Condition Behaviors
Control Condition Behaviors
Check Animation State
Checks the current state of an AnimationEventanimation received(for example, play, paused, or direction changed) from anthe 'Configure and Play Animation Behavior'.behavior
and triggers an action behavior when the condition is met.
Common Properties
| AnimationState | AnimationState::Enum |
State of the AnimationEvent which fulfills the Condition. Possible values: PastEnd, Start, Stop, Finish, Resume, Pause, ApplyChanges, DirectionChange |
| Sender |
SharedPointer<Candera::Animation::AnimationPlayer> | The sender of AnimationEvent. |
Check Enter or Exit
Expects an EnterExit Event (generated by Edit Text Behavior) and returns either a positive or negative response.
Common Properties
| EnterOrExit | bool | True means Enter, false means Exit. |
Check Interval Switch
ExpectsChecks anif the visualization state from the IntervalSwitch behavior matches the configured state (On or OffOff). valueTriggers froman action when the condition is met. Can be used to check the state of a TriggerBehaviorIntervalSwitch and returns either a positive or negative response.behavior.
Common Properties
| VisualizationState | IntervalSwitchState::Enum |
If the value (received by the IntervalSwitchConditionBehavior) matches the Visualization State set, it will return a positive response. Possible values: On, Off, Blinking |
Check Selection ID
Common Properties
| SelectionCondition | SelectionConditionEnum::Enum |
The condition that the ID from the ChangeSelectionEvent has to fulfill. Possible values: Same, NotSame |
Check Control State
ExpectsChecks a Statespecific Eventstate (event generated by Controlthe StateControlState Behavior)behavior (pressed, enabled, etc.) in conjunction with the configured state and returnscondition either(e.g. apressed positiveand oris negativetrue). response.If the condition is met, an action behavior is triggered.
Common Properties
| State | ControlStateEnum::Enum |
State which has to be checked. Possible values: Selected, Pressed, Enabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched |
| StateCondition | StateConditionEnum::Enum |
The condition the state has to fulfill. Possible values: ChangedToTrue, ChangedToFalse, IsTrue, IsFalse |
Check Timer
See also: Start Timer, OnTimer
Checks ifthe time (in milliseconds) received from the StartTimer behavior. If the timer reaches the configured delay, it invokes an Action behavior. Can be used as a Timertransition reachedcondition in a certainstate value.machine.
Common Properties
| Sender | AbstractNodePointer | The node from which the event has to be emitted. If it is not set then all events of the proper event type are handled. |
Check Changed Value
Common Properties
| ConditionOperator | Operators::Enum |
The condition operator. Possible values: GreaterThan, LowerThan, Equal, AlmostEqual, GreaterOrEqual, LowerOrEqual |
| ConditionValue | FeatStd::Variant | The condition value. |
Check Processed Value
- Value sent in Process Value
Example Usage
Common Properties
| OperationMode | Operators::Enum |
Operation mode of behavior, defining which values should be compared. Possible values: CompareProcessedValueWithConditionValue, CompareExternalValueWithConditionValue, CompareProcessedValueWithExternalValue |
The condition value. This property is only available if "OperationMode" is set to "CompareProcessedValueWithConditionValue" or "CompareExternalValueWithConditionValue". |
| ValueBehavior | CgiStudioControl::ValueBehavior * |
Value behavior to be checked for changes if OperationMode requires external value. This property is only available if "OperationMode" is set to "CompareExternalValueWithConditionValue" or "CompareProcessedValueWithExternalValue". This property can be set in the right side of the Scene Tree Panel. |
Check Video State
Checks the state of an VideoStateEvent received from an 'Video Stream Behavior'.
Common Properties
| VideoState | VideoState::Enum |
State of the VideoEvent which fulfills the Condition. Possible values: Null, Ready, Playing, Paused, EndOfStream |
Input Condition Behaviors
Check Click
Example Usage
Common Properties
| ClickCount | CgiStudioControl::ClickCount::Enum |
If the value ClickConditionBehavior receives matches the Click Count set, it will return a positive response. Possible values: AnyClick, SingleClick, DoubleClick, TripleClick |
| TouchId | FeatStd::UInt | The id of the finger that performed the click (the default value of 0 indicates the first finger, 1 the second ...). |
Check Drag Drop
Common Properties
| Type | FeatStd::Optional<DragDropEventType::Enum> |
The optional type of the event. If not provided then any DragDropEvent will be evaluated to true. Possible values: Drag, DragMove, Drop, DragEnter, DragLeave |
| TouchId | FeatStd::UInt | The id of the finger that performed the drag (the default value of 0 indicates the first finger, 1 the second ...). |
Check Hover
Common Properties
The optional type of the event. If not provided then any DragDropEvent will be evaluated to true. Possible values: Hover, HoverEnter, HoverLeave |
Check Key Input
Common Properties
| KeyType | CgiStudioControl::KeyType::KeyCode |
Choose type of key. Possible values: KeyCode, Modifier |
| KeyCode | Candera::KeyboardKeyCode::Enum |
Check the KeyCode of the pressed key (can also be modifier). Possible values: Key_None, ...<all keyboard key codes>... Key_OEM8 This property is only available if "KeyType" is set to "KeyCode". |
Advanced Properties
| Modifier | Candera::KeyModifierEnum::Enum |
Check a modifier key. Possible values: None, Key_Shift, Key_Alt, Key_Ctrl, Key_CapsLock, Key_Num This property is only available if "KeyType" is set to "Modifier". |
Check Pressed
Common Properties
The optional type of the event. If not provided then any DragDropEvent will be evaluated to true. Possible values: Pressed, Released, LongPressed |
Swipe Gesture
Configuration
Begin
- The threshold in pixel is independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
- The threshold can be changed by calling this method:
CgiStudioControl::SwipeGestureDetector:: GetInstance().SetSwipeDistanceThreshold(…).
Swiping
Flick
- The threshold is in pixel per second independent of the unit size of the control local coordinate system. You do not have to take care of that transformation.
CgiStudioControl::SwipeGestureDetector:: GetInstance().SetFlickVelocityThreshold(…).
Abort
Common Properties
| Type | FeatStd::Optional<SwipeType::Enum> |
The type of the swipe gesture. Possible values: Begin, Swiping, End, Flick, Abort |
| Direction | FeatStd::Optional<SwipeDirection::Enum> |
The direction of the swipe. Possible values: Left, Right, Up, Down |
Transform Gesture
Common Properties
Logic Condition Behaviors
Check Logic Condition
Common Properties
| Operation | LogicConditionBehaviorOperator::Enum |
Specifies logical operator that is used on values returned by the Conditions. The resulting value is returned. Possible values: And, Or, XOr |
| Conditions | Candera::ConditionBehaviorArrayProperty | ConditionBehaviors that are combined with the ConditionOperator. |
Check Not Condition
Common Properties
| Condition | Candera::ConditionBehavior* | ConditionBehavior whose value NotConditionBehavior inverts. |
Scroll Condition Behaviors
Check Scroll Condition
Common Properties
| ScrollDirection | ScrollDirection::Enum |
If the value that the ScrollDirectionConditionBehavior receives matches the set ScrollDirection, it will return a positive response. Possible values: Vertical, Horizontal |
Check Culture Change
Checks if the culture has changedchanged. andThis condition is fulfilledsatisfied ifwhen thisthe culture matches the locale.culture
ID specified in the Local property, and an action behavior is subsequently invoked. Can be used to change the text culture with a button press.
Common Properties
| Locale | FeatStd::String | Locale of a culture which will be checked. |
