Action Behaviors
Contents List
- Animation Action Behaviors
- Control Action Behaviors
- Custom
- Gesture Action Behaviors
- Property Action Behaviors
- Scroll Action Behaviors
- Streaming Action Behaviors
- Transition Action Behaviors
Configure and Play Animation
Common Properties
| TargetNode |
Candera::AbstractNodePointer | The Node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
| Animation | Candera::Animation::AnimationPlayer | The animation that should be controlled. |
| Action | CgiStudioControl::AnimationAction::Enum | Action that shall be executed on the animation: Start, Stop, Pause, Resume, Speedup, Finish, Change. |
| Direction | CgiStudioControl::AnimationDirection::Enum | Playback direction of the animation. |
| Speed | FeatStd::Float | Playback speed of the animation. |
| RepeatMode |
FeatStd::Optional<AnimationRepeatMode::Enum> |
Defines how the animation shall be repeated. Possible values: Replay, Bounce |
| RepeatCount |
FeatStd::Optional<FeatStd::UInt32> | Count of replays. If set to 0 the animation loops till it gets stopped. |
| EventDispatchStrategy |
EventDispatchStrategyType::Enum | The way the event gets sent. |
| DedicatedBehavior |
Candera::Behavior* |
A dedicated process value behavior that will receive the animation event. This property can be set in the right side of the Scene Tree Panel. |
Advanced Properties
| FinishTime |
FeatStd::Optional<Candera::Animation::WorldTimeType> |
Finish time in milliseconds. This property is only available if the property "Action" is checked and set to "Finish". |
| IncreaseSdpeed |
FeatStd::Optional<FeatStd::Float> |
Increased playback speed of the animation. If set and Play is executed again during playback, animation will speed up (can be used only once per animation!). Zero means immediate position seek. This property is only available in the following configuration: an "Animation" is configured "Action" is set to "Start" or "SpeedUp" "RepeatMode" is not checked "RepeatCount" is not checked |
| IncreasedSpeedRevertMargin |
Defines trailing part of animation (in milliseconds) that will be played at normal speed again. If not set, speedup will last until the end of animation. This property is only available if property "IncreasedSpeed" is checked. |
| SequenceStartTime |
FeatStd::Optional<Candera::Animation::SequenceTimeType> |
The start point of the animation. [ms] This property is only available if an animation is set in the property "Animation". |
| SequenceDurationTime |
The duration of the animation. [ms] This property is only available if an animation is set in the property "Animation". |
Breadcrumb Action
An Action Behavior that sends breadcrumb action events. It allows you to control a Breadcrumb or a node with a Breadcrumb Behavior attached. This behavior is available for 2D scenes only.
Common Properties
Action that will be called on the breadcrumb. Possible values: SetPath, BackToPrevious, BackToElement |
| Path | String |
The path with a separator that will be passed when the action is called. The separator is defined in the receiving breadcrumb. |
| BreadcrumbNode | Candera::AbstractNodePointer | Breadcrumb Control Node. |
Change Selection
Sends a ChangeSelectionEvent to the SelectionGroup. The SelectionGroup then sends a ChangeSelectionEvent to all of its receivers. The event is emitted via BubbleEventDispatchStrategy to a SelectionGroupBehavior.
Common Properties
Conditional Action
Common Properties
| Actions | Candera::ActionBehaviorArrayProperty | The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition. |
| Postpone | bool | Set this flag to true to perform the actions after all other actions have been performed. This may become necessary if the actions alter the state and other conditional actions may be invoked due to that changed state. |
Change Drawer State
An Action that allows to hide/show the contents of a Drawer or a Node with a Drawer Behavior attached. This behavior is available for 2D scenes only.
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
| Action | CgiStudioControl::DrawerEventType::Enum |
The action that should be performed. Possible values: Open, Close, Toggle |
| EventDispatchStrategy | CgiStudioControl::EventDispatchStrategyType::Enum |
The way the event gets sent. Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior |
Advanced Properties
| DedicatedBehavior | Candera::Behavior* | A dedicated behavior that will receive the event. Only available when Dispatch Strategy is set to 'DedicatedBehavior'. |
Set Focus
Sets the Keyboard Focus to a control.
Common Properties
Interpolate Value Action
Action Behavior which sends specific action event allows you control the InterpolateProcessValueBehavior.
Common Properties
| Action | InterpolateValueAction::Enum |
Action that will be called on the interpolate value behavior. Possible values: SetMode, Reset |
| AnimationMode | InterpolationAnimationMode::Enum |
Use the InterpolationAnimationMode to select the desired type of animation in the InterpolateProcessValueBehavior. Possible values: SpeedBased, TimeBased, Instant |
Interval Switch Action
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is mofified. If not set, then the node where the behavior is attached to, will be modified. |
| SwitchState | IntervalSwitchState::Enum |
SwitchState: IntervalSwitchState: Enum Possible values: On, Off, Blinking |
Keyboard Action
Keyboard behavior manages the Keyboard control.
