Action Behaviors
Contents List
    Animation Action Behaviors
      Configure and Play Animation Control Action Behaviors
        Breadcrumb Action Change Selection Conditional Action Change Drawer State Set Focus Interpolate Value Action Interval Switch Action Keyboard Action Map Action Map Location Action Navigation Action MenuScreenAction Page Indicator Action Set Control State Start Timer Custom Action Behaviors
          Click To Message Copy Textures Gesture Action Behaviors
            Transform Gesture Property Action Behaviors
              Set Appearance Send Value as Event
              Set Color Set Image Render Child Nodes Set Text Set Text Style Enable Rendering Send Value Changed As Event Scroll Action Behaviors
                Send Scrollable Events Streaming Action Behaviors
                  Configure and Play Stream Transition Action Behaviors
                    Perform Transition Request Transition Request Send Virtual Key
                      Class Reference
                      Common Properties
                      TargetNode
                      Candera::AbstractNodePointer The Node which is modified. If not set, then the node where the behavior is attached to, will be modified.
                      Animation Candera::Animation::AnimationPlayer The animation that should be controlled.
                      Action CgiStudioControl::AnimationAction::Enum Action that shall be executed on the animation:
                      Start, Stop, Pause, Resume, Speedup, Finish, Change.
                      Direction CgiStudioControl::AnimationDirection::Enum Playback direction of the animation.
                      Speed FeatStd::Float Playback speed of the animation.
                      RepeatMode
                      FeatStd::Optional<AnimationRepeatMode::Enum>
                      Defines how the animation shall be repeated.
                      Possible values: Replay, Bounce
                      RepeatCount
                      FeatStd::Optional<FeatStd::UInt32> Count of replays. If set to 0 the animation loops till it gets stopped.
                      EventDispatchStrategy
                      EventDispatchStrategyType::Enum The way the event gets sent.
                      DedicatedBehavior
                      Candera::Behavior*
                      A dedicated process value behavior that will receive the animation event.
                      Advanced Properties
                      FinishTime
                      FeatStd::Optional<Candera::Animation::WorldTimeType>
                      Finish time in milliseconds.
                      This property is only available if the property "Action" is checked and set to "Finish".
                      IncreaseSdpeed
                      FeatStd::Optional<FeatStd::Float>
                      Increased playback speed of the animation. If set and Play is executed again during playback, animation will speed up (can be used only once per animation!). Zero means immediate position seek.
                      This property is only available in the following configuration:
                      an "Animation" is configured
                      "Action" is set to "Start" or "SpeedUp"
                      "RepeatMode" is not checked
                      "RepeatCount" is not checked
                      IncreasedSpeedRevertMargin
                      Defines trailing part of animation (in milliseconds) that will be played at normal speed again. If not set, speedup will last until the end of animation.
                      This property is only available if property "IncreasedSpeed" is checked.
                      SequenceStartTime
                      FeatStd::Optional<Candera::Animation::SequenceTimeType>
                      The start point  of the animation. [ms]
                      This property is only available if an animation is set in the property "Animation".
                      SequenceDurationTime
                      Back to the menu
                      Breadcrumb Action
                      Class Reference
                      An Action Behavior that sends breadcrumb action events. It allows you to control a Breadcrumb or a node with a Breadcrumb Behavior attached. This behavior is available for 2D scenes only.
                      • SetPath - sets elements contained in the breadcrumb.
                      • BackToPrevious - calls breadcrumb to create a path without the last element from the ones existing in the breadcrumb.
                      • BackToElement - the action will be called if the element exists in the breadcrumb. It will create a path from beginning to the selected element from the breadcrumb.
                      Common Properties
                      Action that will be called on the breadcrumb.
                      Possible values: SetPath, BackToPrevious, BackToElement
                      Path String
                      The path with a separator that will be passed when the action is called. The separator is defined in the receiving breadcrumb.
                      BreadcrumbNode Candera::AbstractNodePointer Breadcrumb Control Node.
                      Back to the menu
                      Change Selection
                      Class Reference
                      Sends a ChangeSelectionEvent to the SelectionGroup. The SelectionGroup then sends a ChangeSelectionEvent to all of its receivers. The event is emitted via BubbleEventDispatchStrategy to a SelectionGroupBehavior.
