Condition Behaviors
Content List
- Control Condition Behaviors
- Input Condition Behaviors
- Logic Condition Behaviors
- Scroll Condition Behaviors
- Check Culture Change
Check Animation State
Common Properties
| AnimationState | AnimationState::Enum |
State of the AnimationEvent which fulfills the Condition. Possible values: PastEnd, Start, Stop, Finish, Resume, Pause, ApplyChanges, DirectionChange |
| Sender |
SharedPointer<Candera::Animation::AnimationPlayer> | The sender of AnimationEvent. |
Check Enter or Exit
Expects an EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
| EnterOrExit | bool | True means Enter, false means Exit. |
Check Interval Switch
Common Properties
| VisualizationState | IntervalSwitchState::Enum |
If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response. Possible values: On, Off, Blinking |
Check Selection ID
Common Properties
| SelectionCondition | SelectionConditionEnum::Enum |
The condition that the ID from the ChangeSelectionEvent has to fulfill. Possible values: Same, NotSame |
Check Control State
Common Properties
| State | ControlStateEnum::Enum |
State which has to be checked. Possible values: Selected, Pressed, Enabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched |
| StateCondition | StateConditionEnum::Enum |
The condition the state has to fulfill. Possible values: ChangedToTrue, ChangedToFalse, IsTrue, IsFalse |
Check Timer
See also: Start Timer, OnTimer
Common Properties
| Sender | AbstractNodePointer | The node from which the event has to be emitted. If it is not set then all events of the proper event type are handled. |
Check Changed Value
Common Properties
| ConditionOperator | Operators::Enum |
The condition operator. Possible values: GreaterThan, LowerThan, Equal, AlmostEqual, GreaterOrEqual, LowerOrEqual |
| ConditionValue | FeatStd::Variant | The condition value. |
Check Processed Value
- Value sent in Process Value
Example Usage
Common Properties
| OperationMode | Operators::Enum |
Operation mode of behavior, defining which values should be compared. Possible values: CompareProcessedValueWithConditionValue, CompareExternalValueWithConditionValue, CompareProcessedValueWithExternalValue |
The condition value. This property is only available if |
| ValueBehavior | CgiStudioControl::ValueBehavior * |
Value behavior to be checked for changes if OperationMode requires external value. This property is only available if This property can be set in the right side of the Scene Tree Panel. |
Check Video State
Checks the state of an VideoStateEvent received from an 'Video Stream Behavior'.
Common Properties
| VideoState | VideoState::Enum |
State of the VideoEvent which fulfills the Condition. Possible values: Null, Ready, Playing, Paused, EndOfStream |
Check Click
Example Usage
Common Properties
| ClickCount | CgiStudioControl::ClickCount::Enum |
If the value ClickConditionBehavior receives matches the Click Count set, it will return a positive response. Possible values: AnyClick, SingleClick, DoubleClick, TripleClick |
| TouchId | FeatStd::UInt | The id of the finger that performed the click (the default value of 0 indicates the first finger, 1 the second ...). |
Check Drag Drop
Common Properties
| Type | FeatStd::Optional<DragDropEventType::Enum> |
The optional type of the event. If not provided then any DragDropEvent will be evaluated to true. Possible values: Drag, DragMove, Drop, DragEnter, DragLeave |
| TouchId | FeatStd::UInt | The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...). |
Check Hover
Common Properties
The optional type of the event. If not provided then any DragDropEvent will be evaluated to true. Possible values: Hover, HoverEnter, HoverLeave |
Check Key Input
Common Properties
| KeyType | CgiStudioControl::KeyType::KeyCode |
Choose type of key. Possible values: KeyCode, Modifier |
| KeyCode | Candera::KeyboardKeyCode::Enum |
Check the KeyCode of the pressed key (can also be modifier). Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 This property is only available if "KeyType" is set to "KeyCode". |
Advanced Properties
| Modifier | Candera::KeyModifierEnum::Enum |
Check a modifier key. Possible values: None, Key_Shift, Key_Alt, Key_Ctrl, Key_CapsLock, Key_Num This property is only available if "KeyType" is set to "Modifier". |
Check Pressed
Common Properties
| Sender |
Possible values: Pressed, Released, LongPressed
TouchId FeatStd::UInt The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...).Swipe Gesture
Configuration
Begin
- The threshold in pixel is independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
- The threshold can be changed by calling this method:
CgiStudioControl::SwipeGestureDetector:: GetInstance().SetSwipeDistanceThreshold(…).
Swiping
Flick
- The threshold is in pixel per second independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
CgiStudioControl::SwipeGestureDetector:: GetInstance().SetFlickVelocityThreshold(…).
Abort
Common Properties
| Type | FeatStd::Optional<SwipeType::Enum> |
The type of the swipe gesture. Possible values: Begin, Swiping, End, Flick, Abort |
| Direction | FeatStd::Optional<SwipeDirection::Enum> |
The direction of the swipe. Possible values: Left, Right, Up, Down |
Transform Gesture
Common Properties
Check Logic Condition
Common Properties
| Operation | LogicConditionBehaviorOperator::Enum |
Specifies logical operator that is used on values returned by the Conditions. The resulting value is returned. Possible values: And, Or, XOr |
| Conditions | Candera::ConditionBehaviorArrayProperty | ConditionBehaviors that are combined with the ConditionOperator. |
Check Not Condition
Common Properties
| Condition | Candera::ConditionBehavior* | ConditionBehavior whose value NotConditionBehavior inverts. |
Check Scroll Condition
Common Properties
| ScrollDirection | ScrollDirection::Enum |
If the value that the ScrollDirectionConditionBehavior receives matches the set ScrollDirection, it will return a positive response. Possible values: Vertical, Horizontal |
DescriptionChecks if the culture has changed and is fulfilled if this culture matches the locale.
Sends a ChangeSelectionEvent to the SelectionGroup. The SelectionGroup then sends a ChangeSelectionEvent to all of its receivers.
Common Properties
| Locale | FeatStd::String | Locale of a |
