Control Behaviors
Content List
- Map
- Circular Slider Behavior
- Drawer Behavior
- Map
- Internal Control Behaviors
- Align Pivot
- Android Event Bridge
- Arc Align
- Blend Mode
- Breadcrumb Behavior
- Disable Control
- Enable Control
- Event Bridge
- Focus
- Focus Leave
- Hover
- HoverLeave
- IntervalSwitch
- Keyboard Behavior
- Menu Item
- MenuScreen
- Navigation Instruction View
- OnClick
- OnPressed
- OnTimer
- Orbit Camera Transform
- Page Indicator
- Rectangle Clipping Behavior
- Roll
- Touch Indication Behavior
- Transform Mesh2D
- Event Handler
- Virtual Key
Construction Kit Control Behaviors > Map
Map
| Bearing | BearingType | Clockwise angle relative to North that the users currently faces. |
| Longitude | LongitudeType | Longitude of current users location. |
| Latitude | LatitudeType | Latitude of current users location. |
| SimulateDriving | SimulateDrivingType | Simulate driving along computed route when in navigation mode. |
| NaviMessageNode | NaviMessagesNodeType | Node to which navigation instructions will be sent. |
| LocationMesh | LocationMeshType | Node containing mesh(es) used to render the location indicator. |
| RouteOverlayColor | RouteOverlayColorType | Color used by the route overlay. |
| AvoidTolls | AvoidTollsType | Avoid tolls during route computation. |
| AvoidMotorways | AvoidMotorwaysType | Avoid motorways during route computation. |
| AvoidFerry | AvoidFerryType | Avoid ferrys during route computation. |
Map Bridge
| TargetNode | TargetNodeType | Node containing the target MapBehavior to which events will be forwarded. |
List Behavior
Common Properties
| ScrollDirection | ScrollDirection::Enum | The direction in which the ListBehavior scrolls. |
| Items | The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required. | |
Scrollbar
Common Properties
| ScrollbarVisibility | ScrollbarVisibility::Enum | Configure the visibility of the scrollbar. By default it is set to Automatic which will determine the visibility based on the actual content. |
Scroll View
Example Usage
Common Properties
Snap List Item Configuration
Common Properties
| ItemAlignment | SnapAlignmentOrientation::Enum | The location of the alignment base point within the list item. |
| ItemAlignmentOffset | FeatStd::Float | The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ItemAlignmentOffsetInPercent | bool | The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
Snap List Item Extension
Common Properties
| ListBehavior | ListBehavior* | The ListBehavior that shall be extended. |
| ListAlignment | SnapAlignmentOrientation::Enum | The location of the alignment base point within the list item. |
| ListAlignmentOffset | FeatStd::Float | The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ListAlignmentOffsetInPercent | bool | The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
SubList Behavior
Common Properties
| ScrollDirection | ScrollDirection::Enum | The direction in which the SubListBehavior scrolls. |
This behavior provides the functionality of CircularSlider control by creating a radial mask and setting a rotation of knob node.