                      Common Properties
                      Back to the menu
                      Conditional Action
                      Class Reference
                      Common Properties
                      Actions Candera::ActionBehaviorArrayProperty The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition.
                      Postpone bool Set this flag to true to perform the actions after all other actions have been performed. This may become necessary if the actions alter the state and other conditional actions may be invoked due to that changed state.
                      Change Drawer State
                      Class Reference
                      An Action that allows to hide/show the contents of a Drawer or a Node with a Drawer Behavior attached. This behavior is available for 2D scenes only.
                      Common Properties
                      Action CgiStudioControl::DrawerEventType::Enum
                      The action that should be performed.
                      Possible values: Open, Close, Toggle
                      Advanced Properties
                      DedicatedBehavior Candera::Behavior* A dedicated behavior that will receive the event. Only available when Dispatch Strategy is set to 'DedicatedBehavior'.
                      Set Focus
                      Sets the Keyboard Focus to a control.
                      Common Properties
                      Action Behavior which sends specific action event allows you control the InterpolateProcessValueBehavior.
                      Common Properties
                      Action InterpolateValueAction::Enum
                      Action that will be called on the interpolate value behavior.
                      Possible values: SetMode, Reset
                      AnimationMode InterpolationAnimationMode::Enum
                      Use the InterpolationAnimationMode to select the desired type of animation in the InterpolateProcessValueBehavior.
                      Common Properties
                      TargetNode Candera::AbstractNodePointer The Node which is mofified.modified. If not set, then the node where the behavior is attached to, will be modified.
                      SwitchState IntervalSwitchState::Enum
                      SwitchState: IntervalSwitchState: Enum
                      Keyboard Action
                      Keyboard behavior manages the Keyboard control.
                      Common Properties
                      Action KeyboardAction::Enum
                      Keyboard action to execute.
                      Possible values: Open, Close, Toggle, InvokeKey, ShiftLayout, SwitchLayout, SetConfiguration
                      KeyboardNode Candera::AbstractNodePointer Keyboard Node.
                      AutoHideKeyboard bool Should keyboard be hidden when node loses focus and show again when node is focused?
                      Advanced Properties
                      Layout String
                      Layout name.
                      This property is only available if "Action" is set to "Open", "ShiftLayout" or "SwitchLayout".
                      Notifier
                      Event sender. If NotifiererNotifier is invalid then default is node which has attached behavior.
                      This property is only available if "Action" is set to "InvokeKey".
                      TextNode
                      Text node.
                      ImageNode
                      ImageNode node.
                      FocusNode
                      FocusNode node.
                      Configuration
                      String
                      Keyboard configuration.
                      This property is only available if "Action" is set to "SetConfiguration".
                      Map Action
                      Common Properties
                      MapNode Candera::AbstractNodePointer Map node on which this action should be called.
                      Action MapAction::Enum
                      Action that will be called on the MapBehavior.
                      Possible values: Reset, Pan, Zoom, Tilt, LookAt, CenterAtLocation, Rotate, SetRotation, ChangeTheme.
                      Latitude Float GPS latitude at which the camera looks at.
                      Longitude Float GPS longitude at which the camera looks at.
                      Zoomlevel Float Determines how close is the camera to the ground level.
                      Bearing Float Determines the bearing angle at which the camera is rotated relative to north.
                      Tilt Float Determines the tilt angle at which the camera looks at specified location.
                      SyleUrl String Theme that describes how the map looks like and how is styled.
                      Back to the menu
                      Map Location Action
                      Common Properties
                      TargetNode Candera::AbstractNodePointer Map node on which this action should be called.
                      Latitude Float Latitude of the location.
                      LongitudeLayout Float Longitude of the location.
                      Name
                      String
                      Human-readable name of the location.
                      Address String Address of the location (usually street name).
                      Navigation Action
                      Common Properties
                      Action MapNavigationAction::Enum
                      Action that will be called on the MapNode.
                      Possible values: StartNavi, StopNavi, ReverseRoute
                      MenuScreenAction
                      Class Reference
                      Action Behavior which sends menuscreenMenuScreen action event allows you control the menu screen. The operations it can do are: add, dletedelete element and change screen page. This behavior is available for 2D scenes only.
