Control Behaviors
Content List
- Map
- List Behavior
- Scrollbar Behavior
- Scroll View
- SubList Behavior
- Circular Slider Behavior
- Drawer Behavior
- Internal Control Behaviors
- Caret
- Handle Control State
- DataContext
- Edit Text
- Selection Group
- Provide Alignment
- Copy Size
- Provide Color
- Provide Margin
- Property Provider
- Render Node
- Provide Appearance
- Provide Image
- Set Layout
- Provide Text
- Align Pivot
- Android Event Bridge
- Arc Align
- Blend Mode
- Breadcrumb Behavior
- Disable Control
- Enable Control
- Event Bridge
- Focus
- Focus Leave
- Hover
- HoverLeave
- IntervalSwitch
- Keyboard Behavior
- Menu Item
- MenuScreen
- Navigation Instruction View
- OnClick
- OnPressed
- OnTimer
- Orbit Camera Transform
- Page Indicator
- Rectangle Clipping Behavior
- Roll
- Touch Indication Behavior
- Transform Mesh2D
- Event Handler
- Virtual Key
Construction Kit Control Behaviors > Map
Map
Property Name
Type
Bearing
BearingType
Clockwise angle relative to North that the users currently faces.
Longitude
LongitudeType
Longitude of current users location.
Latitude
LatitudeType
Latitude of current users location.
SimulateDriving
SimulateDrivingType
Simulate driving along computed route when in navigation mode.
NaviMessageNode
NaviMessagesNodeType
Node to which navigation instructions will be sent.
LocationMesh
LocationMeshType
Node containing mesh(es) used to render the location indicator.
RouteOverlayColor
RouteOverlayColorType
Color used by the route overlay.
AvoidTolls
AvoidTollsType
Avoid tolls during route computation.
AvoidMotorways
AvoidMotorwaysType
Avoid motorways during route computation.
AvoidFerry
AvoidFerryType
Avoid ferrys during route computation.
Map Bridge
Property Name
Type
TargetNode
TargetNodeType
Node containing the target MapBehavior to which events will be forwarded.
List Behavior
Common Properties
Property Name
Type
ScrollDirection
ScrollDirection::Enum
The direction in which the ListBehavior scrolls.
Position
FeatStd::Float
The pixel position of the visible content within the list content.
AnimationDuration
FeatStd::UInt32
Duration of the scrolling animation.
DecelerationFactor
FeatStd::Float
Loss of flick animation speed over time.
MaxSpeedPerFlick
FeatStd::Float
Maximum amount of speed each flick motion adds to the flick animation.
MinSpeedPerFlick
FeatStd::Float
Minimum speed required to count a touch gesture as a flick and start or continue the flick animation.
MinMovementToScrolling
FeatStd::UInt32
Minimum distance a touch gesture needs to move to start a scrolling animation.
MaxTouchSampleAge
FeatStd::UInt32
Maximum age in miliseconds of touch movement speed counted towards generating flick animation speed.
Items
ListFragmentTriggerOffset
FeatStd::SizeType
A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This trigger offset value defines an area at the begin and end of the list fragment. Whenever the list shows a part of these areas a new fragment is requested from the model.
ListFragmentSize
FeatStd::SizeType
A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This buffer size defines how large this fragment should be. By default it is set to 0 which results in an automatic calculation. The automatic calculation assumes the number of item nodes is configured to match the maximum number of visible nodes for one page. By multiplying this number by three and adding the trigger offset one time for the begin and one additional time for the end to calculate for the automatic buffer size the list has a spare page on each side before a new fragment has to be requested
Common Properties
Property Name
Type
TouchListenerNode
Candera::AbstractNodePointer
This node defines the area on which the ScrollbarBehavior will listen for the touch events.
ScrollDirection
FeatStd::Optional< ScrollDirection::Enum >
The direction in which the ListBehavior scrolls. By default it is configured as a vertical scrollbar.
ScrollbarVisibility
ScrollbarVisibility::Enum
Configure the visibility of the scrollbar. By default it is set to Automatic which will determine the visibility based on the actual content.
HandleMinimumSize
FeatStd::UInt32
The minimum height (for vertical scrollbar) or minimum width (for horizontal scrollbar) of the handle in pixels.
FeatStd::UInt32
Minimum distance a touch gesture needs to move to start scrolling.
Example Usage
Common Properties
SubList Behavior
Common Properties
Property Name
Type
ScrollDirection
The direction in which the SubListBehavior scrolls.
Position
FeatStd::Float
AnimationDuration
FeatStd::UInt32
DecelerationFactor
FeatStd::Float
MaxSpeedPerFlick
FeatStd::Float
MinSpeedPerFlick
FeatStd::Float
FeatStd::UInt32
MaxTouchSampleAge
FeatStd::UInt32
Items
FeatStd::SizeType
ListFragmentSize
FeatStd::SizeType
This behavior provides the functionality of CircularSlider control by creating a radial mask and setting a rotation of knob node.
Common Properties
Property Name
Type
Value
FeatStd::Variant
Value of the slider
MinimumValue
FeatStd::Variant
Minimum value of the slider
MaximumValue
FeatStd::Variant
Maximum value of the slider
StepSize
FeatStd::Variant
Step size for Value
MinimumAngle
FeatStd::Float
Angle of the slider, corresponding to minimum value.
MaximumAngle
FeatStd::Float
Angle of the slider, corresponding to maximum value.
ThumbNode
Thumb node which will be rotated.
ImageNode
Image node which will be masked.
Drawer Behavior
Common Properties
Property Name
Type
Open
bool
Shows the Drawer in its opened appearance.
