Condition Behaviors
Content List
    Control Condition Behaviors
      Check Animation State
      Check Enter or Exit
      Check Interval Switch
      Check Selection ID
      Check Control State
      Check Timer
      Check Changed Value
      Check Processed Value
      Check Video State
      Input Condition Behaviors
        Check Click
        Check Drag Drop
        Check Hover
        Check Key Input
        Check Pressed
        Swipe Gesture
        Transform Gesture
        Logic Condition Behaviors
          Check Logic Condition
          Check Not Condition
          Scroll Condition Behaviors
            Check Scroll Condition
            Check Culture Change
            Common Properties
            AnimationState AnimationState::Enum
            State of the AnimationEvent which fulfills the Condition.
            Possible values: PastEnd, Start, Stop, Finish, Resume, Pause, ApplyChanges, DirectionChange
            Sender
            SharedPointer<Candera::Animation::AnimationPlayer> The sender of AnimationEvent.
            Back to the menu
            Check Enter or Exit
            Expects an EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
            Common Properties
            EnterOrExit bool True means Enter, false means Exit.
            Common Properties
            VisualizationState IntervalSwitchState::Enum
            If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response.
            Back to the menu
            Check Selection ID
            Common Properties
            SelectionCondition SelectionConditionEnum::Enum
            The condition that the ID from the ChangeSelectionEvent has to fulfill.
            Possible values: Same, NotSame
            Check Control State
            Common Properties
            State ControlStateEnum::Enum
            State which has to be checked.
            Possible values: Selected, Pressed, Enabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched
            StateCondition StateConditionEnum::Enum
            The condition the state has to fulfill.
            Possible values: ChangedToTrue, ChangedToFalse, IsTrue, IsFalse
            Check Timer
            See also: Start Timer, OnTimer
            Common Properties
            Sender AbstractNodePointer The node from which the event has to be emitted. If it is not set then all events of the proper event type are handled.
            Back to the menu
            Check Changed Value
            Common Properties
            ConditionOperator Operators::Enum
            The condition operator.
            Possible values: GreaterThan, LowerThan, Equal, AlmostEqual, GreaterOrEqual, LowerOrEqual
            ConditionValue FeatStd::Variant The condition value.
            Back to the menu
            • Value sent in Process Value
            • External value from ValueBehavior
            • Value set directly in this ValueConditionBehavior
            Example Usage
            Common Properties
            OperationMode Operators::Enum
            Operation mode of behavior, defining which values should be compared.
            Possible values: CompareProcessedValueWithConditionValue, CompareExternalValueWithConditionValue, CompareProcessedValueWithExternalValue
            This property is only available if "OperationMode" is set to "CompareProcessedValueWithConditionValue" or  "CompareExternalValueWithConditionValue".
            ValueBehavior CgiStudioControl::ValueBehavior *
            Value behavior to be checked for changes if OperationMode requires external value.
            This property is only available if "OperationMode" is set to "CompareExternalValueWithConditionValue" or "CompareProcessedValueWithExternalValue".
            Check Video State
            Checks the state of an VideoStateEvent received from an 'Video Stream Behavior'.
            Common Properties
            VideoState VideoState::Enum
            State of the VideoEvent which fulfills the Condition.
            Possible values: Null, Ready, Playing, Paused, EndOfStream
            Back to the menu
            Check Click
            Example Usage
            Common Properties
            ClickCount CgiStudioControl::ClickCount::Enum
            If the value ClickConditionBehavior receives matches the Click Count set, it will return a positive response.
            Possible values: AnyClick, SingleClick, DoubleClick, TripleClick
            TouchId FeatStd::UInt The id of the finger that performed the click (the default value of 0 indicates the first finger, 1 the second ...).
            Back to the menu
            Check Drag Drop
            Common Properties
            Type FeatStd::Optional<DragDropEventType::Enum>
            The optional type of the event. If not provided then any DragDropEvent will be evaluated to true.
            Possible values: Drag, DragMove, Drop, DragEnter, DragLeave
            TouchId FeatStd::UInt The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...).
            Back to the menu
            Check Hover
            Common Properties
            Possible values: Hover, HoverEnter, HoverLeave
            Back to the menu
            Check Key Input
            Common Properties
            KeyType CgiStudioControl::KeyType::KeyCode
            Choose type of key.
            Possible values: KeyCode, Modifier
            KeyCode Candera::KeyboardKeyCode::Enum
            Check the KeyCode of the pressed key (can also be modifier).
            Advanced Properties
            Modifier Candera::KeyModifierEnum::Enum
            Check a modifier key.
            Back to the menu
            Check Pressed
            Common Properties
            Possible values: Pressed, Released, LongPressed
            Back to the menu
            Swipe Gesture
            Configuration
            Begin
            • The threshold in pixel is independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
            • The default threshold is set to 10 pixel.
            • The threshold can be changed by calling this method: CgiStudioControl::SwipeGestureDetector:: GetInstance().SetSwipeDistanceThreshold(…).
            Swiping
            Flick
            • The threshold is in pixel per second independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
            • The default threshold is set to 0,01 pixel per second.
            • The threshold can be changed by calling this method CgiStudioControl::SwipeGestureDetector:: GetInstance().SetFlickVelocityThreshold(…).
            Abort
            Common Properties
            Type FeatStd::Optional<SwipeType::Enum>
            The type of the swipe gesture.
            Possible values: Begin, Swiping, End, Flick, Abort
            Direction FeatStd::Optional<SwipeDirection::Enum>
            The direction of the swipe.
            Possible values: Left, Right, Up, Down
            Back to the menu
            Transform Gesture
            Common Properties
            Back to the menu
            Common Properties
            Operation LogicConditionBehaviorOperator::Enum
            Specifies logical operator that is used on values returned by the Conditions. The resulting value is returned.
            Possible values: And, Or, XOr
            Conditions Candera::ConditionBehaviorArrayProperty ConditionBehaviors that are combined with the ConditionOperator.
            Back to the menu
            Check Not Condition
            Common Properties
            Condition Candera::ConditionBehavior* ConditionBehavior whose value NotConditionBehavior inverts.
            Back to the menu
            Common Properties
            ScrollDirection ScrollDirection::Enum
            If the value that the ScrollDirectionConditionBehavior receives matches the set ScrollDirection, it will return a positive response.
            Back to the menu
            Class Reference
            Checks if the culture has changed and is fulfilled if this culture matches the locale.
            Common Properties
            Locale FeatStd::String Locale of a culture which will be checked.
            Back to the menu
