Control Behaviors
Content List
- Map
- Circular Slider Behavior
- Drawer Behavior
- Map
- Internal Control Behaviors
- Align Pivot
- Android Event Bridge
- Arc Align
- Blend Mode
- Breadcrumb Behavior
- Disable Control
- Enable Control
- Event Bridge
- Focus
- Focus Leave
- Hover
- HoverLeave
- IntervalSwitch
- Keyboard Behavior
- Menu Item
- MenuScreen
- Navigation Instruction View
- OnClick
- OnPressed
- OnTimer
- Orbit Camera Transform
- Page Indicator
- Rectangle Clipping Behavior
- Roll
- Touch Indication Behavior
- Transform Mesh2D
- Event Handler
- Virtual Key
Map MapControl Behaviors
Map
Common Properties
| TouchableId |
Touchable Id of the behavior. Bearing
Map Bridge
Common Properties
String
Touchable Id of the behavior. TargetNode
List Behavior
Common Properties
| TouchableId |
Touchable Id of the behavior. ScrollDirection ScrollDirection::Enum
The direction in which the ListBehavior scrolls.
Position FeatStd::Float The pixel position of the visible content within the list content. AnimationDuration FeatStd::UInt32 Duration of the scrolling animation. DecelerationFactor FeatStd::Float Loss of flick animation speed over time. MaxSpeedPerFlick FeatStd::Float Maximum amount of speed each flick motion adds to the flick animation. MinSpeedPerFlick FeatStd::Float Minimum speed required to count a touch gesture as a flick and start or continue the flick animation. MinMovementToScrolling FeatStd::UInt32 Minimum distance a touch gesture needs to move to start a scrolling animation. MaxTouchSampleAge FeatStd::UInt32 Maximum age in miliseconds of touch movement speed counted towards generating flick animation speed. Items ListPropertyType<DataContextItem::SharedPointer>The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required. ListFragmentTriggerOffset FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This trigger offset value defines an area at the begin and end of the list fragment. Whenever the list shows a part of these areas a new fragment is requested from the model. ListFragmentSize FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This buffer size defines how large this fragment should be. By default it is set to 0 which results in an automatic calculation. The automatic calculation assumes the number of item nodes is configured to match the maximum number of visible nodes for one page. By multiplying this number by three and adding the trigger offset one time for the begin and one additional time for the end to calculate for the automatic buffer size the list has a spare page on each side before a new fragment has to be requested HandleKeyboardEvents
bool
Makes the behavior handle KeyboardFocusNavigation events internally. WrapAround
bool
Set this flag to true for static list to wrap around the list items on the top and bottom of the list
Scrollbar
Common Properties
- 1 child: marker
Common Properties
String
Touchable Id of the behavior. TouchListenerNode Candera::AbstractNodePointer This node defines the area on which the ScrollbarBehavior will listen for the touch events. ScrollDirection FeatStd::Optional< ScrollDirection::Enum > The direction in which the ListBehavior scrolls. By default it is configured as a vertical scrollbar. ScrollbarVisibility ScrollbarVisibility::Enum
Configure the visibility of the scrollbar. By default it is set to Automatic which will determine the visibility based on the actual content.
Possible values: Automatic, Collapsed, Visible
HandleMinimumSize FeatStd::UInt32 The minimum height (for vertical scrollbar) or minimum width (for horizontal scrollbar) of the handle in pixels. MinMovementToScrolling FeatStd::UInt32 Minimum distance a touch gesture needs to move to start scrolling. ScrollableNodeCandera::AbstractNodePointer Node of the scrollable behavior.
Scroll View
Example Usage
Common Properties
Snap List Item Configuration
Information on how to use this behavior can be found in the chaper of the List Control.Control.
Common Properties
| ItemAlignment | SnapAlignmentOrientation::Enum |
The location of the alignment base point within the list item. Possible values: Begin, Center, End |
| ItemAlignmentOffset | FeatStd::Float |
The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ItemAlignmentOffsetInPercent | bool |
The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
Snap List Item Extension
Common Properties
| ListBehavior | ListBehavior* |
The ListBehavior that shall be extended. This property can be set in the right side of the Scene Tree Panel. |
| ListAlignment | SnapAlignmentOrientation::Enum |
| ListAlignmentOffset | FeatStd::Float | The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ListAlignmentOffsetInPercent | bool | The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
| ItemAlignment | SnapAlignmentOrientation::Enum | The location of the alignment base point within the list item.
| ItemAlignmentOffset | FeatStd::Float | The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ItemAlignmentOffsetInPercent | bool | The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
SubList Behavior
Common Properties
String
The direction in which the SubListBehavior scrolls.
