Control Behaviors
Construction Kit Control Behaviors
Map Control Behaviors
Map
Common Properties
| TouchableId |
String |
Touchable Id of the behavior. |
| Bearing | Float | Clockwise angle relative to North that the users currently faces. |
| Longitude | Candera::Variant | Longitude of current users location. |
| Latitude | Candera::Variant | Latitude of current users location. |
| SimulateDriving | bool | Simulate driving along computed route when in navigation mode. |
| NaviMessageNode | AbstractNodePointer | Node to which navigation instructions will be sent. |
| LocationMesh | AbstractNodePointer | Node containing mesh(es) used to render the location indicator. |
| RouteOverlayColor | Candera::Color | Color used by the route overlay. |
| AvoidTolls | bool | Avoid tolls during route computation. |
| AvoidMotorways | bool | Avoid motorways during route computation. |
| AvoidFerry | bool | Avoid ferrys during route computation. |
Map Bridge
Common Properties
| TouchableId |
String |
| TargetNode | AbstractNodePointer | Node containing the target MapBehavior to which events will be forwarded. |
Scroll Control Behaviors
List Behavior
Common Properties
| TouchableId |
String |
| ScrollDirection | ScrollDirection::Enum |
The direction in which the ListBehavior scrolls. Possible values: Vertical, Horizontal |
| MaxTouchSampleAge | FeatStd::UInt32 | Maximum age in milliseconds of touch movement speed counted towards generating flick animation speed. |
| Items | ListPropertyType<DataContextItem::SharedPointer> |
The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required. |
| HandleKeyboardEvents |
bool |
Makes the behavior handle KeyboardFocusNavigation events internally. |
| WrapAround |
bool |
Set this flag to true for static list to wrap around the list items on the top and bottom of the list |
Scrollbar
- 1 child: marker
Common Properties
| TouchableId |
String |
| ScrollbarVisibility | ScrollbarVisibility::Enum |
Configure the visibility of the scrollbar. By default it is set to Automatic which will determine the visibility based on the actual content. Possible values: Automatic, Collapsed, Visible |
| ScrollableNode |
Candera::AbstractNodePointer | Node of the scrollable behavior. |
Scroll View
Example Usage
Common Properties
Snap List Item Configuration
Information on how to use this behavior can be found in the chapter of the List Control.
Common Properties
| ItemAlignment | SnapAlignmentOrientation::Enum |
The location of the alignment base point within the list item. Possible values: Begin, Center, End |
| ItemAlignmentOffset | FeatStd::Float |
The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ItemAlignmentOffsetInPercent | bool |
The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
Snap List Item Extension
Common Properties
| ListBehavior | ListBehavior* |
The ListBehavior that shall be extended. This property can be set in the right side of the Scene Tree Panel. |
| ListAlignment | SnapAlignmentOrientation::Enum |
| ListAlignmentOffset | FeatStd::Float | The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ListAlignmentOffsetInPercent | bool | The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
| ItemAlignment | SnapAlignmentOrientation::Enum | The location of the alignment base point within the list item.