                      Common Properties
                      Action MenuScreenAction::Enum
                      Action that will be called on the menu screen.
                      Possible values: EditMode, Delete, SwapRight, SwapLeft, AddScreen, DeleteLastScreen
                      Class Reference
                      Common Properties
                      Action PageIndicatorAction::Enum
                      Action to perform on PageIndicator (change number of pages, change active index)
                      Possible values: ChangeActiveIndex, ChangeNumberOfPages, ActiveDot
                      Value FeatStd::Int32 Value to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
                      ChangeValue ChangeValue::Enum
                      Type of value change to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
                      Possible values: ChangeActiveIndex, ChangeNumberOfPages, ActivateDot
                      PageIndicatorNode Candera::AbstractNodePointer PageIndicator node to communicate with.
                      RenderNode
                      Candera::AbstractNodePointer Render node for current PageIndicatorElement (used only for PageIndicatorElement)
                      NormalImagePropertyProvider
                      CgiStudioControl::PropertyProviderBehavior*
                      Property Behavior which contains the image of normal (unselected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement).
                      ActiveImagePropertyProvider
                      Property Behavior which contains the image of active (selected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement).
                      Set Control State
                      Class Reference
                      Sets the state of a control by sending an Event to a control considering the selected EventDispatchStrategy.
                      Supports: Any Node with a Handle Control State attached.
                      Used in: SpinBox
                      Example Usage
                      Common Properties
                      State ControlStateEnum::Enum
                      Choose the State which has to be changed to True or False.
                      Possible values: Selected, Pressed, Ennabled,Enabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched
                      ChangeTo bool Switch the state of the control to True or False.
                      UseForChildNodes
                      bool
                      State change will also affect all child nodes of the target node
                      EventDispatchStrategy EventDispatchStrategyType::Enum
                      Advanced Properties
                      This property is only available when Dispatch Strategy is set to 'DedicatedBehavior'.
                      Start Timer
                      Class Reference
                      Used in: ScrollBar
                      See also: Check Timer, OnTimer
                      Example Usage
                      Common Properties
                      Delay FeatStd::UInt32 Delay time for the timer event (specification in milliseconds)
                      Back to the menu
                      Click to Message
                      Common Properties
                      Identifier String The identifier of the click message.
                      Copy Textures
                      Common Properties
                      Appearance
                      SharedPointer<Candera::Appearance> The appearance to set on the node.
                      Back to the menu
                      Transform Gesture
                      Pan
                      • Use the Maximum/Minimum properties for X/Y to limit the movement of the position to a certain area.
                      • Use the Pan mode selector to limit the transformation to X or Y axis.
                      • Deactivate the Pan to disallow any position change.
                      Pinch
                      • Use the Maximum/Minimum properties to limit the absolute scale of the node.
                      • Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to non-uniform scaling where both axis are scaled individually.
                      • Deactivate the Pinch to disallow any scale change.
                      Rotate
                      • Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to none uniform scaling where both axis are scaled individually.
                      Example Usage
                      Common Properties
                      Pan FeatStd::Optional<PanGestureType::Enum> The pan transformation of a pan gesture is applied to the node.
                      Pinch FeatStd::Optional<PinchGestureType::Enum> The scale transformation of a pinch gesture is applied to the node.
                      Rotate bool The rotate transformation of a rotate gesture is applied to the node.
                      Advanced Properties
                      PanMinimumX FeatStd::Optional<FeatStd::Float>
                      The minimum pan X value.
                      This property is only available if panning in x direction is enabled.
                      PanMinimumY FeatStd::Optional<FeatStd::Float>
                      The minimum pan Y value.
                      This property is only available if panning in xyy direction is enabled.
                      PanMaximumY FeatStd::Optional<FeatStd::Float>
                      The maximum pan X value.
                      PanMaximumX FeatStd::Optional<FeatStd::Float>
                      The maximum pan Y value.
                      This property is only available if panning in y direction is enabled.
                      PinchMinimumX FeatStd::Optional<FeatStd::Float>
                      The minimum pinch X value.
                      This property is only available if pinching in x direction is enabled.
                      PinchMinimumY FeatStd::Optional<FeatStd::Float>
                      The minimum pinch Y value.
