Control Behaviors
Content List
  • Construction Kit Control Behaviors
  • Internal Control Behaviors
    • Caret
    • Handle Control State
    • DataContext
    • Edit Text
    • Selection Group
  • Public Property Control Behaviors
    • Provide Alignment
    • Copy Size
    • Provide Color
    • Provide Margin
    • Property Provider
    • Render Node
    • Provide Appearance
    • Provide Image
    • Set Layout
    • Provide Text
  • Align Pivot
  • Android Event Bridge
  • Arc Align
  • Blend Mode
  • Breadcrumb Behavior
  • Disable Control
  • Enable Control
  • Event Bridge
  • Focus
  • Focus Leave
  • Hover
  • HoverLeave
  • IntervalSwitch
  • Keyboard Behavior
  • Menu Item
  • MenuScreen
  • Navigation Instruction View
  • OnClick
  • OnPressed
  • OnTimer
  • Orbit Camera Transform
  • Page Indicator
  • Rectangle Clipping Behavior
  • Roll
  • Touch Indication Behavior
  • Transform Mesh2D
  • Event Handler
  • Virtual Key
Construction Kit Control Behaviors > Map
Map
Bearing BearingType Clockwise angle relative to North that the users currently faces.
Longitude LongitudeType Longitude of current users location.
Latitude LatitudeType Latitude of current users location.
SimulateDriving SimulateDrivingType Simulate driving along computed route when in navigation mode.
NaviMessageNode NaviMessagesNodeType Node to which navigation instructions will be sent.
LocationMesh LocationMeshType Node containing mesh(es) used to render the location indicator.
RouteOverlayColor RouteOverlayColorType Color used by the route overlay.
AvoidTolls AvoidTollsType Avoid tolls during route computation.
AvoidMotorways AvoidMotorwaysType Avoid motorways during route computation.
AvoidFerry AvoidFerryType Avoid ferrys during route computation.
Back to the menu
Map Bridge
TargetNode TargetNodeType Node containing the target MapBehavior to which events will be forwarded.
Back to the menu
List Behavior
Common Properties
ScrollDirection ScrollDirection::Enum The direction in which the ListBehavior scrolls.
Position FeatStd::Float The pixel position of the visible content within the list content.
AnimationDuration FeatStd::UInt32 Duration of the scrolling animation.
DecelerationFactor FeatStd::Float Loss of flick animation speed over time.
MaxSpeedPerFlick FeatStd::Float Maximum amount of speed each flick motion adds to the flick animation.
MinSpeedPerFlick FeatStd::Float Minimum speed required to count a touch gesture as a flick and start or continue the flick animation.
MinMovementToScrolling FeatStd::UInt32 Minimum distance a touch gesture needs to move to start a scrolling animation.
MaxTouchSampleAge FeatStd::UInt32 Maximum age in miliseconds of touch movement speed counted towards generating flick animation speed.
Items
ListFragmentTriggerOffset FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This trigger offset value defines an area at the begin and end of the list fragment. Whenever the list shows a part of these areas a new fragment is requested from the model.
ListFragmentSize FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This buffer size defines how large this fragment should be. By default it is set to 0 which results in an automatic calculation. The automatic calculation assumes the number of item nodes is configured to match the maximum number of visible nodes for one page. By multiplying this number by three and adding the trigger offset one time for the begin and one additional time for the end to calculate for the automatic buffer size the list has a spare page on each side before a new fragment has to be requested
Back to the menu
Scrollbar Behavior
Common Properties
TouchListenerNode Candera::AbstractNodePointer This node defines the area on which the ScrollbarBehavior will listen for the touch events.
ScrollDirection FeatStd::Optional< ScrollDirection::Enum > The direction in which the ListBehavior scrolls. By default it is configured as a vertical scrollbar.
ScrollbarVisibility ScrollbarVisibility::Enum Configure the visibility of the scrollbar. By default it is set to Automatic which will determine the visibility based on the actual content.
HandleMinimumSize FeatStd::UInt32 The minimum height (for vertical scrollbar) or minimum width (for horizontal scrollbar) of the handle in pixels.
MinMovementToScrolling FeatStd::UInt32 Minimum distance a touch gesture needs to move to start scrolling.
Back to the menu
Scroll View
Example Usage
Common Properties
Back to the menu
SubList Behavior
Common Properties
ScrollDirection ScrollDirection::Enum The direction in which the SubListBehavior scrolls.
Items
Back to the menu
Circular Slider Behavior
This behavior provides the functionality of CircularSlider control by creating a radial mask and setting a rotation of knob node.