| ItemAlignmentOffset | FeatStd::Float | The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin. |
| ItemAlignmentOffsetInPercent | bool | The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset. |
SubList Behavior
Common Properties
| TouchableId |
String |
The direction in which the SubListBehavior scrolls. Possible values: Vertical, Horizontal |
| Items | ListPropertyType< ::Courier::DataContextItem::SharedPointer > | The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required. |
bool |
| ParentListNode |
Candera::AbstractNodePointer | The node with a ListBehavior that acts as a parent to this SubListBehavior. |
Circular Slider Behavior
Common Properties
| Receivers |
Candera::ProcessValueBehaviorArrayProperty |
The process value behaviors that will receive the value as next in the value processing chain. This property can be set in the right side of the Scene Tree Panel. |
Drawer Behavior
Common Properties
| Receivers |
| AppearDirection | AppearDirection::Enum |
The direction from which the Drawer will open. Possible values: Top, Left, Right, Bottom |
Linear Slider Behavior
Common Properties
| Receivers |
| KnobNode |
Candera::AbstractNodePointer | Knob node which will be shifted. |
| SliderBarNode | Candera::AbstractNodePointer | Image node which will be scaled according to value. |
| BackgroundNode | Candera::AbstractNodePointer | Image node which will provide background image and also control slider total size. |
| UseBitmapClipping | bool | If true, the slider bar image will be resized using bitmap clipping instead of the layouter. |
Internal Control Behaviors
Caret
Common Properties
| Receivers |
| CaretNode | Candera::AbstractNodePointer | Node which will be set as caret.. |
| IntervalSwitchBehavior | Candera::Behavior* |
The Caret Behavior will change the state of the given IntervalSwitch Behavior. This property can be set in the right side of the Scene Tree Panel. |
Handle Control State
Example Usage
Common Properties
| TouchableId |
String |
| Selected |
bool |
If true, the controls state Selected is set to true. |
DataContext
Common Properties
Edit Text
Common Properties
| Receivers |
Selection Group
Common Properties
Public Property Control Behaviors
Provide Alignment
Common Properties
| HorizontalAlignment | Candera::HorizontalAlignment |
Provides property to set the Horizontal Alignment (especially for Controls). Possible values: HLeft, HCenter, HRight, Hstretch, HstrechRight, HstrechCenter |
| VerticalAlignment | Candera::VerticalAlignment |
Provides property to set the Vertical Alignment (especially for Controls). Possible values: VTop, VCenter, VBottom, Vstretch, VstrechCenter, VstrechBottom |
Copy Size
Common Properties
Provide Color
Common Properties
The color to set. This property is only available if the PropertyReference is set to "Self". |
Advanced Properties
| PropertyProvider | Behavior* |
Property Behavior which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree Panel. This property is only available if PropertyReference is set to "Other". |
Provide Margin
Common Properties
Property Provider
Common Properties
| PropertyDataType | CgiStudioControl::PropertyDataTypes::Enum |
Choose the type which should be offered by this behavior. Possible values: Color, Text, Style, Image, Appearance, Value, BlendType, Layout, VertexBuffer |
Advanced Properties
The color which can be used from other Behaviors. This property is only available if PropertyDataType is set to "Color". |
The Text that will be set to the Text Node. This property is only available if PropertyDataType is set to "Text". |
| Style |
SharedPointer<Candera::TextRendering::SharedStyle> |
The Style that will be set to the Text Node. This property is only available if PropertyDataType is set to "Style". |
| Image | SharedPointer<Candera::Image2D> |
The image to set on the effect. This property is only available for 2D scenes if PropertyDataType is set to "Image". |
The texture to set on the effect. This property is only available for 3D scenes if PropertyDataType is set to "Image". |
| Appearance | SharedPointer<Candera::Appearance> |
The appearance to set on the node. This property is only available for 3D scenes if PropertyDataType is set to "Appearance". |
The value that will be set to the Send Value as Event action. This property is only available if PropertyDataType is set to "Value". |
| BlendType |
BlendType::Enum |
The blend type that will be set. Possible values: Default, DefaultPremultiplied, DefaultTransparentLayer, Add, Multiply, Screen, Darken, Lighten, SourceAtop, SourceIn, SourceOut, SourceOver, DestinationIn, DestinationOut, DestinationOver, Off. This property is only available if PropertyDataType is set to "BlendType". |
| Layout | CgiStudioControl::LayoutType::Enum |
