Determines the length of the mesh.
YOffset FeatStd::Float Applies y-offset to the mesh.
InputPoints CgiStudioControl::Internal::AR::ArPoint This property is used to bind input points.
InputPointMinDistance FeatStd::Float Minimum distance of two control points. Input points that are closer together will be rejected.
InputPointHandling InputPointHandling::Enum Determines how new input points are used for the mesh.
ReqFragmentSize FeatStd::SizeType Size of the fragment that is requested from the input point list.
ReqThresholdDistance FeatStd::Float If the distance between camera and the last point is below this threshold, request a new fregment of input points.
InterpolationType InterpolationType::Enum Determines which interpolation method is used.
MeshType MeshType::Enum Determines which primitive type is used.
PointSize FeatStd::Float Determines the point size.
NumOfRowsPerInputPoint FeatStd::SizeType Determines how many vertex rows are used to interpolate between two input points. Increasing this value makes the mesh smoother, but will also shorten the distance of the overlay, as number of vertices per row remain constant.
NumOfVertexRows FeatStd::SizeType Amount of vertical vertices in the mesh.
NumOfVertexColums FeatStd::SizeType Amount of horizontal vertices in the mesh.
IsAdvanced bool Enables advanced settings of the behavior.
Poi Configuration
Class Reference
Behavior that configures the mapping of a name to a assetId, such that it can be found by the PoiFactory.
Common Properties
PoiName FeatStd::String Name of this poi
PoiControlAssetId Candera::Id ID of the control that is assosiated with PoiName.
Poi Manager
Class Reference
Manager of the poi control nodes.
Common Properties
StreetPoints CgiStudioControl::Internal::AR::ArPoint List of points of the street. Used to align the rotation of pois.
StreetPointsMinDistance FeatStd::Float Minimum distance between two street points. Street points that are closer together will be rejected.
ReqDistance FeatStd::Float The distance in which pois are requested from the model.
ReqThresholdDistance FeatStd::Float Once the camera has moved this specified distance a new request will be sent.
PoiMetaData Candera::ArrayProperty<FeatStd::String> Use databinding to receive metadata updates for the POIs
Pose Tracking
Class Reference
The behavior receives rotation and position updates via data binding and apply these values directly to its own position and rotation.
Common Properties
TargetNode Candera::AbstractNodePointer On this node the pose update will be applied. If nothing is specified the current node will be used as target.
Position Candera::Vector3 Position on the target node.
Rotation Candera::Vector3 Rotation on the target node.
EnableUserControl bool Enable to use WASD control to navigate the camera instead of databinding.
EventReceivers Candera::ArrayProperty<Candera::AbstractNodePointer> List of nodes that will receive position and rotation update events
Back to the menu
