Condition Behaviors
Content List
Control Condition Behaviors
Check Animation State
Common Properties
AnimationState AnimationState::Enum
State of the AnimationEvent which fulfills the Condition.
Possible values: PastEnd, Start, Stop, Finish, Resume, Pause, ApplyChanges, DirectionChange
Sender
SharedPointer<Candera::Animation::AnimationPlayer> The sender of AnimationEvent.
Back to the menu
Check Enter or Exit
Expects an EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
EnterOrExit bool True means Enter, false means Exit.
Check Interval Switch
Common Properties
VisualizationState IntervalSwitchState::Enum
If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response.
Back to the menu
Check Selection ID
Common Properties
SelectionCondition SelectionConditionEnum::Enum
The condition that the ID from the ChangeSelectionEvent has to fulfill.
Possible values: Same, NotSame
Check Control State
Common Properties
State ControlStateEnum::Enum
State which has to be checked.
Possible values: Selected, Pressed, Enabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched
StateCondition StateConditionEnum::Enum
The condition the state has to fulfill.
Possible values: ChangedToTrue, ChangedToFalse, IsTrue, IsFalse
Check Timer
See also: Start Timer, OnTimer
Common Properties
Sender AbstractNodePointer The node from which the event has to be emitted. If it is not set then all events of the proper event type are handled.
Back to the menu
Check Changed Value
Common Properties
ConditionOperator Operators::Enum
The condition operator.
Possible values: GreaterThan, LowerThan, Equal, AlmostEqual, GreaterOrEqual, LowerOrEqual
ConditionValue FeatStd::Variant The condition value.
Back to the menu
Check Processed Value
  • Value sent in Process Value
  • External value from ValueBehavior
  • Value set directly in this ValueConditionBehavior
Example Usage
Common Properties
OperationMode Operators::Enum
Operation mode of behavior, defining which values should be compared.
Possible values: CompareProcessedValueWithConditionValue, CompareExternalValueWithConditionValue, CompareProcessedValueWithExternalValue
This property is only available if "OperationMode" is set to "CompareProcessedValueWithConditionValue" or  "CompareExternalValueWithConditionValue".
ValueBehavior CgiStudioControl::ValueBehavior *
Value behavior to be checked for changes if OperationMode requires external value.
This property is only available if "OperationMode" is set to "CompareExternalValueWithConditionValue" or "CompareProcessedValueWithExternalValue".
Check Video State
Checks the state of an VideoStateEvent received from an 'Video Stream Behavior'.
Common Properties
VideoState VideoState::Enum
State of the VideoEvent which fulfills the Condition.
Possible values: Null, Ready, Playing, Paused, EndOfStream
Back to the menu
Input Condition Behaviors
Check Click
Example Usage
Common Properties
ClickCount CgiStudioControl::ClickCount::Enum
If the value ClickConditionBehavior receives matches the Click Count set, it will return a positive response.
Possible values: AnyClick, SingleClick, DoubleClick, TripleClick
TouchId FeatStd::UInt The id of the finger that performed the click (the default value of 0 indicates the first finger, 1 the second ...).
Back to the menu
Check Drag Drop
Common Properties
Type FeatStd::Optional<DragDropEventType::Enum>
The optional type of the event. If not provided then any DragDropEvent will be evaluated to true.
Possible values: Drag, DragMove, Drop, DragEnter, DragLeave
TouchId FeatStd::UInt The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...).
Back to the menu
Check Hover
Common Properties
Possible values: Hover, HoverEnter, HoverLeave
Back to the menu
Check Key Input
Common Properties
KeyType CgiStudioControl::KeyType::KeyCode
Choose type of key.
Possible values: KeyCode, Modifier
KeyCode Candera::KeyboardKeyCode::Enum
Check the KeyCode of the pressed key (can also be modifier).
Advanced Properties
Modifier Candera::KeyModifierEnum::Enum
Check a modifier key.
Back to the menu
Check Pressed
Common Properties
Possible values: Pressed, Released, LongPressed
Back to the menu
Swipe Gesture
Configuration
Begin
  • The threshold in pixel is independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
  • The default threshold is set to 10 pixel.
  • The threshold can be changed by calling this method: CgiStudioControl::SwipeGestureDetector:: GetInstance().SetSwipeDistanceThreshold(…).
Swiping
Flick
  • The threshold is in pixel per second independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
  • The default threshold is set to 0,01 pixel per second.
  • The threshold can be changed by calling this method CgiStudioControl::SwipeGestureDetector:: GetInstance().SetFlickVelocityThreshold(…).
Abort
Common Properties
Type FeatStd::Optional<SwipeType::Enum>
The type of the swipe gesture.
Possible values: Begin, Swiping, End, Flick, Abort
Direction FeatStd::Optional<SwipeDirection::Enum>
The direction of the swipe.
Possible values: Left, Right, Up, Down
Back to the menu
Transform Gesture
Common Properties
Back to the menu
Logic Condition Behaviors
Check Logic Condition
Common Properties
Operation LogicConditionBehaviorOperator::Enum
Specifies logical operator that is used on values returned by the Conditions. The resulting value is returned.
Possible values: And, Or, XOr
Conditions Candera::ConditionBehaviorArrayProperty ConditionBehaviors that are combined with the ConditionOperator.
Back to the menu
Check Not Condition
Common Properties
Condition Candera::ConditionBehavior* ConditionBehavior whose value NotConditionBehavior inverts.
Back to the menu
Scroll Condition Behaviors
Check Scroll Condition
Common Properties
ScrollDirection ScrollDirection::Enum
If the value that the ScrollDirectionConditionBehavior receives matches the set ScrollDirection, it will return a positive response.
Back to the menu
Check Culture Change
Class Reference
Checks if the culture has changed and is fulfilled if this culture matches the locale.
Common Properties
Locale FeatStd::String Locale of a culture which will be checked.
Back to the menu