                      This property is only available if pinching in xyy direction is enabled.
                      PinchMaximumX FeatStd::Optional<FeatStd::Float>
                      The maximum pinch X value.
                      PinchMaximumY FeatStd::Optional<FeatStd::Float>
                      The maximum pinch Y value.
                      This property is only available if pinching in y direction is enabled.
                      PinchMinimumUniform FeatStd::Optional<FeatStd::Float>
                      The minimum pinch uniform value.
                      This property is only available if pinching is enabled and configured for ScaleUniform.
                      PinchMaximumUniform FeatStd::Optional<FeatStd::Float>
                      The maximum pinch uniform value.
                      RotateMinimum FeatStd::Optional<FeatStd::Float>
                      The minimum rotate value
                      This property is only available if rotation is enabled.
                      RotateMaximum FeatStd::Optional<FeatStd::Float>
                      The maximum rotate value
                      Back to the menu
                      Set Appearance
                      When triggered, sets an appearance on a node. This behavior is available for 3D scenes only.
                      Common Properties
                      PropertyReference
                      PropertyReference::Enum
                      Possible values: Self, Other
                      Appearance
                      PropertyProvider
                      This property is only available if the PropertyReference is set to "Other".
                      UseAsDefault
                      bool
                      True if the image shall be used as default image.
                      Back to the menu
                      Send Value as Event
                      Class Reference
                      Example Usage
                      Common Properties
                      How the event value shall be handled by the receiving.
                      Possible values: Absolute, Relative
                      Advanced Properties
                      Value FeatStd::Variant
                      The value of the event which gets sent.
                      This property is only available when the PropertyReference is set to "Self".
                      PropertyProvider PropertyProviderBehavior*
                      Property provider which contains the value which has to be set on the send value as event action.
                      It is only available when the PropertyReference is set to "Other".
                      It is only available if the EventDispatchStrategy is set to "DedicatedBehavior".
                      Back to the menu
                      Set Color
                      Class Reference
                      Supports
                      • Controls:
                        • Text
                        • Text Value
                      • Effects:
                        • BitmapBrushColorBlend (as used in TextNode)
                        • GlBitmapBrushColorMaskBlend
                        • GlDropShadowBitmapBrushColorBlend
                        • GlFlipBitmapBrushColorBlend
                        • GlOutlineBitmapBrushColorBlend
                        • SolidColorBrushColorBlend (as used in SolidColorNode)
                      Example Usage
                      Common Properties
                      Property Reference PropertyReference::Enum
                      Color Candera::Color
                      The color to set.
                      This property is only available if PropertyReference is set to "Self".
                      Use For Child Nodes bool If set to true, also child nodes are affected by this action.
                      Levels UInt8
                      Number of levels to step down through groups. Default is zero.
                      This property is only available if UseForChildNodes is checked.
                      TargetNode Candera::AbstractNodePointer The node which is modified. If not set, then the node where the behavior is attached to, will be modified.
                      Advanced Properties
                      Property Provider PropertyProviderBehavior*
                      Property Provider which contains the color which has to be set on the effect.
                      It is only available if PropertyReference is set to"Other".
                      Back to the menu
                      Set Image
                      Class Reference
                      When triggered, sets an image on a node.
                      See also: Set Text, Set Color, Set Control State
                      Example Usage
                      Common Properties
                      Target Node Candera::AbstractNodePointer The node which gets the given image. If not set, then the node where the behavior is attached too, will be modified.
                      Image SharedPointer<Image2D>
                      Use As Default bool True if the image shall be used as default image.
                      Advanced Properties
                      It is only available if PropertyReference is set to "Other"
                      Render Child Nodes
                      Class Reference
                      If invoked by a TriggerBehavior, enables/disables Child nodes corresponding to the received value and the behavior settings.
                      Example Usage
                      Common Properties
                      TargetNode Candera::AbstractNodePointer The node which switches child nodes. If not set, then the node where the behavior is attached to, will modified its children.
                      Index Float Index of the child node which shall be active.
                      Levels UInt8 Number of levels to step down through groups. Default is zero.
                      Set Text
                      Class Reference
                      Example Usage
                      Common Properties
                      PropertyReference PropertyReference::Enum
                      Text String
                      The text that will be set to the Text Node.
