Condition Behaviors
Content List
- Control Condition Behaviors
- Check Animation State
- Check Enter or Exit
- Check Interval Switch
- Check Selection ID
- Check Control State
- Check Timer
- Check changed Value
- Check processed Value
- Check Video State
- Input Condition Behaviors
- Check Click
- Check Drag Drop
- Check Hover
- Check Key Input
- Check Pressed
- Swipe Gesture Condition
- Transform Gesture
- Check Click
- Logic Condition Behaviors
- Check Logic Condition
- Check Not Condition
- Scroll Condition Behaviors
- Check Scroll Condition
- Check Culture Change
Common Properties
| AnimationState | AnimationState::Enum | State of the AnimationEvent which fulfills the Condition. |
Check Enter or Exit
Expects a EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
| EnterOrExit | Bool | True means Enter, false means Exit. |
Common Properties
| VisualizationState | IntervalSwitchState::Enum | If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response. |
Common Properties
| SelectionCondition | SelectionConditionEnum::Enum | The condition that the ID from the ChangeSelectionEvent has to fulfill. |
Check Control State
Common Properties
| State | ControlStateEnum::Enum | State which has to be checked. |
| StateCondition | StateConditionEnum::Enum | The condition the state has to fulfill. |
Check Timer
See also
Common Properties
Check changed Value
Common Properties
| ConditionOperator | Operators::Enum | The condition operator. |
| ConditionValue | FeatStd::Variant | The condition value. |
- Value sent in Process Value
Example Usage
Common Properties
| OperationMode | Operators::Enum | Operation mode of behavior, defining which values should be compared: processed value with condition value (default), processed value with external value or external value with condition value |
| ValueBehavior | CgiStudioControl::ValueBehavior * | Value behavior to be checked for changes if OperationMode requires external value. |
Check Video State
Common Properties
| VideoState | VideoState::Enum | State of the VideoEvent which fulfills the Condition. |
Check Click
Example Usage
Common Properties
Check Drag Drop
Common Properties
Check Hover
Common Properties
Check Key Input
Common Properties
Advanced Properties
Check Pressed
Common Properties
Configuration
Begin
The default threshold is set to 10 pixel.
The threshold can be changed by calling this method:
CgiStudioControl::SwipeGestureDetector::
GetInstance().SetSwipeDistanceThreshold(…).
Swiping
Flick
The default threshold is set to 0,01 pixel per second.
GetInstance().SetFlickVelocityThreshold(…).
Abort
Common Properties
Transform Gesture
Common Properties