Common Properties
Value FeatStd::Variant Value of the slider
MinimumValue FeatStd::Variant Minimum value of the slider
MaximumValue FeatStd::Variant Maximum value of the slider
StepSize FeatStd::Variant Step size for Value
MinimumAngle FeatStd::Float Angle of the slider, corresponding to minimum value.
MaximumAngle FeatStd::Float Angle of the slider, corresponding to maximum value.
ThumbNode Candera::AbstractNodePointer Thumb node which will be rotated.
ImageNode Candera::AbstractNodePointer Image node which will be masked.
Back to the menu
Drawer Behavior
Common Properties
Open bool Shows the Drawer in its opened appearance.
AppearDirection AppearDirection::Enum The direction from which the Drawer will open.
DragEnabled bool Set to true to allow the Drawer to be controlled by Touch Inputs.
Back to the menu
Caret
Common Properties
CaretNode Candera::AbstractNodePointer Node which will be set as caret." type="
IntervalSwitchBehavior Candera::Behavior* The Caret Behavior will change the state of the given IntervalSwitch Behavior.
Back to the menu
Example Usage
Common Properties
Highlighted bool If true, the controls state Highlighted is set to true.
Identifier Candera::AbstractNodePointer Identifier which is used when emitting an Event (e.g. Click Event).
Back to the menu
DataContext
Common Properties
Back to the menu
Edit Text
Common Properties
InputText FeatStd::String Text which will be set as default text.
TextNode Candera::AbstractNodePointer Text Node which will be edited.
Placeholder Candera::AbstractNodePointer Text which will be shown as placeholder.
SetValueOnEachChange bool If true, the value will be set on each input.
MaxTextLength FeatStd::UInt16 Maximum count of characters.
JustDigits bool If true, the Inputfield will receive just digits.
Back to the menu
Selection Group
Common Properties
DefaultSelectedObject Candera::AbstractNodePointer Selection Object (e.g. RadioButton) which shall be selected by default.
Back to the menu
Provide Alignment
Common Properties
HorizontalAlignment Candera::HorizontalAlignment Provides property to set the Horizontal Alignment (especially for Controls).
VerticalAlignment Candera::VerticalAlignment Provides property to set the Vertical Alignment (especially for Controls).
Back to the menu
Copy Size
Common Properties
Back to the menu
Provide Color
Common Properties
Color Candera::Color The color to set.
Advanced Properties
PropertyProvider Behavior* Property Behavior which contains the color which has to be set on the effect.
Back to the menu
Provide Margin
Common Properties
Margin Candera::Margin Provides property to set the Margin (especially for Controls).
Back to the menu
Property Provider
Common Properties
PropertyDataType CgiStudioControl::PropertyDataTypes::Enum Choose the type which sould be offered by this behavior.
Advanced Properties
Color Candera::Color The color which can be used from other Behaviors.
Text FeatStd::String The Text that will be set to the Text Node.
Image <Candera::MemoryManagement::SharedPointer<Candera::Image2D>/td> description="The image to set on the effect.
Texture Candera::MemoryManagement::SharedPointer<Candera::TextureImage> The texture to set on the effect.
Appearance Candera::MemoryManagement::SharedPointer<Candera::Appearance> The appearance to set on the node.
Value FeatStd::Variant The value that will be set to the Send Value as Event action.
Layout CgiStudioControl::LayoutType::Enum The layouter type for node. See Set Layout for more information.
Back to the menu
Render Node
Common Properties
EnableRendering bool If true, rendering is enabled.
Back to the menu
Provide Appearance
ProvideAppearance, 3D only
Common Properties
Advanced Properties
Back to the menu
Provide Image
Example Usage
Common Properties
Image Candera::MemoryManagement::SharedPointer<Candera::Image2D> The image to set on the effect.
Texture Candera::MemoryManagement::SharedPointer<Candera::TextureImage> The image to set on the appearance.
Set Layout
Class Reference
Common Properties
Layout CgiStudioControl::LayoutType::Enum Selects layouter type for node: None, Overlay, Stack, Baseline.
StackArrangement Candera::StackLayouter::Arrangement Selects arrangement for stack layouter.
PropertyProvider Behavior* Property Behavior which contains the layout which has to be set on the effect. See Property Provider for more information.
Limitations
  • Only certain built-in layouters are supported
  • Scene Composer does not support displaying layout-related properties when layouter is assigned using SetLayout behavior.