                      This property is available if the PropertyReference is set to "Self".
                      Advanced Properties
                      It is only available if the PropertyReference is configured with "Other".
                      Set Text Style
                      An Action Behavior that sends change style action. It allows to control the style of text Nodes.
                      Common Properties
                      Style SharedPointer<TextRendering::SharedStyle> The Style that will be set to the Text Node.
                      Enable Rendering
                      Class Reference
                      Example Usage
                      Common Properties
                      TargetNode Candera::AbstractNodePointer The node which gets the visibility flag. If not set, then the node where the behavior is attached to, will be modified.
                      Visible bool According to this value, the affected node gets rendered or not.
                      Back to the menu
                      Example Usage
                      Common Properties
                      Value
                      FeatStd::Variant
                      Sender
                      Candera::AbstractNodePointer The node for which the event shall be emitted. If it is not set then the TargetNode or Node (if TargetNode is not set) will be taken instead.
                      c
                      TargetNode
                      Candera::AbstractNodePointer The node on which the for which the EventDispatchStrategy will be applied. If it is not set then the Node will be taken instead.
                      PropertyReference
                      Target Node Candera::AbstractNodePointer The target node to which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior.
                      Advanced Properties
                      DedicatedBehavior
                      It is only available if the PropertyReference is set to "Other".
                      Back to the menu
                      Class Reference
                      Enables scrolling a scrollable behavior (e.g. a ListBehavior) to a specific target position that is specified by the scrolling Type and the Value.
                      Common Properties
                      Direction Optional<ScrollDirection::Enum>
                      The direction in which the scroll should be performed.
                      Type ScrollableEventType::Enum The scrolling type. It can be either relative or absolute scrolling in combination of being either itemwise or pagewise scrolling.
                      Value Float The number of items or pages scrolled to.
                      TreatAnimationDurationZeroAsNotSet
                      bool
                      When the AnimationDuration is set to 0 it will not be used as a valid animation duration. If a immediate scroll to the target position is intended this flag has to be set to false.
                      AnimationDuration
                      UInt32
                      Duration of the scrolling animation.
                      Advanced Properties
                      DedicatedBehavior
                      Behavior*
                      Back to the menu
                      Class Reference
                      Starts, stops, pauses, resumes video streams by emitting an VideoControl Event. These Events can be received by Video Stream Behaviors.
                      Common Properties
                      TargetNode Candera::AbstractNodePointer The node which receives the event. If not set, then the node where the behavior is attached to, will receive it.
                      Action VideoControl::Enum
                      Action that will be executed on the stream.
                      Possible values: Play, Replay, Pause, Resume, Stop.
                      The strategy in which the event is sent.
                      Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior.
                      Advanced Properties
                      Back to the menu
                      Perform Transition Requests
                      Class Reference
                      See also: Transition Request
                      Example Usage
                      Common Properties
                      Requests ArrayProperty<TransitionRequestBehavior *> The first TransitionRequestBehavior in the request-set.
                      Variant String Default Variant which will be used for attached Requests. Not that Requests can also have their own Variant.
                      Back to the menu
                      Transition Request
                      Class Reference
                      Example Usage
                      Common Properties
                      RequestType CgiStudioControl::TransitionRequestType::Enum
                      Whether a node should be Activated or Deactivated by the transition. Currently running transitions on a node can be ended using the Finish transition type.
                      Possible values: Activate, Deactivate, Finish
                      Variant FeatStd::String Variant which will be used for this Request.
                      Identifier Candera::Transitions::Identifier The Node or Scene that will be subject to the transition.
                      Back to the menu
                      Send Virtual Key
                      Common Properties
                      KeyType KeyType::Enum
                      Choose the type of the key. With KeyCode you can select any key.
                      Possible values: KeyCode, Modifier
                      Modifier
                      KeyModifierEnum::Enum
                      Modifier Key (e.g. Shift)
                      KeyCode
                      KeyboardKeyCode::Enum
                      Back to the menu
                      Set Culture
                      Class Reference
                      Common Properties
                      Locale FeatStd::String Locale of a culture. Invoking the action will set the culture active.
                      Back to the menu