Common Properties
Drawer Behavior
Common Properties
| AppearDirection | AppearDirection::Enum | The direction from which the Drawer will open. |
Caret
Common Properties
| CaretNode | Candera::AbstractNodePointer | Node which will be set as caret." type=" |
| IntervalSwitchBehavior | Candera::Behavior* | The Caret Behavior will change the state of the given IntervalSwitch Behavior. |
Handle Control State
Example Usage
Common Properties
DataContext
Common Properties
Edit Text
Common Properties
Selection Group
Common Properties
Provide Alignment
Common Properties
| HorizontalAlignment | Candera::HorizontalAlignment | Provides property to set the Horizontal Alignment (especially for Controls). |
| VerticalAlignment | Candera::VerticalAlignment | Provides property to set the Vertical Alignment (especially for Controls). |
Copy Size
Common Properties
Provide Color
Common Properties
| Color | Candera::Color | The color to set. |
Advanced Properties
Provide Margin
Common Properties
Property Provider
Common Properties
| PropertyDataType | CgiStudioControl::PropertyDataTypes::Enum | Choose the type which sould be offered by this behavior. |
Advanced Properties
| Color | Candera::Color | The color which can be used from other Behaviors. |
| Image | <Candera::MemoryManagement::SharedPointer<Candera::Image2D>/td> | description="The image to set on the effect. |
| Texture | Candera::MemoryManagement::SharedPointer<Candera::TextureImage> | The texture to set on the effect. |
| Appearance | Candera::MemoryManagement::SharedPointer<Candera::Appearance> | The appearance to set on the node. |
| Value | FeatStd::Variant | The value that will be set to the Send Value as Event action. |
| Layout | CgiStudioControl::LayoutType::Enum | The layouter type for node. See Set Layout for more information. |
Render Node
Common Properties
Provide Image
Example Usage
Common Properties
| Image | Candera::MemoryManagement::SharedPointer<Candera::Image2D> | The image to set on the effect. |
| Texture | Candera::MemoryManagement::SharedPointer<Candera::TextureImage> | The image to set on the appearance. |
Set Layout
Common Properties
| Layout | CgiStudioControl::LayoutType::Enum | Selects layouter type for node: None, Overlay, Stack, Baseline. |
| StackArrangement | Candera::StackLayouter::Arrangement | Selects arrangement for stack layouter. |
| PropertyProvider | Behavior* | Property Behavior which contains the layout which has to be set on the effect. See Property Provider for more information. |
Limitations
- Only certain built-in layouters are supported
Provide Text
Example Usage
Common Properties
| Style | Candera::MemoryManagement::SharedPointer<Candera::TextRendering::SharedStyle> | The Style that will be set to the Text Node. |
| Alignment | Candera::TextNode2DLayouter::TextAlignment | The horizontal text alignment, using the culture text direction, is used to define how text will be horizontally aligned within its layout area. |
| Multiline | bool | If multi line is disabled then the new line control characters will be ignored and text will always be rendered in one line. |
| LineSpacing | Candera::TextRendering::PixelSize | Defines the distance between the baselines of successive lines of text. |
| WordWrap | bool | If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines. |
| Trimming | Candera::TextNode2DLayouter::Trimming | Trimming defines the behavior to employ when content overflows the content area. |
| TrimmingText | FeatStd::String | Trimming text defines the text which replaces content overflowing the content area. |
Align Pivot
Example Usage
Common Properties
Common Properties
Arc Align
Example Usage
Common Properties
Blend Mode
- Lighten
- Darken.
Common Properties
| Blend Mode | BlendType::Enum | Sets a blend mode from a given list of options. |
Breadcrumb Behavior
Common Properties
Disable Control
Enable Control
Event Bridge
Common Properties
Focus
Focus Leave
Hover
See also
Example Usage
HoverLeave
Example Usage
IntervalSwitch
Common Properties
| State | IntervalSwitchState::Enum | If set to On, sends only On value to Trigger Behaviors in the same node. If set to Off, sends only Off value to Trigger Behaviors in the same node. If set to Blinking, alternates between sending On or Off values. Use On Time Ms and Off Time Ms to specify the speed of blinking. |
| OnTimeMs | FeatStd::UInt32 | If State is set to Blinking, IntervalSwitchBehavior will be sending On value for On Time Ms miliseconds before switching to sending Off value. |
| OffTimeMs | FeatStd::UInt32 | If State is set to Blinking, IntervalSwitchBehavior will be sending Off value for Off Time Ms miliseconds before switching to sending On value. |