Back to the menu
Provide Text
Example Usage
Common Properties
Style Candera::MemoryManagement::SharedPointer<Candera::TextRendering::SharedStyle> The Style that will be set to the Text Node.
Alignment Candera::TextNode2DLayouter::TextAlignment The horizontal text alignment, using the culture text direction, is used to define how text will be horizontally aligned within its layout area.
Multiline bool If multi line is disabled then the new line control characters will be ignored and text will always be rendered in one line.
LineSpacing Candera::TextRendering::PixelSize Defines the distance between the baselines of successive lines of text.
WordWrap bool If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines.
Trimming Candera::TextNode2DLayouter::Trimming Trimming defines the behavior to employ when content overflows the content area.
TrimmingText FeatStd::String Trimming text defines the text which replaces content overflowing the content area.
Back to the menu
Align Pivot
Example Usage
Common Properties
Back to the menu
Common Properties
TargetNode Candera::AbstractNodePointer The target node to which the events are sent. If the property is not set, the event will be routed to the node of the behavior.
Back to the menu
Arc Align
Example Usage
Common Properties
Radius Float Radius of the digital needle indicators.
Orientation Offset Float Offset in the orientation of the needle indicators.
Angle Min Max Vector2 Min/Max angle values (e.g. indicators displayed from -25 to 210 degrees).
Back to the menu
Blend Mode
Class Reference
  • Default
  • Add
  • Multiply
  • Screen
  • Source Atop
  • Source In
  • Source Over
  • Destination Atop
  • Destination Out
  • Destination Over
  • Lighten
  • Darken.
Common Properties
Blend Mode BlendType::Enum Sets a blend mode from a given list of options.
Back to the menu
Breadcrumb Behavior
Common Properties
StateMachineNode Candera::AbstractNodePointer The node of the State Machine
EllipsisText FeatStd::String When more elements are added than the breadcrumb can show, one element will be replaced with the text from this field (collapse effect).
PathDelimiter FeatStd::String Tag that separates the elements that a path contains.
Back to the menu
Disable Control
Back to the menu
Enable Control
Back to the menu
Event Bridge
Common Properties
TargetNode Candera::AbstractNodePointer The target node to which the events are routed from the source node. If the property is not set, the event will be routed to the node of the behavior.
Back to the menu
Focus
Back to the menu
Focus Leave
Back to the menu
Hover
See also
HoverLeave
Example Usage
Back to the menu
HoverLeave
Example Usage
Back to the menu
IntervalSwitch
Common Properties
State IntervalSwitchState::Enum If set to On, sends only On value to Trigger Behaviors in the same node. If set to Off, sends only Off value to Trigger Behaviors in the same node. If set to Blinking, alternates between sending On or Off values. Use On Time Ms and Off Time Ms to specify the speed of blinking.
OnTimeMs FeatStd::UInt32 If State is set to Blinking, IntervalSwitchBehavior will be sending On value for On Time Ms miliseconds before switching to sending Off value.
OffTimeMs FeatStd::UInt32 If State is set to Blinking, IntervalSwitchBehavior will be sending Off value for Off Time Ms miliseconds before switching to sending On value.
Back to the menu
Keyboard Behavior
Common Properties
ConfigurationScript FeatStd::String String that specifies symbols and layout of the Control
StateMachineNode AbstractNodePointer State machine that reacts on events sent by a special key to change keyboard layout
KeyBackContentType CgiStudioControl::KeyContent::Enum Switch for Content of KEY_BACK special key
KeyBackText FeatStd::String KEY_BACK is labeled with the text (enabled with appropriate content type set to text)
KeyBackImage SharedPointer<Candera::Image2D> KEY_BACK is labeled with the image (enabled with appropriate content type set to image)
KeyEnterContentType CgiStudioControl::KeyContent::Enum Switch for Content of KEY_ENTER special key
KeyEnterText FeatStd::String KEY_ENTER is labeled with the text (enabled with appropriate content type set to text)
KeyEnterImage SharedPointer<Candera::Image2D> KEY_ENTER is labeled with the image (enabled with appropriate content type set to image)
KeySpaceContentType CgiStudioControl::KeyContent::Enum Switch for Content of KEY_SPACE special key
KeySpaceText FeatStd::String KEY_SPACE is labeled with the text (enabled with appropriate content type set to text)
KeySpaceImage SharedPointer<Candera::Image2D> KEY_SPACE is labeled with the image (enabled with appropriate content type set to image)
KeySwitchContentType CgiStudioControl::KeyContent::Enum Switch for Content of SWITCH special key
KeySwitchText FeatStd::String SWITCH is labeled with the text (enabled with appropriate content type set to text)
KeySwitchImage SharedPointer<Candera::Image2D> SWITCH is labeled with the image (enabled with appropriate content type set to image)