The layouter type for node. See Set Layout for more information. Possible values: Horizontal, Vertical This property is only available for 2D scenes if PropertyDataType is set to "Layout". |
| StackArrangement |
StackLayouter::Arrangement |
Selects arrangement for stack layouter. This property is only available for 2D scenes if PropertyDataType is set to "Layout" and the property Layout is set to "Stack". |
| VertexBuffer | SharedPointer<Candera::VertexBuffer> |
You can set the VertexBuffer held by the mesh created when importing FBX. This property is only available for 3D scenes if PropertyDataType is set to "VertexBuffer". |
Render Node
Common Properties
| PostponeChange | bool | If set to true the render change will be handled during the next Update cyle, if false it will be handled immediately. |
Provide Appearance
Common Properties
| Appearance |
This property is only available if "PropertyReference" is set to "Self". | |
Property Behavior which contains the color which has to be set on the effect. This property is only available if "PropertyReference" is set to "Other". This property can be set in the right side of the Scene Tree Panel. |
Provide Image
Example Usage
Common Properties
Advanced Properties
The image to set on the effect. This property is only available for 2D scenes if "PropertyReference" is set to "Self". |
The image to set on the appearance. This property is only available for 3D scenes if "PropertyReference" is set to "Self". |
Set Layout
Limitations
- Only certain built-in layout mechanisms are supported
Common Properties
Selects layout type for node. Possible values: None, Overlay, Stack, Baseline. This property is only available if "PropertyReference" is set to "Self". |
Advanced Properties
| StackArrangement | Candera::StackLayouter::Arrangement |
Selects arrangement for stack layouter. This property is only available if Layout is set to "Stack". |
Property Behavior which contains the layout which has to be set on the effect. See Property Provider for more information. This property is only available if "PropertyReference"" is set to "Other". |
Set Property Provider
Sets or resets a property provider on a behavior that supports it. Note: The receiver (for example, ProvideText) must have PropertyReference set to Other when an action is triggered.
Provide Text
Example Usage
Common Properties
| Style | SharedPointer<Candera::TextRendering::SharedStyle> |
The Style that will be set to the Text Node. |
| Alignment | Candera::TextNode2DLayouter::TextAlignment |
The horizontal text alignment, using the culture text direction, is used to define how text will be horizontally aligned within its layout area. Possible values: Auto, Left, Center, Right. |
| Multiline | bool |
If multi line is disabled then the new line control characters will be ignored and text will always be rendered in one line. |
| LineSpacing | Candera::TextRendering::PixelSize |
Defines the distance between the baselines of successive lines of text. |
| WordWrap | bool |
If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines. |
| Trimming | Candera::TextNode2DLayouter::Trimming |
Trimming defines the behavior to employ when content overflows the content area. Possible values: None, Ellipsis, CustomText. |
Advanced Properties
Property Behavior which contains the color which has to be set on the effect. This property is only available if "PropertyReference"" is set to "Other". |
| TrimmingText | FeatStd::String |
Trimming text defines the text which replaces content overflowing the content area. This property is only available if "Trimming" is set to "CustomText". |
Align Pivot
Example Usage
Common Properties
Android Event Bridge
Common Properties
Arc Align
Example Usage
Common Properties
Blend Mode
- Lighten
- Darken
Common Properties
Property Behavior which contains the color which has to be set on the effect. This property is only available if PropertyReference is set to "Other". This property can be set in the right side of the Scene Tree Panel. |
| Mode | BlendType::Enum |
Sets a blend mode from a given list of options. Possible values: Default, DefaultPremultiplied, DefaultTransparentLayer, Add, Multiply, Screen, Darken (3D only), Lighten (3D only), Source Atop, Source In, SourceOut, Source Over, Destination Atop, Destination In, Destination Out, Destination Over, Off |
Breadcrumb Behavior
Common Properties
Disable Control
A set of actions can be configured, which will be executed when the node gets disabled.
Enable Control
A set of actions can be configured, which will be executed when the node gets enabled.
Event Bridge
Common Properties
Focus
A set of actions can be configured, which will be executed when the node gets focused.
Focus Leave
A set of actions can be configured, which will be executed when the node's focus is left.
Hover
See also: HoverLeave
A set of actions can be configured, which will be executed when the node gets hovered.