AppearDirection
AppearDirection::Enum
The direction from which the Drawer will open.
DragEnabled
bool
Set to true to allow the Drawer to be controlled by Touch Inputs.
Caret
Common Properties
Property Name
Type
CaretNode
Node which will be set as caret." type="
IntervalSwitchBehavior
Candera::Behavior*
The Caret Behavior will change the state of the given IntervalSwitch Behavior.
Example Usage
Common Properties
Property Name
Type
Highlighted
bool
If true, the controls state Highlighted is set to true.
Enabled
bool
If set to false it will not react on focus events and does not have to support different visualizations for the different states.
Focusable
bool
If true, the control is focusable. Otherwise the control can not be focused.
Identifier
Identifier which is used when emitting an Event (e.g. Click Event).
DataContext
Common Properties
Edit Text
Common Properties
Property Name
Type
InputText
FeatStd::String
Text which will be set as default text.
TextNode
Text Node which will be edited.
Placeholder
Text which will be shown as placeholder.
SetValueOnEachChange
bool
If true, the value will be set on each input.
MaxTextLength
FeatStd::UInt16
Maximum count of characters.
JustDigits
bool
If true, the Inputfield will receive just digits.
Selection Group
Common Properties
Property Name
Type
DefaultSelectedObject
Selection Object (e.g. RadioButton) which shall be selected by default.
Provide Alignment
Common Properties
Property Name
Type
HorizontalAlignment
Candera::HorizontalAlignment
Provides property to set the Horizontal Alignment (especially for Controls).
VerticalAlignment
Candera::VerticalAlignment
Provides property to set the Vertical Alignment (especially for Controls).
Copy Size
Common Properties
Property Name
Type
TargetNode
The target node to which the events are routed from the source node. If the property is not set, the event will be routed to the node of the behavior
Provide Color
Common Properties
Property Name
Type
PropertyReference
CgiStudioControl::PropertyReference::Enum
Color
Candera::Color
The color to set.
Advanced Properties
Property Name
Type
PropertyProvider
Behavior*
Provide Margin
Common Properties
Property Name
Type
Margin
Candera::Margin
Provides property to set the Margin (especially for Controls).
Property Provider
Common Properties
Property Name
Type
PropertyDataType
CgiStudioControl::PropertyDataTypes::Enum
Choose the type which sould be offered by this behavior.
Advanced Properties
Property Name
Type
Color
Candera::Color
The color which can be used from other Behaviors.
Text
FeatStd::String
The Text that will be set to the Text Node.
<Candera::MemoryManagement::SharedPointer<Candera::Image2D>/td>
description="The image to set on the effect.
Texture
Candera::MemoryManagement::SharedPointer<Candera::TextureImage>
The texture to set on the effect.
Appearance
Candera::MemoryManagement::SharedPointer<Candera::Appearance>
The appearance to set on the node.
Value
FeatStd::Variant
The value that will be set to the Send Value as Event action.
Layout
CgiStudioControl::LayoutType::Enum
The layouter type for node. See Set Layout for more information.
Render Node
Common Properties
Property Name
Type
EnableRendering
bool
If true, rendering is enabled.
Provide Appearance
ProvideAppearance, 3D only
Common Properties
Property Name
Type
PropertyReference
Appearance
Advanced Properties
Property Name
Type
PropertyProvider
Behavior*
Provide Image
Example Usage
Common Properties
Property Name
Type
PropertyReference
Texture
PropertyProvider
Behavior*
Set Layout
Class Reference
Common Properties
Property Name
Type
Layout
Selects layouter type for node: None, Overlay, Stack, Baseline.
StackArrangement
Candera::StackLayouter::Arrangement
Selects arrangement for stack layouter.
PropertyReference
PropertyProvider
Behavior*
Property Behavior which contains the layout which has to be set on the effect. See Property Provider for more information.
Limitations
Only certain built-in layouters are supported
Scene Composer does not support displaying layout-related properties when layouter is assigned using SetLayout behavior.
Provide Text
Example Usage
Common Properties
Property Name
Type
PropertyReference
Text
FeatStd::String
PropertyProvider
Behavior*
Style
Candera::MemoryManagement::SharedPointer<Candera::TextRendering::SharedStyle>
Alignment
Candera::TextNode2DLayouter::TextAlignment
Multiline
bool
If multi line is disabled then the new line control characters will be ignored and text will always be rendered in one line.
LineSpacing
Candera::TextRendering::PixelSize
Defines the distance between the baselines of successive lines of text.
WordWrap
bool
If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines.
Trimming
Candera::TextNode2DLayouter::Trimming
TrimmingText
FeatStd::String
Align Pivot
Example Usage
Common Properties
Common Properties
Property Name
Type
TargetNode
The target node to which the events are sent. If the property is not set, the event will be routed to the node of the behavior.
Arc Align
Example Usage
Common Properties
Property Name
Type
Radius
Float
Radius of the digital needle indicators.
Orientation Offset
Float
Offset in the orientation of the needle indicators.
Angle Min Max
Vector2
Min/Max angle values (e.g. indicators displayed from -25 to 210 degrees).
Blend Mode
Class Reference
Default
Add
Multiply
Screen
Source Atop
Source In
Source Over
Destination Atop
Destination Out
Destination Over
Common Properties
Property Name
Type
Blend Mode
BlendType::Enum
PropertyReference
PropertyProvider
Behavior*
Virtual Key
Common Properties
Property Name
Type
Modifier
Candera::KeyModifierEnum::Enum
Modifier Key (e.g. Shift)
KeyCode
Candera::KeyboardKeyCode::Enum
With KeyCode you can select any key.