Position FeatStd::Float The pixel position of the visible content within the list content. AnimationDuration FeatStd::UInt32 Duration of the scrolling animation. DecelerationFactor FeatStd::Float Loss of flick animation speed over time. MaxSpeedPerFlick FeatStd::Float Maximum amount of speed each flick motion adds to the flick animation. MinSpeedPerFlick FeatStd::Float Minimum speed required to count a touch gesture as a flick and start or continue the flick animation. MinMovementToScrolling FeatStd::UInt32 Minimum distance a touch gesture needs to move to start a scrolling animation. MaxTouchSampleAge FeatStd::UInt32 Maximum age inListPropertyType< ::Courier::DataContextItem::SharedPointer > The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required. ListFragmentTriggerOffset FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This trigger offset value defines an area at the begin and end of the list fragment. Whenever the list shows a part of these areas a new fragment is requested from the model. ListFragmentSize FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This buffer size defines how large this fragment should be. By default it is set to 0 which results in an automatic calculation. The automatic calculation assumes the number of item nodes is configured to match the maximum number of visible nodes for one page. By multiplying this number by three and adding the trigger offset one time for the begin and one additional time for the end to calculate for the automatic buffer size the list has a spare page on each side before a new fragment has to be requested HandleKeyboardEvents
bool
Makes the behavior handle KeyboardFocusNavigation events internally. ParentListNode
Candera::AbstractNodePointer The node with a ListBehavior that acts as a parent to this SubListBehavior.
Common Properties
Value FeatStd::Variant Value of the slider MinimumValue FeatStd::Variant Minimum value of the slider MaximumValue FeatStd::Variant Maximum value of the slider StepSize FeatStd::Variant Step size for Value MinimumAngle FeatStd::Float Angle of the slider, corresponding to minimum value. MaximumAngle FeatStd::Float Angle of the slider, corresponding to maximum value. ThumbNode Candera::AbstractNodePointer Thumb node which will be rotated. ImageNode Candera::AbstractNodePointer Image node which will be masked.Drawer Behavior
DescriptionThe Drawer is a Layouting Behavior that can hide or show its content via Events or Touch Inputs. This will only work if the Node has a Group called 'Content' as Child. To support Touch Inputs there needs to be a Node called 'Knob' as Child.
CommonThis Propertiesbehavior is available for 2D scenes only.
Common Properties
Open bool Shows the Drawer in its opened appearance. AppearDirection AppearDirection::EnumThe direction from which the Drawer will open.
Possible values: Top, Left, Right, Bottom
DragEnabled bool Set to true to allow the Drawer to be controlled by Touch Inputs.Linear Slider Behavior
Common Properties
KnobNodeCandera::AbstractNodePointer Knob node which will be shifted. SliderBarNode Candera::AbstractNodePointer Image node which will be scaled according to value. BackgroundNode Candera::AbstractNodePointer Image node which will provide background image and also control slider total size.
Caret
Common Properties
| Receivers |
CaretNode Candera::AbstractNodePointer Node which will be set as caret.The Caret Behavior will change the state of the given IntervalSwitch Behavior.
Handle Control State
Example Usage
Common Properties
bool
If true, the controls state Selected is set to true. Focusable bool If true, the control is focusable. Otherwise the control can not be focused. Identifier Candera::AbstractNodePointer Identifier which is used when emitting an Event (e.g. Click Event).
DataContext
Common Properties
Edit Text
Common Properties
InputText FeatStd::String Text which will be set as default text. TextNode Candera::AbstractNodePointer Text Node which will be edited. Placeholder Candera::AbstractNodePointer Text which will be shown as placeholder. SetValueOnEachChange bool If true, the value will be set on each input. MaxTextLength FeatStd::UInt16 Maximum count of characters. JustDigits bool If true, the Inputfield will receive just digits.Selection Group
Common Properties
Provide Alignment
Common Properties
| HorizontalAlignment | Candera::HorizontalAlignment |
Provides property to set the Horizontal Alignment (especially for Controls). Possible values: HLeft, HCenter, HRight, HStretch |
| VerticalAlignment | Candera::VerticalAlignment |
Provides property to set the Vertical Alignment (especially for Controls). Possible values: VTop, VCenter, VBottom, VStretch |
Copy Size
Common Properties
Provide Color
Common Properties
| Color | Candera::Color |
The color to set. This property is only available if the PropertyReference is set to "Self". |
Advanced Properties
| PropertyProvider | Behavior* |
Property Behavior which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree Panel. This property is only available if PropertyReference is set to "Other". |
Provide Margin
Common Properties
Property Provider
Common Properties
| PropertyDataType | CgiStudioControl::PropertyDataTypes::Enum |
Choose the type which Possible values: Color, Text, Style, Image, Appearance, Value, BlendType, Layout |
Advanced Properties
The color which can be used from other Behaviors. This property is only available if PropertyDataType is set to "Color". |
| Text | FeatStd::String |
The Text that will be set to the Text Node. This property is only available if PropertyDataType is set to "Text". |
SharedPointer<Candera::TextRendering::SharedStyle>
This property is only available if PropertyDataType is set to "Style".