Example Usage
HoverLeave
A set of actions can be configured, which will be executed when the node's hovering is left.
Example Usage
IntervalSwitch
Common Properties
| State | IntervalSwitchState::Enum |
If set to On, sends only On value to Trigger Behaviors in the same node. If set to Off, sends only Off value to Trigger Behaviors in the same node. If set to Blinking, alternates between sending On or Off values. Use On Time Ms and Off Time Ms to specify the speed of blinking. Possible values: On, Off, Blinking |
| OnTimeMs | FeatStd::UInt32 | If State is set to Blinking, IntervalSwitchBehavior will be sending On value for On Time Ms milliseconds before switching to sending Off value. |
| OffTimeMs | FeatStd::UInt32 | If State is set to Blinking, IntervalSwitchBehavior will be sending Off value for Off Time Ms milliseconds before switching to sending On value. |
| AcceptValueEvent |
bool |
Set this flag to true to make the behavior changeable by events/actions. |
Keyboard
Common Properties
| KeyContent |
AbstractNodePointer | Node containing Keyboard Keys. |
| KeyBackContentType | CgiStudioControl::KeyContent::Enum |
Switch for Content of KEY_BACK special key. Possible values: Text, Icon |
| KeyBackText | FeatStd::String |
KEY_BACK is labeled with the text. This property is only visible if KeyBackContentType is set to "Text". |
| KeyBackImage | SharedPointer<Candera::Image2D> |
KEY_BACK is labeled with the image. This property is only visible if KeyBackContentType is set to "Icon". |
| KeyEnterContentType | CgiStudioControl::KeyContent::Enum |
Switch for Content of KEY_ENTER special key. Possible values: Text, Icon |
| KeyEnterText | FeatStd::String |
KEY_ENTER is labeled with the text. This property is only visible if KeyBackContentType is set to "Text". |
| KeyEnterImage | SharedPointer<Candera::Image2D> |
KEY_ENTER is labeled with the image. This property is only visible if KeyBackContentType is set to "Icon". |
| KeySpaceContentType | CgiStudioControl::KeyContent::Enum |
Switch for Content of KEY_SPACE special key. Possible values: Text, Icon |
| KeySpaceText | FeatStd::String |
KEY_SPACE is labeled with the text. This property is only visible if KeyBackContentType is set to "Text". |
| KeySpaceImage | SharedPointer<Candera::Image2D> |
KEY_SPACE is labeled with the image. This property is only visible if KeyBackContentType is set to "Icon". |
| KeySwitchText | FeatStd::String |
SWITCH is labeled with the text. This property is only visible if KeySwitchContentType is set to "Text". |
| KeySwitchImage | SharedPointer<Candera::Image2D> |
SWITCH is labeled with the image. This property is only visible if KeySwitchContentType is set to "Icon". |
| KeyShiftText | FeatStd::String |
SHIFT is labeled with the text. This property is only visible if KeyShiftContentType is set to "Text". |
| KeyShiftImage | SharedPointer<Candera::Image2D> |
SHIFT is labeled with the image. This property is only visible if KeyShiftContentType is set to "Icon". |
| KeyShiftOnceContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of SHIFT ONCE special key |
| KeyShiftOnceText | FeatStd::String |
SHIFT ONCE is labeled with the text: This property is only visible if KeyShiftOnceContentType is set to "Text". |
| KeyShiftOnceImage | SharedPointer<Candera::Image2D> |
SHIFT ONCE is labeled with the image. This property is only visible if KeyShiftOnceContentType is set to "icon". |
| KeyShiftLockContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of SHIFT LOCK special key |
| KeyShiftLockText | FeatStd::String |
SHIFT LOCK is labeled with the text. This property is only visible if KeyShiftLockContentType is set to "Text". |
| KeyShiftLockImage | SharedPointer<Candera::Image2D> |
LEFT is labeled with the image. This property is only visible if KeyShiftLockContentType is set to "Icon". |
| KeyCloseContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of SHIFT LOCK special key |
| KeyCloseText | FeatStd::String |
CLOSE is labeled with the text. This property is only visible if KeyCloseContentType is set to "Text". |
| KeyCloseImage | SharedPointer<Candera::Image2D> |
CLOSE is labeled with the image. This property is only visible if KeyCloseContentType is set to "Icon". |
| KeyLeftContentType | CgiStudioControl::KeyContent::Enum | Switch for Content of LEFT special key |
| KeyLeftText |
FeatStd::String |
LEFT is labeled with the text. This property is only visible if KeyLeftContentType is set to "Text". |
| KeyLeftImage |
LEFT is labeled with the image. This property is only visible if KeyLeftContentType is set to "Icon". |
| KeyRightContentType |
CgiStudioControl::KeyContent::Enum | Switch for Content of RIGHT special key |
| KeyRightText |
FeatStd::String |
RIGHT is labeled with the text. This property is only visible if KeyRightContentType is set to "Text". |
| KeyRightImage |
RIGHT is labeled with the image. This property is only visible if KeyRightContentType is set to "Icon". |
Configuration String
| Key String | Meaning |
Menu Item
Common Properties
| FocusImageOnSelection | SharedPointer<Candera::Image2D> | The image to set on the effect. |
| FocusImageOnDragging | SharedPointer<Candera::Image2D> | The image to set on the effect. |
MenuScreen
Common Properties
| ActiveScreenIndex |
UInt32 |
Currently active index. |
| NumberOfScreens |
UInt32 | Number of active screens. |
| LimitOfScreens |
UInt32 | Limit of active screens. |
| Rows |
UInt32 | Number of rows. |
| Columns |
UInt32 | Number of columns. |
| ScreenChangeTime |
Float |
Time of dragging a Menu Item outside boundaries of the Menu Screen to change its screen to a neighbour. |
| SwapItemAnimationEasingFunction |
EasingFunctions::Enum |
Swap item animation easing function. Possible values: CircularInOut, Linear, SineIn, SineOut, SineInOut |
| SwapItemAnimationLength |
Float |
Swap item animation length |
| ChangeScreenAnimationEasingFunction |
Change screen animation easing function. Possible values: CircularInOut, Linear, SineIn, SineOut, SineInOut |
| ChangeScreenAnimationLength |
Float |
Change screen animation length. |
| KeyCodeToMoveSelectionLeft |
Key code to move selection left. Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 |
| KeyCodeToMoveSelectionRight | KeyboardKeyCode::Enum |
Key code to move selection right. Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 |
| KeyCodeToMoveSelectionUp | KeyboardKeyCode::Enum |
Key code to move selection up. Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 |
| KeyCodeToMoveSelectionDown | KeyboardKeyCode::Enum |
Key code to move selection down. Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 |
| PageIndicatorNode | Candera::AbstractNodePointer | Page indicator node. |
| Items | ListPropertyType<::Courier::DataContextItem::SharedPointer> | The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required. |
| ContentNode | Candera::AbstractNodePointer | Content node. |
Navigation Instruction View
Common Properties
| SignDisplayNode | Candera::AbstractNodePointer | Node used to display the graphical sign. |
| PrimaryTextNode | Candera::AbstractNodePointer | Node used to display the primary message. |
| SecondaryTextNode | Candera::AbstractNodePointer | Node used to display the secondary message. |
| ManeuverTypeTextNode | Candera::AbstractNodePointer | Node used to display the maneuver type (as text). |
OnClick
A set of actions can be configured, which will be executed when the node is clicked.
- Note:
Example Usage
OnPressed
A set of actions can be configured, which will be executed when the node is pressed.
Example Usage
OnTimer
A timer node and a set of actions can be configured. These actions will be executed when the timer expires.
