Condition Behaviors
Content List
  • Control Condition Behaviors
    • Check Animation State
    • Check Enter or Exit
    • Check Interval Switch
    • Check Selection ID
    • Check Control State
    • Check Timer
    • Check changed Value
    • Check processed Value
    • Check Video State
  • Input Condition Behaviors
    • Check Click
    • Check Drag Drop
    • Check Hover
    • Check Key Input
    • Check Pressed
    • Swipe Gesture Condition
    • Transform Gesture
  • Logic Condition Behaviors
    • Check Logic Condition
    • Check Not Condition
  • Scroll Condition Behaviors
    • Check Scroll Condition
  • Check Culture Change
Common Properties
AnimationState AnimationState::Enum State of the AnimationEvent which fulfills the Condition.
Back to the menu
Check Enter or Exit
Expects a EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
EnterOrExit Bool True means Enter, false means Exit.
Common Properties
VisualizationState IntervalSwitchState::Enum If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response.
Back to the menu
Check Selection ID
Common Properties
SelectionCondition SelectionConditionEnum::Enum The condition that the ID from the ChangeSelectionEvent has to fulfill.
Check Control State
Common Properties
State ControlStateEnum::Enum State which has to be checked.
StateCondition StateConditionEnum::Enum The condition the state has to fulfill.
Check Timer
See also
Start Timer, OnTimer
Common Properties
Back to the menu
Check changed Value
Common Properties
ConditionOperator Operators::Enum The condition operator.
ConditionValue FeatStd::Variant The condition value.
  • Value sent in Process Value
  • External value from ValueBehavior
  • Value set directly in this ValueConditionBehavior
Example Usage
Common Properties
OperationMode Operators::Enum Operation mode of behavior, defining which values should be compared:
processed value with condition value (default), processed value with external value or external value with condition value
ValueBehavior CgiStudioControl::ValueBehavior * Value behavior to be checked for changes if OperationMode requires external value.
Check Video State
Common Properties
VideoState VideoState::Enum State of the VideoEvent which fulfills the Condition.
Back to the menu