ImageThe image to set on the effect.
This property is only available for 2D scenes if PropertyDataType is set to "Image".
TextureThe texture to set on the effect.
This property is only available for 3D scenes if PropertyDataType is set to "Image".
AppearanceThe appearance to set on the node.
This property is only available for 3D scenes if PropertyDataType is set to "Appearance".
Value FeatStd::VariantThe value that will be set to the Send Value as Event action.
This property is only available if PropertyDataType is set to "Value".
BlendTypeBlendType::Enum
The blend type that will be set.
Possible values: Default, DefaultPremultiplied, DefaultTransparentLayer, Add, Multiply, Screen, Darken, Lighten, SourceAtop, SourceIn, SourceOut, SourceOver, DestinationIn, DestinationOut, DestinationOver, Off.
This property is only available if PropertyDataType is set to "BlendType".
Layout CgiStudioControl::LayoutType::EnumThe layouter type for node. See Set Layout for more information.
Possible values: Horizontal, Vertical
This property is only available for 2D scenes if PropertyDataType is set to "Layout".
StackArrangementStackLayouter::Arrangement
Selects arrangement for stack layouter.
This property is only available for 2D scenes if PropertyDataType is set to "Layout" and the property Layout is set to "Stack".
Render Node
Common Properties
Provide ImageAppearance
Common Properties
AppearanceThis property is only available if "PropertyReference" is set to "Self". PropertyProvider Behavior*
This property is only available if "PropertyReference" is set to "Other".
Provide Image
Example Usage
Common Properties
Advanced setProperties
Image SharedPointer<Candera::Image2D>The image to set on the effect.
This property is only available for 2D scenes if "PropertyReference" is set to "Self".
Texture SharedPointer<Candera::TextureImage>The image to set on the appearance.
This property is only available for 3D scenes if "PropertyReference" is set to "Self".
Set Layout
Limitations
Common Properties
| Layout | CgiStudioControl::LayoutType::Enum |
Selects Possible values: None, Overlay, Stack, Baseline. |
This property StackArrangementis Candera::StackLayouter::Arrangementonly Selectsavailable arrangementif for"PropertyReference" stackis layouter.set to "Self".
PropertyReference
Advanced Properties
This property is only available if Layout is set to "Stack".
PropertyProvider Behavior*Property Behavior which contains the layout which has to be set on the effect. See Property Provider for more information.
This property is only available if "PropertyReference"" is set to "Other".
Limitations
Provide Text
Example Usage
Common Properties
Possible values: Auto, Left, Center, Right.
Multiline boolIf multi line is disabled then the new line control characters will be ignored and text will always be rendered in one line.
Defines the distance between the baselines of successive lines of text.
If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines.
Possible values: None, Ellipsis, CustomText.
Advanced Properties
TrimmingText FeatStd::StringTrimming text defines the text which replaces content overflowing the content area.
This property is only available if "Trimming" is set to "CustomText".
