Condition Behaviors
Content List
- Control Condition Behaviors
- Input Condition Behaviors
- Logic Condition Behaviors
- Scroll Condition Behaviors
- Check Culture Change
Check Animation State
Common Properties
| AnimationState | AnimationState::Enum | State of the AnimationEvent which fulfills the Condition. |
Check Enter or Exit
Expects a EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
| EnterOrExit | Bool | True means Enter, false means Exit. |
Check Interval Switch
Common Properties
| VisualizationState | IntervalSwitchState::Enum | If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response. |
Common Properties
| SelectionCondition | SelectionConditionEnum::Enum | The condition that the ID from the ChangeSelectionEvent has to fulfill. |
Check Control State
Common Properties
| State | ControlStateEnum::Enum | State which has to be checked. |
| StateCondition | StateConditionEnum::Enum | The condition the state has to fulfill. |
Check Timer
see also
Common Properties
Check changed Value
Common Properties
| ConditionOperator | Operators::Enum | The condition operator. |
| ConditionValue | FeatStd::Variant | The condition value. |
Check processed Value
- Value sent in Process Value
Example Usage
Common Properties
| OperationMode | Operators::Enum | Operation mode of behavior, defining which values should be compared: processed value with condition value (default), processed value with external value or external value with condition value |
| ValueBehavior | CgiStudioControl::ValueBehavior * | Value behavior to be checked for changes if OperationMode requires external value. |
Check Video State
Common Properties
| VideoState | VideoState::Enum | State of the VideoEvent which fulfills the Condition. |
Check Click
Example Usage
Common Properties
| ClickCount | CgiStudioControl::ClickCount::Enum | If the value ClickConditionBehavior receives matches the Click Count set, it will return a positive response.y/td> |
| TouchId | FeatStd::UInt | The id of the finger that performed the click (the default value of 0 indicates the first finger, 1 the second ...). |
Check Drag Drop
Common Properties
| Type | FeatStd::Optional<DragDropEventType::Enum> | The optional type of the event. If not provided then any DragDropEvent will be evaluated to true. |
| TouchId | FeatStd::UInt | The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...).y/td> |
Check Hover
Common Properties
Check Key Input
Common Properties
| KeyType | CgiStudioControl::KeyType::KeyCode | Choose type of key. |
| KeyCode | Candera::KeyboardKeyCode::Enum | Check the KeyCode of the pressed key (can also be modifier). |
Advanced Properties
| Modifier | Candera::KeyModifierEnum::Enum | Check a modifier key. |
Check Pressed
Common Properties
| TouchId | FeatStd::UInt | The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...). |
Swipe Gesture Condition
Configuration
Begin
- The threshold in pixel is independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
- The threshold can be changed by calling this method:
CgiStudioControl::SwipeGestureDetector:: GetInstance().SetSwipeDistanceThreshold(…).
Swiping
Flick
- The threshold is in pixel per second independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
CgiStudioControl::SwipeGestureDetector:: GetInstance().SetFlickVelocityThreshold(…).
Abort
Common Properties
| Type | FeatStd::Optional<SwipeType::Enum> | The type of the swipe gesture. |
| Direction | FeatStd::Optional<SwipeDirection::Enum> | The direction of the swipe. |
Transform Gesture
Common Properties
Check Logic Condition
Common Properties
| Operation | LogicConditionBehaviorOperator::Enum | Specifies logical operator that is used on values returned by the Conditions. The resulting value is returned. |
| Conditions | Candera::ConditionBehaviorArrayProperty | ConditionBehaviors that are combined with the ConditionOperator. |
Check Not Condition
Common Properties
| Condition | Candera::ConditionBehavior* | ConditionBehavior whose value NotConditionBehavior inverts. |
Check Scroll Condition
Common Properties
| ScrollDirection | ScrollDirection::Enum | If the value that the ScrollDirectionConditionBehavior receives matches the set ScrollDirection, it will return a positive response. |
Sends a ChangeSelectionEvent to the SelectionGroup. The SelectionGroup then sends a ChangeSelectionEvent to all of its receivers.
Common Properties