Example Usage
Orbit Camera Transform
When attached to a Node, the specified camera will orbit around that Node. PLAYER USE ONLY.
And the options to limit the movement of the camera to specific parts of the spherical orbit. Setting the flag IsOrbitLimited allows the user to set minimum and maximum angles between the camera and the axes of the coordinate system, preventing the camera from moving too close to an axis. In this way, the user can define unwanted areas that the camera cannot move to, e.g., below the ground.
Common Properties
| TouchableId |
String |
Touchable Id |
Advanced Properties
| IsOrbitLimited |
bool |
Enables setting of boundaries for the camera within the orbit. |
| AngleMinX | FeatStd::Float | Min angle between camera and X-axis (from 0 to 180 degrees). Must be less than AngleMaxX. |
| AngleMaxX | FeatStd::Float | Max angle between camera and X-axis (from 0 to 180 degrees). Must be greater than AngleMinX. |
| AngleMinY | FeatStd::Float | Min angle between camera and Y-axis (from 0 to 180 degrees). Must be less than AngleMaxY. |
| AngleMaxY | FeatStd::Float | Max angle between camera and Y-axis (from 0 to 180 degrees). Must be greater than AngleMinY. |
| AngleMinZ | FeatStd::Float | Min angle between camera and Z-axis (from 0 to 180 degrees). Must be less than AngleMaxZ. |
| AngleMaxZ | FeatStd::Float | Max angle between camera and Z-axis (from 0 to 180 degrees). Must be greater than AngleMinZ. |
Page Indicator
Common Properties
| DecrementKeyCode | Candera::KeyboardKeyCode::Enum |
Key used for decrementing value (if value is actually decremented, focus handling is suspended) Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 |
| IncrementKeyCode | Candera::KeyboardKeyCode::Enum |
Key used for incrementing value (if value is actually incremented, focus handling is suspended) Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 |
Rectangle Clipping Behavior
Common Properties
| Width | Float | Width of the clipping rectangle. |
| Height | Float | Height of the clipping rectangle. |
| ClipPositionEnabled | bool | Enable Clipping Position. |
| ClipPosition |
Candera::Vector2 |
Position of the clipping rectangle. This property is only available if ClipPositionEnabled is set to true. |
Roll
Common Properties
| LensGroup | Candera::AbstractNodePointer |
Node containing current value. This property is only available if 'LensVisible' is set to 'true'. |
| DecorationGroup | Candera::AbstractNodePointer |
Node containing lens decoration. This property is only available if 'LensVisible' is set to 'true'. |
| AllowDraggingPastLimit | bool |
Allow temporary over-dragging (dragging to blank values before first and after last entry) This property is only available if 'UseCyclicRoll' is set to 'false'. |
Advanced Properties
| Format | FeatStd::String |
Value display format (use '%f' for value) This property is only available if 'LensVisible' is set to 'false'. |
| EditKeyCode | Candera::KeyboardKeyCode::Key_Enter |
Key used for entering text edit mode Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 This property is only available if 'LensVisible' is set to 'true' and a 'TextEditNode' is configured. |
Touch Indication
Common Properties
| TouchableId |
String |
Touchable Id |
| Camera | Candera::AbstractNodePointer | The camera used to render the touch indicator. Will be used to correctly match touch position with object position in case the camera has a position offset. |
| DistanceFromCamera | FeatStd::Float |
How far from the camera should the touch indication node be rendered. This property is only available for 3D scenes. |
Transform Mesh2D
Common Properties
Event Handler
Example Usage
Common Properties
| ConsumeEvent |
bool |
Set this flag to false if the event should not be consumed by the trigger. By default it is set to true and if the trigger evaluates to true the event will not be routed to any other behavior. |
Virtual Key
Common Properties
| KeyType |
CgiStudioControl::KeyType::Enum |
Choose the type of key. With KeyCode you can select any key. Possible values: Modifier, KeyCode |
| Modifier | Candera::KeyModifierEnum::Enum |
