Condition Behaviors
Content List
  • Control Condition Behaviors
    • Check Animation State
    • Check Enter or Exit
    • Check Interval Switch
    • Check Selection ID
    • Check Control State
    • Check Timer
    • Check changed Value
    • Check processed Value
    • Check Video State
  • Input Condition Behaviors
    • Check Click
    • Check Drag Drop
    • Check Hover
    • Check Key Input
    • Check Pressed
    • Swipe Gesture Condition
    • Transform Gesture
  • Logic Condition Behaviors
    • Check Logic Condition
    • Check Not Condition
  • Scroll Condition Behaviors
    • Check Scroll Condition
  • Check Culture Change
Common Properties
AnimationState AnimationState::Enum State of the AnimationEvent which fulfills the Condition.
Back to the menu
Check Enter or Exit
Expects a EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
EnterOrExit Bool True means Enter, false means Exit.
Common Properties
VisualizationState IntervalSwitchState::Enum If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response.
Back to the menu
Check Selection ID
Common Properties
SelectionCondition SelectionConditionEnum::Enum The condition that the ID from the ChangeSelectionEvent has to fulfill.
Check Control State
Common Properties
State ControlStateEnum::Enum State which has to be checked.
StateCondition StateConditionEnum::Enum The condition the state has to fulfill.
Check Timer
See also
Start Timer, OnTimer
Common Properties
Back to the menu
Check changed Value
Common Properties
ConditionOperator Operators::Enum The condition operator.
ConditionValue FeatStd::Variant The condition value.
Back to the menu
  • Value sent in Process Value
  • External value from ValueBehavior
  • Value set directly in this ValueConditionBehavior
Example Usage
Common Properties
OperationMode Operators::Enum Operation mode of behavior, defining which values should be compared:
processed value with condition value (default), processed value with external value or external value with condition value
ValueBehavior CgiStudioControl::ValueBehavior * Value behavior to be checked for changes if OperationMode requires external value.
Check Video State
Common Properties
VideoState VideoState::Enum State of the VideoEvent which fulfills the Condition.
Back to the menu
Check Click
Example Usage
Common Properties
ClickCount CgiStudioControl::ClickCount::Enum If the value ClickConditionBehavior receives matches the Click Count set, it will return a positive response.y/td>
TouchId FeatStd::UInt The id of the finger that performed the click (the default value of 0 indicates the first finger, 1 the second ...).
Back to the menu
Check Drag Drop
Common Properties
Type FeatStd::Optional<DragDropEventType::Enum> The optional type of the event. If not provided then any DragDropEvent will be evaluated to true.
TouchId FeatStd::UInt The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...).y/td>
Back to the menu
Check Hover
Common Properties
Back to the menu
Check Key Input
Common Properties
KeyType CgiStudioControl::KeyType::KeyCode Choose type of key.
KeyCode Candera::KeyboardKeyCode::Enum Check the KeyCode of the pressed key (can also be modifier).
Advanced Properties
Modifier Candera::KeyModifierEnum::Enum Check a modifier key.
Back to the menu
Check Pressed
Common Properties
Back to the menu
Configuration
Begin
  • The threshold in pixel is independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
  • The default threshold is set to 10 pixel.
  • The threshold can be changed by calling this method: CgiStudioControl::SwipeGestureDetector:: GetInstance().SetSwipeDistanceThreshold(…).
Swiping
Flick
  • The threshold is in pixel per second independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
  • The default threshold is set to 0,01 pixel per second.
  • The threshold can be changed by calling this method CgiStudioControl::SwipeGestureDetector:: GetInstance().SetFlickVelocityThreshold(…).
Abort
Common Properties
Type FeatStd::Optional<SwipeType::Enum> The type of the swipe gesture.
Direction FeatStd::Optional<SwipeDirection::Enum> The direction of the swipe.
Back to the menu
Transform Gesture
Common Properties
Back to the menu
Common Properties
Property Name Type Description Operation LogicConditionBehaviorOperator::Enum Specifies logical operator that is used on values returned by the Conditions. The resulting value is returned. Conditions Candera::ConditionBehaviorArrayProperty ConditionBehaviors that are combined with the ConditionOperator.
Back to the menu
Check Not Condition
Common Properties
Property Name Type Description Condition Candera::ConditionBehavior* ConditionBehavior whose value NotConditionBehavior inverts.
Back to the menu
Common Properties
Property Name Type Description ScrollDirection ScrollDirection::Enum If the value that the ScrollDirectionConditionBehavior receives matches the set ScrollDirection, it will return a positive response.
Back to the menu
Class Reference
Sends a ChangeSelectionEvent to the SelectionGroup. The SelectionGroup then sends a ChangeSelectionEvent to all of its receivers.
Common Properties
Property Name Type Description Locale FeatStd::String Locale of a culture. Invoking the action will set the culture active.
Back to the menu
