Condition Behaviors
Content List
- Control Condition Behaviors
- Check Animation State
- Check Enter or Exit
- Check Interval Switch
- Check Selection ID
- Check Control State
- Check Timer
- Check changed Value
- Check processed Value
- Check Video State
- Input Condition Behaviors
- Check Click
- Check Drag Drop
- Check Hover
- Check Key Input
- Check Pressed
- Swipe Gesture Condition
- Transform Gesture
- Check Click
- Logic Condition Behaviors
- Check Logic Condition
- Check Not Condition
- Scroll Condition Behaviors
- Check Scroll Condition
- Check Culture Change
Common Properties
| AnimationState | AnimationState::Enum | State of the AnimationEvent which fulfills the Condition. |
Check Enter or Exit
Expects a EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
Common Properties
Common Properties
Check Control State
Common Properties
Check Timer
See also
Common Properties
Check changed Value
Common Properties
Example Usage
Common Properties
processed value with condition value (default), processed value with external value or external value with condition value ConditionOperator Operators::Enum The condition operator. ConditionValue FeatStd::Variant The condition value. ValueBehavior CgiStudioControl::ValueBehavior * Value behavior to be checked for changes if OperationMode requires external value.
Check Video State
Common Properties
