Control Behaviors
Content List
- Map
- Map
- Map Bridge
- Map
- List Behavior
- Scrollbar Behavior
- Scroll View
- SubList Behavior
- List Behavior
- Circular Slider Behavior
- Drawer Behavior
- Map
- Internal Control Behaviors
- Caret
- Handle Control State
- DataContext
- Edit Text
- Selection Group
- Caret
- Provide Alignment
- Copy Size
- Provide Color
- Provide Margin
- Property Provider
- Render Node
- Provide Appearance
- Provide Image
- Set Layout
- Provide Text
- Provide Alignment
- Align Pivot
- Android Event Bridge
- Arc Align
- Blend Mode
- Breadcrumb Behavior
- Disable Control
- Enable Control
- Event Bridge
- Focus
- Focus Leave
- Hover
- HoverLeave
- IntervalSwitch
- Keyboard Behavior
- Menu Item
- MenuScreen
- Navigation Instruction View
- OnClick
- OnPressed
- OnTimer
- Orbit Camera Transform
- Page Indicator
- Rectangle Clipping Behavior
- Roll
- Touch Indication Behavior
- Transform Mesh2D
- Event Handler
- Virtual Key
Construction Kit Control Behaviors > Map
Map
| Bearing | BearingType | Clockwise angle relative to North that the users currently faces. |
| Longitude | LongitudeType | Longitude of current users location. |
| Latitude | LatitudeType | Latitude of current users location. |
| SimulateDriving | SimulateDrivingType | Simulate driving along computed route when in navigation mode. |
| NaviMessageNode | NaviMessagesNodeType | Node to which navigation instructions will be sent. |
| LocationMesh | LocationMeshType | Node containing mesh(es) used to render the location indicator. |
| RouteOverlayColor | RouteOverlayColorType | Color used by the route overlay. |
| AvoidTolls | AvoidTollsType | Avoid tolls during route computation. |
| AvoidMotorways | AvoidMotorwaysType | Avoid motorways during route computation. |
| AvoidFerry | AvoidFerryType | Avoid ferrys during route computation. |
Map Bridge
| TargetNode | TargetNodeType | Node containing the target MapBehavior to which events will be forwarded. |
List Behavior
Common Properties
| ScrollDirection | ScrollDirection::Enum | The direction in which the ListBehavior scrolls. |
| Items | The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required. | |
Scrollbar Behavior
Common Properties
| ScrollbarVisibility | ScrollbarVisibility::Enum | Configure the visibility of the scrollbar. By default it is set to Automatic which will determine the visibility based on the actual content. |
Scroll View
Example Usage
Common Properties
SubList Behavior
Common Properties
| ScrollDirection | ScrollDirection::Enum | The direction in which the SubListBehavior scrolls. |
This behavior provides the functionality of CircularSlider control by creating a radial mask and setting a rotation of knob node.
Common Properties
Drawer Behavior
Common Properties
| AppearDirection | AppearDirection::Enum | The direction from which the Drawer will open. |
Caret
Common Properties
| CaretNode | Candera::AbstractNodePointer | Node which will be set as caret." type=" |
| IntervalSwitchBehavior | Candera::Behavior* | The Caret Behavior will change the state of the given IntervalSwitch Behavior. |
Example Usage
Common Properties
DataContext
Common Properties
Edit Text
Common Properties
Selection Group
Common Properties
Provide Alignment
Common Properties
| HorizontalAlignment | Candera::HorizontalAlignment | Provides property to set the Horizontal Alignment (especially for Controls). |
| VerticalAlignment | Candera::VerticalAlignment | Provides property to set the Vertical Alignment (especially for Controls). |
Copy Size
Common Properties
Provide Color
Common Properties
| Color | Candera::Color | The color to set. |
Advanced Properties
Provide Margin
Common Properties
Property Provider
Common Properties
| PropertyDataType | CgiStudioControl::PropertyDataTypes::Enum | Choose the type which sould be offered by this behavior. |
Advanced Properties
| Color | Candera::Color | The color which can be used from other Behaviors. |
| Image | <Candera::MemoryManagement::SharedPointer<Candera::Image2D>/td> | description="The image to set on the effect. |
| Texture | Candera::MemoryManagement::SharedPointer<Candera::TextureImage> | The texture to set on the effect. |
| Appearance | Candera::MemoryManagement::SharedPointer<Candera::Appearance> | The appearance to set on the node. |
| Value | FeatStd::Variant | The value that will be set to the Send Value as Event action. |
| Layout | CgiStudioControl::LayoutType::Enum | The layouter type for node. See Set Layout for more information. |
Render Node
Common Properties
Provide Appearance
ProvideAppearance, 3D only
Common Properties
Advanced Properties
Provide Image
Example Usage
Common Properties
| Image | Candera::MemoryManagement::SharedPointer<Candera::Image2D> | The image to set on the effect. |
| Texture | Candera::MemoryManagement::SharedPointer<Candera::TextureImage> | The image to set on the appearance. |
Set Layout
Common Properties
| Layout | CgiStudioControl::LayoutType::Enum | Selects layouter type for node: None, Overlay, Stack, Baseline. |
| StackArrangement | Candera::StackLayouter::Arrangement | Selects arrangement for stack layouter. |
| PropertyProvider | Behavior* | Property Behavior which contains the layout which has to be set on the effect. See Property Provider for more information. |
Limitations
- Only certain built-in layouters are supported
Provide Text
Example Usage
Common Properties
| Style | Candera::MemoryManagement::SharedPointer<Candera::TextRendering::SharedStyle> | The Style that will be set to the Text Node. |
| Alignment | Candera::TextNode2DLayouter::TextAlignment | The horizontal text alignment, using the culture text direction, is used to define how text will be horizontally aligned within its layout area. |
| Multiline | bool | If multi line is disabled then the new line control characters will be ignored and text will always be rendered in one line. |
| LineSpacing | Candera::TextRendering::PixelSize | Defines the distance between the baselines of successive lines of text. |
| WordWrap | bool | If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines. |
| Trimming | Candera::TextNode2DLayouter::Trimming | Trimming defines the behavior to employ when content overflows the content area. |
| TrimmingText | FeatStd::String | Trimming text defines the text which replaces content overflowing the content area. |
Align Pivot
Example Usage
Common Properties
Common Properties
Arc Align
Example Usage
Common Properties
Blend Mode
- Lighten
- Darken.
Common Properties
| Blend Mode | BlendType::Enum | Sets a blend mode from a given list of options. |
Virtual Key
Common Properties
| Modifier | Candera::KeyModifierEnum::Enum | Modifier Key (e.g. Shift) |
| KeyCode | Candera::KeyboardKeyCode::Enum | With KeyCode you can select any key. |