Keyboard Behavior
Common Properties
| KeyBackContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of KEY_BACK special key |
| KeyBackText | FeatStd::String | KEY_BACK is labeled with the text (enabled with appropriate content type set to text) |
| KeyBackImage | SharedPointer<Candera::Image2D> | KEY_BACK is labeled with the image (enabled with appropriate content type set to image) |
| KeyEnterContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of KEY_ENTER special key |
| KeyEnterText | FeatStd::String | KEY_ENTER is labeled with the text (enabled with appropriate content type set to text) |
| KeyEnterImage | SharedPointer<Candera::Image2D> | KEY_ENTER is labeled with the image (enabled with appropriate content type set to image) |
| KeySpaceContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of KEY_SPACE special key |
| KeySpaceText | FeatStd::String | KEY_SPACE is labeled with the text (enabled with appropriate content type set to text) |
| KeySpaceImage | SharedPointer<Candera::Image2D> | KEY_SPACE is labeled with the image (enabled with appropriate content type set to image) |
| KeySwitchText | FeatStd::String | SWITCH is labeled with the text (enabled with appropriate content type set to text) |
| KeySwitchImage | SharedPointer<Candera::Image2D> | SWITCH is labeled with the image (enabled with appropriate content type set to image) |
| KeyShiftText | FeatStd::String | SHIFT is labeled with the text (enabled with appropriate content type set to text) |
| KeyShiftImage | SharedPointer<Candera::Image2D> | SHIFT is labeled with the image (enabled with appropriate content type set to image) |
| KeyCloseContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of CLOSE special key |
| KeyCloseText | FeatStd::String | CLOSE is labeled with the text (enabled with appropriate content type set to text) |
| KeyCloseImage | SharedPointer<Candera::Image2D> | CLOSE is labeled with the image (enabled with appropriate content type set to image) |
Configuration String
| Key String | Meaning |
Menu Item
Common Properties
| FocusImageOnSelection | Candera::MemoryManagement::SharedPointer<Candera::Image2D> | The image to set on the effect. |
| FocusImageOnDragging | Candera::MemoryManagement::SharedPointer<Candera::Image2D> | The image to set on the effect. |
| Blend Type | CgiStudioControl::BlendType::Enum | Sets the blend option. |
MenuScreen
Common Properties
| Action | MenuScreenAction::Enum | Action that will be called on the menu screen. |
| SignDisplayNode | SignDisplayNodeType | Node used to display the graphical sign. |
| PrimaryTextNode | PrimaryTextNodeType | Node used to display the primary message. |
| SecondaryTextNode | SecondaryTextNodeType | Node used to display the secondary message. |
| ManeuverTypeTextNode | ManeuverTypeTextNodeType | Node used to display the maneuver type (as text). |
OnClick
- Note:
Example Usage
OnPressed
Example Usage
OnTimer
See also
Example Usage
Page Indicator
Common Properties
| DecrementKeyCode | Candera::KeyboardKeyCode::Enum | Key used for decrementing value (if value is actually decremented, focus handling is suspended) |
| IncrementKeyCode | Candera::KeyboardKeyCode::Enum | Key used for incrementing value (if value is actually incremented, focus handling is suspended) |
| Width | WidthType | Width of the clipping rectangle. |
| Height | HeightType | Height of the clipping rectangle. |
| ClipPositionEnabled | ClipPositionEnabledType | Enable Clipping Position. |
Roll
Common Properties
Advanced Properties
| LensGroup | Candera::AbstractNodePointer | Node containing current value |
| DecorationGroup | Candera::AbstractNodePointer | Node containing lens decoration |
| Format | FeatStd::String | Value display format (use f for value) |
| Step | FeatStd::Float | Value step (positive float) |
| AllowDraggingPastLimit | bool | Allow temporary over-dragging (dragging to blank values before first and after last entry) |
| EditKeyCode | Candera::KeyboardKeyCode::Key_Enter | Key used for entering text edit mode |
Common Properties
| Camera | The camera used to render the touch indicator. Will be used to correctly match touch position with object position in case the camera has a position offset. | |
| DistanceFromCamera | FeatStd::Float | How far from the camera should the touch indication node be rendered. |
Transform Mesh2D
Common Properties
Event Handler
Example Usage
Common Properties
Virtual Key
Common Properties
| Modifier | Candera::KeyModifierEnum::Enum | Modifier Key (e.g. Shift) |
| KeyCode | Candera::KeyboardKeyCode::Enum | With KeyCode you can select any key. |