Align Pivot
Example Usage
Common Properties
Common Properties
Arc Align
Example Usage
Common Properties
Blend Mode
- Lighten
- Darken
Common Properties
| Blend Mode | BlendType::Enum | Sets a blend mode from a given list of options. |
Breadcrumb Behavior
Common Properties
Disable Control
Enable Control
Event Bridge
Common Properties
Focus
Focus Leave
Hover
See also
Example Usage
HoverLeave
Example Usage
IntervalSwitch
Common Properties
| State | IntervalSwitchState::Enum | If set to On, sends only On value to Trigger Behaviors in the same node. If set to Off, sends only Off value to Trigger Behaviors in the same node. If set to Blinking, alternates between sending On or Off values. Use On Time Ms and Off Time Ms to specify the speed of blinking. |
| OnTimeMs | FeatStd::UInt32 | If State is set to Blinking, IntervalSwitchBehavior will be sending On value for On Time Ms miliseconds before switching to sending Off value. |
| OffTimeMs | FeatStd::UInt32 | If State is set to Blinking, IntervalSwitchBehavior will be sending Off value for Off Time Ms miliseconds before switching to sending On value. |
Keyboard Behavior
Common Properties
| KeyBackContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of KEY_BACK special key |
| KeyBackText | FeatStd::String | KEY_BACK is labeled with the text (enabled with appropriate content type set to text) |
| KeyBackImage | SharedPointer<Candera::Image2D> | KEY_BACK is labeled with the image (enabled with appropriate content type set to image) |
| KeyEnterContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of KEY_ENTER special key |
| KeyEnterText | FeatStd::String | KEY_ENTER is labeled with the text (enabled with appropriate content type set to text) |
| KeyEnterImage | SharedPointer<Candera::Image2D> | KEY_ENTER is labeled with the image (enabled with appropriate content type set to image) |
| KeySpaceContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of KEY_SPACE special key |
| KeySpaceText | FeatStd::String | KEY_SPACE is labeled with the text (enabled with appropriate content type set to text) |
| KeySpaceImage | SharedPointer<Candera::Image2D> | KEY_SPACE is labeled with the image (enabled with appropriate content type set to image) |
| KeySwitchText | FeatStd::String | SWITCH is labeled with the text (enabled with appropriate content type set to text) |
| KeySwitchImage | SharedPointer<Candera::Image2D> | SWITCH is labeled with the image (enabled with appropriate content type set to image) |
| KeyShiftText | FeatStd::String | SHIFT is labeled with the text (enabled with appropriate content type set to text) |
| KeyShiftImage | SharedPointer<Candera::Image2D> | SHIFT is labeled with the image (enabled with appropriate content type set to image) |
| KeyCloseContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of CLOSE special key |
| KeyCloseText | FeatStd::String | CLOSE is labeled with the text (enabled with appropriate content type set to text) |
| KeyCloseImage | SharedPointer<Candera::Image2D> | CLOSE is labeled with the image (enabled with appropriate content type set to image) |
Configuration String
| Key String | Meaning |
Menu Item
Common Properties
| FocusImageOnSelection | Candera::MemoryManagement::SharedPointer<Candera::Image2D> | The image to set on the effect. |
| FocusImageOnDragging | Candera::MemoryManagement::SharedPointer<Candera::Image2D> | The image to set on the effect. |
| Blend Type | CgiStudioControl::BlendType::Enum | Sets the blend option. |
MenuScreen
Common Properties
| Action | MenuScreenAction::Enum | Action that will be called on the menu screen. |
Common Properties
| SignDisplayNode | SignDisplayNodeType | Node used to display the graphical sign. |
| PrimaryTextNode | PrimaryTextNodeType | Node used to display the primary message. |
| SecondaryTextNode | SecondaryTextNodeType | Node used to display the secondary message. |
| ManeuverTypeTextNode | ManeuverTypeTextNodeType | Node used to display the maneuver type (as text). |
OnClick
- Note:
Example Usage
OnPressed
Example Usage
OnTimer
See also
Example Usage
Common Properties
Page Indicator
Common Properties
| DecrementKeyCode | Candera::KeyboardKeyCode::Enum | Key used for decrementing value (if value is actually decremented, focus handling is suspended) |
| IncrementKeyCode | Candera::KeyboardKeyCode::Enum | Key used for incrementing value (if value is actually incremented, focus handling is suspended) |
Common Properties
| Width | WidthType | Width of the clipping rectangle. |
| Height | HeightType | Height of the clipping rectangle. |
| ClipPositionEnabled | ClipPositionEnabledType | Enable Clipping Position. |
Roll
Common Properties
Advanced Properties
| LensGroup | Candera::AbstractNodePointer | Node containing current value |
| DecorationGroup | Candera::AbstractNodePointer | Node containing lens decoration |
| Format | FeatStd::String | Value display format (use f for value) |
| Step | FeatStd::Float | Value step (positive float) |
| AllowDraggingPastLimit | bool | Allow temporary over-dragging (dragging to blank values before first and after last entry) |
| EditKeyCode | Candera::KeyboardKeyCode::Key_Enter | Key used for entering text edit mode |
Common Properties
| Camera | The camera used to render the touch indicator. Will be used to correctly match touch position with object position in case the camera has a position offset. | |
| DistanceFromCamera | FeatStd::Float | How far from the camera should the touch indication node be rendered. |
Transform Mesh2D
Common Properties
Event Handler
Example Usage
Common Properties
Virtual Key
Common Properties
| Modifier | Candera::KeyModifierEnum::Enum | Modifier Key (e.g. Shift) |
| KeyCode | Candera::KeyboardKeyCode::Enum | With KeyCode you can select any key. |