KeyShiftContentType CgiStudioControl::KeyContent::Enum Switch for Content of SHIFT special key
KeyShiftText FeatStd::String SHIFT is labeled with the text (enabled with appropriate content type set to text)
KeyShiftImage SharedPointer<Candera::Image2D> SHIFT is labeled with the image (enabled with appropriate content type set to image)
KeyCloseContentType CgiStudioControl::KeyContent::Enum Switch for Content of CLOSE special key
KeyCloseText FeatStd::String CLOSE is labeled with the text (enabled with appropriate content type set to text)
KeyCloseImage SharedPointer<Candera::Image2D> CLOSE is labeled with the image (enabled with appropriate content type set to image)
NavigateUpKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key above the current focused
NavigateDownKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key below the current focused
NavigateNextKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key on the right from the current focused
NavigatePreviousKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key on the left from the current focused
NavigateStartKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that starts navigation within the Control
NavigateStartOnDown bool Enables starting navigation with the same key as NavigateDownKeyCode
NavigateEndKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that finishes navigation within the Control
NavigateEndOnUp bool Enables finishing navigation with the same key as NavigateUpKeyCode
NavigateCloseKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that hides the Control
NavigateInvokeKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that emulates clicking the current focused Key from the Control
Configuration String
Key String Meaning
enum from Candera::KeyboardKeyCode::Enum:
KEY_BACK, KEY_SPACE, KEY_ENTER
For most keys KEY_* has the same meaning as * (e.g. „KEY_A“ is the same as simply „A“); it enables keys with non-printable characters like backspace etc.
CLOSE() Represents a key that sends Close KeyboardAction to a state machine; it is designed to enable hiding (setting EnableRendering to false) an instance of the Control
SWITCH(layoutName) Represents a key that sends ¬¬to a state machine an event with its argument; it is designed to enable permanent changing layout e.g. to uppercase letters, symbols or digits
SHIFT(layoutName) Mostly the same as SWITCH() but is separated to enable changing layout only for a single input, it means after entering a single letter (e.g. first capital letter in a sentence) the layout will be reset to the previous one
NULL() Represents a key that will NOT be rendered; it is designed for a layouting/padding purpose
Back to the menu
Menu Item
Class Reference
Common Properties
DeleteButtonNode Candera::AbstractNodePointer Delete button node needed to control visibility (render on/off).
Focusable bool If true then focus node will be visible.
FocusNode Candera::AbstractNodePointer Focus node needed to control visibility (render on/off) and change focus image.
Enabled bool If true then item is visible.
FocusImageOnSelection Candera::MemoryManagement::SharedPointer<Candera::Image2D> The image to set on the effect.
FocusImageOnDragging Candera::MemoryManagement::SharedPointer<Candera::Image2D> The image to set on the effect.
Blend Type CgiStudioControl::BlendType::Enum Sets the blend option.
Back to the menu
MenuScreen
Class Reference
Common Properties
Action MenuScreenAction::Enum Action that will be called on the menu screen.
Back to the menu
SignDisplayNode SignDisplayNodeType Node used to display the graphical sign.
PrimaryTextNode PrimaryTextNodeType Node used to display the primary message.
SecondaryTextNode SecondaryTextNodeType Node used to display the secondary message.
ManeuverTypeTextNode ManeuverTypeTextNodeType Node used to display the maneuver type (as text).
Back to the menu
OnClick
Note:
Click is a synthetic event composed by combining two basic events: Press and Release.
Example Usage
Back to the menu
OnPressed
Example Usage
Back to the menu
OnTimer
See also
Check Timer, Start Timer
Example Usage
Back to the menu
Camera CameraType The camera that looks at the associated node.
Back to the menu
Page Indicator
Class Reference
Common Properties
ActivePageIndex FeatStd::Int32 Index of active page (range from 0 to NumberOfPages - 1)
NumberOfPages FeatStd::Int32 Total number of pages (you have to ensure that PageIndicator has at least this number of child elements)
DecrementKeyCode Candera::KeyboardKeyCode::Enum Key used for decrementing value (if value is actually decremented, focus handling is suspended)
IncrementKeyCode Candera::KeyboardKeyCode::Enum Key used for incrementing value (if value is actually incremented, focus handling is suspended)
TargetNode Candera::AbstractNodePointer Target node that will receive a ChangeValueEvent when ActivePageIndex changes
Back to the menu
Width WidthType Width of the clipping rectangle.
