Behaviors and Events
This chapter explains how the Event-System in Behaviors work.
General
Behaviors communicate via Events with each other and with other components of the application. For each action a specific event is implemented. An Event can carry any data or none at all. For a custom Event simply derive from FeatStd::Event. Each Behavior can return an event-result after handling an Event in the "OnEvent"-method. Behaviors are using unique identifiers (FeatStd::Internal::Identifier) to identify the sender of an event.
        void OnPressedEvent(const PressedEvent& event, Candera::EventDispatchResult& /*dispatchResult*/)
            if (event.GetSender() == m_behavior.GetIdentifier()) {
                static_cast<void>(m_behavior.SetState(ControlStateEnum::Pressed, event.GetType() == PressedEventType::Pressed));
For a list with all Events which are used by Behaviors also check chapter Control Behaviors Events . There you can also find their readable names (names in SC).
Event-dispatching
The Behavior base-class implements DispatchEvent-functions. Events are dispatched on a Node using one of the available EventDispatchStrategy objects. An Event is passed to all OnEvent function of all Behaviors. The following dispatch strategies are available:
  • DirectEventDispatchStrategy: Only the behaviors of the node will receive the event.
  • BroadcastEventDispatchStrategy: The event will be first dispatched to the current node then to all child nodes.
  • BubbleEventDispatchStrategy: The event will be dispatched from the current node to the parent and so on until the root node is reached.
  • TunnelEventDispatchStrategy: The event will be dispatched from the root node to the current node.
Event Dispatching Diagram
This chapter gives an overview of the most important control behaviors events. Furthermore they are listed with their readable names (names in SC). For further information of how to use them in SC see chapter EventHandler Tab .
Events
Class Candera::ProcessValueEvent
ProcessValueEvent - Value Processed
AnimationEvent - Animation State Changed
Class CgiStudioControl::ArTargetEvent
ArTargetEvent - ArTargetEvent event
Class CgiStudioControl::CaretPositionChangedEvent
CaretPositionChangedEvent - Caret Position Changed
Class CgiStudioControl::ChangePropertyEvent
ChangePropertyEvent - Property Changed
Class CgiStudioControl::ChangeSelectionEvent
ChangeSelectionEvent - Selection Changed
Class CgiStudioControl::ChangeStateEvent
ChangeStateEvent - State Change Triggered
Class CgiStudioControl::ChangeValueEvent
ChangeValueEvent - Value Change Triggered
Class CgiStudioControl::ClickEvent
ClickEvent - Clicked
Class CgiStudioControl::ControlTimer::Event
ControlTimer::Event - Timer Expired
Class CgiStudioControl::DragDropEvent
DragDropEvent - Drag and Drop
Class CgiStudioControl::EnterExitEvent
OnEnterExitEvent- On Enter Exit Edit
Class CgiStudioControl::HoverEvent
HoverEvent - Hovered
Member CgiStudioControl::IntervalSwitchBehavior::OnEvent (const FeatStd::Event &event, Candera::EventDispatchResult &dispatchResult)
to handle.
Class CgiStudioControl::IntervalVisualizationEvent
IntervalVisualizationEvent - Interval State Changed
Class CgiStudioControl::PoiUpdateEvent
PoiUpdateEvent - Poi update
Class CgiStudioControl::PressedEvent
PressedEvent - Pressed
Class CgiStudioControl::RegisterSelectionEvent
RegisterSelectionEvent - Register Selection
Class CgiStudioControl::ScrollableDirectionChangedEvent
ScrollableDirectionChangedEvent - Scroll Direction Changed
Class CgiStudioControl::StateEvent
StateEvent - State Changed
Class CgiStudioControl::TrackingEvent
TrackingEvent - Tracking event
Class CgiStudioControl::ValueChangedEvent
ValueChangedEvent - Value Changed
Class CgiStudioControl::VideoControlEvent
VideoControlEvent - Video Control Event
Class CgiStudioControl::VideoStateEvent
VideoStateEvent - Video changed
