Condition Behaviors
Content List
  • Control Condition Behaviors
    • Check Animation State
    • Check Enter or Exit
    • Check Interval Switch
    • Check Selection ID
    • Check Control State
    • Check Timer
    • Check changed Value
    • Check processed Value
    • Check Video State
  • Input Condition Behaviors
    • Check Click
    • Check Drag Drop
    • Check Hover
    • Check Key Input
    • Check Pressed
    • Swipe Gesture Condition
    • Transform Gesture
  • Logic Condition Behaviors
    • Check Logic Condition
    • Check Not Condition
  • Scroll Condition Behaviors
    • Check Scroll Condition
  • Check Culture Change
Common Properties
AnimationState AnimationState::Enum State of the AnimationEvent which fulfills the Condition.