Height HeightType Height of the clipping rectangle.
ClipPositionEnabled ClipPositionEnabledType Enable Clipping Position.
Back to the menu
Roll
Class Reference
Common Properties
Step FeatStd::Float Value step (positive float value).
Advanced Properties
ValueGroup Candera::AbstractNodePointer Node containing a range of displayed values
LensGroup Candera::AbstractNodePointer Node containing current value
DecorationGroup Candera::AbstractNodePointer Node containing lens decoration
Value FeatStd::Float Current value
Format FeatStd::String Value display format (use f for value)
Min FeatStd::Float Minimum value
Max FeatStd::Float Maximum value
Step FeatStd::Float Value step (positive float)
LensVisible bool Is lens group visible?
UseCyclicRoll bool Is roll cyclic?
AllowDraggingPastLimit bool Allow temporary over-dragging (dragging to blank values before first and after last entry)
EditKeyCode Candera::KeyboardKeyCode::Key_Enter Key used for entering text edit mode
TextEditNode Candera::AbstractNodePointer Node containing text edit field
Back to the menu
Common Properties
IndicationNode Candera::AbstractNodePointer The node moved by the Touch Indication Behavior. It is moved to the touch location to point it out.
TouchAreaNode Candera::AbstractNodePointer The node whose area the Touch Indication Behavior should indicate touch events on.
Camera
The camera used to render the touch indicator. Will be used to correctly match touch position with object position in case the camera has a position offset.
DistanceFromCamera FeatStd::Float How far from the camera should the touch indication node be rendered.
OnAnimation Candera::MemoryManagement::SharedPointer<Candera::Animation::AnimationPlayer> Optional animation played when the indicator is shown.
OffAnimation Candera::MemoryManagement::SharedPointer<Candera::Animation::AnimationPlayer> Optional animation played when the indicator is hidden.
HideIndicatorOnMove bool Hide the touch indicator when a move is detected, otherwise the indicator will stay visible during movement until the finger is lifted from the screen.
Back to the menu
Transform Mesh2D
Class Reference
Common Properties
Rotation FeatStd::Float Defines the rotation angle in degree around configured rotation axis at the configured origin
CameraDistance FeatStd::Float Defines a normalized camera distance (the projection is based on a normalized geometry of widht and height 1) with a default value of 1.
FitToMaximumSizeRotation FeatStd::Float Defines the rotation angle in degree that will be uses as maximum for the FitToMaximumSize fit strategy. Default is an angle of 90 degree.
RotationAxis Candera::Vector3 Defines the axis (default is the y axis) for the rotation as a 3D direction vector (the vector will be internally normalized).
FieldOfView FeatStd::Float The area on the Y axis view field in degrees. It influences the perspective distortion of the projection. Higher angles will result in more distorted projection. Lower angles will result in less perspective distorted projections. The angle has to be higher than 0 and less than 180.
FitStrategy TransformMesh2DFitStrategy::Enum Defines how the perspective projected mesh should fit into the original boundaries.
HorizontalOrigin CgiStudioControl::HorizontalOrigin::Enum The origin influences where the rotation is performed and how the perspective projection looks. It is defined as a normalized (bitmap resolution independent) origin on the y axis as Left (0), Center (0.5), Right (1.0) or Custom (see CustomHorizontalOrigin).
VerticalOrigin CgiStudioControl::VerticalOrigin::Enum The origin influences where the rotation is performed and how the perspective projection looks. It is defined as a normalized (bitmap resolution independent) origin on the y axis as Top (0), Center (0.5), Bottom (1.0) or Custom (see CustomVerticalOrigin).
CustomHorizontalOrigin FeatStd::Float Defines a normalized (bitmap resolution independent) custom origin that can not be defined with Left, Center or Right.
CustomVerticalOrigin FeatStd::Float Defines a normalized (bitmap resolution independent) custom origin that can not be defined with Top, Center or Bottom.
OriginOffset Candera::Vector2 In addition to the configured normalized origin this pixel based origin offset is added.
Back to the menu
Event Handler
Example Usage
Common Properties
Actions ActionBehaviorArrayProperty The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition.
Back to the menu
Virtual Key
Common Properties
Modifier Candera::KeyModifierEnum::Enum Modifier Key (e.g. Shift)
KeyCode Candera::KeyboardKeyCode::Enum With KeyCode you can select any key.
Back to the menu