Common Properties
| Action | KeyboardAction::Enum |
Keyboard action to execute. Possible values: Open, Close, Toggle, InvokeKey, ShiftLayout, SwitchLayout, SetConfiguration |
| KeyboardNode | Candera::AbstractNodePointer | Keyboard Node. |
| AutoHideKeyboard | bool | Should keyboard be hidden when node loses focus and show again when node is focused? |
Advanced Properties
| Layout | String |
Layout name. This property is only available if "Action" is set to "Open", "ShiftLayout" or "SwitchLayout". |
| Notifier |
Event sender. If Notifierer is invalid then default is node which has attached behavior. This property is only available if "Action" is set to "InvokeKey". |
| TextNode |
Text node. This property is only available if "Action" is set to "InvokeKey". |
| ImageNode |
ImageNode node. This property is only available if "Action" is set to "InvokeKey". |
| FocusNode |
FocusNode node. This property is only available if "Action" is set to "InvokeKey". |
| Configuration |
String |
Keyboard configuration. This property is only available if "Action" is set to "SetConfiguration". |
Map Action
Common Properties
| MapNode | Candera::AbstractNodePointer | Map node on which this action should be called. |
| Action | MapAction::Enum |
Action that will be called on the MapBehavior. Possible values: Reset, Pan, Zoom, Tilt, LookAt, CenterAtLocation, Rotate, SetRotation, ChangeTheme. |
| Latitude | Float | GPS latitude at which the camera looks at. |
| Longitude | Float | GPS longitude at which the camera looks at. |
| Zoomlevel | Float | Determines how close is the camera to the ground level. |
| Bearing | Float | Determines the bearing angle at which the camera is rotated relative to north. |
| Tilt | Float | Determines the tilt angle at which the camera looks at specified location. |
| SyleUrl | String | Theme that describes how the map looks like and how is styled. |
Map Location Action
Common Properties
| TargetNode | Candera::AbstractNodePointer | Map node on which this action should be called. |
| Latitude | Float | Latitude of the location. |
| LongitudeLayout | Float | Longitude of the location. |
| Name |
String |
Human-readable name of the location. |
| Address | String | Address of the location (usually street name). |
Navigation Action
Common Properties
| Action | MapNavigationAction::Enum |
Action that will be called on the MapNode. Possible values: StartNavi, StopNavi, ReverseRoute |
MenuScreenAction
Action Behavior which sends menuscreen action event allows you control the menu screen. The operations it can do are: add, dlete element and change screen page. This behavior is available for 2D scenes only.
Common Properties
| Action | MenuScreenAction::Enum |
Action that will be called on the menu screen. Possible values: EditMode, Delete, SwapRight, SwapLeft, AddScreen, DeleteLastScreen |
Page Indicator Action
Common Properties
| Action | PageIndicatorAction::Enum |
Action to perform on PageIndicator (change number of pages, change active index) Possible values: ChangeActiveIndex, ChangeNumberOfPages, ActiveDot |
| Value | FeatStd::Int32 | Value to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions) |
| ChangeValue | ChangeValue::Enum |
Type of value change to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions) Possible values: ChangeActiveIndex, ChangeNumberOfPages, ActivateDot |
| PageIndicatorNode | Candera::AbstractNodePointer | PageIndicator node to communicate with. |
| RenderNode |
Candera::AbstractNodePointer | Render node for current PageIndicatorElement (used only for PageIndicatorElement) |
| NormalImagePropertyProvider |
CgiStudioControl::PropertyProviderBehavior* |
Property Behavior which contains the image of normal (unselected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement). This property can be set in the right side of the Scene Tree panel. |
| ActiveImagePropertyProvider |
Property Behavior which contains the image of active (selected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement). This property can be set in the right side of the Scene Tree panel. |
Set Control State
Supports: Any Node with a Handle Control State attached.
Used in: SpinBox
Example Usage
Common Properties
| State | ControlStateEnum::Enum |
Choose the State which has to be changed to True or False. Possible values: Selected, Pressed, Ennabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched |
| ChangeTo | bool | Switch the state of the control to True or False. |
| UseForChildNodes |
bool |
State change will also affect all child nodes of the target node |
| EventDispatchStrategy | EventDispatchStrategyType::Enum |
Advanced Properties
A dedicated behavior that will receive the event. This property is only available when Dispatch Strategy is set to 'DedicatedBehavior'. |
Start Timer
Used in: ScrollBar
See also: Check Timer, OnTimer
Example Usage
Common Properties
| Delay | FeatStd::UInt32 | Delay time for the timer event (specification in milliseconds) |
Custom
Click to Message
Common Properties
| Identifier | String | The identifier of the click message. |
Copy Textures
Common Properties
| Appearance |
SharedPointer<Candera::Appearance> | The appearance to set on the node. |
Transform Gesture Action
Pan
Pinch
Rotate
Example Usage
Common Properties
| Pan | FeatStd::Optional<PanGestureType::Enum> | The pan transformation of a pan gesture is applied to the node. |
| Pinch | FeatStd::Optional<PinchGestureType::Enum> | The scale transformation of a pinch gesture is applied to the node. |
| Rotate | bool | The rotate transformation of a rotate gesture is applied to the node. |
Advanced Properties
| PanMinimumX | FeatStd::Optional<FeatStd::Float> |
The minimum pan X value. This property is only available if panning in x direction is enabled. |
| PanMinimumY | FeatStd::Optional<FeatStd::Float> |
The minimum pan Y value. This property is only available if panning in xy direction is enabled. |
| PanMaximumY | FeatStd::Optional<FeatStd::Float> |
The maximum pan X value. This property is only available if panning in x direction is enabled. |
| PanMaximumX | FeatStd::Optional<FeatStd::Float> |
The maximum pan Y value. This property is only available if panning in y direction is enabled. |
| PinchMinimumX | FeatStd::Optional<FeatStd::Float> |
The minimum pinch X value. This property is only available if pinching in x direction is enabled. |
| PinchMinimumY | FeatStd::Optional<FeatStd::Float> |
The minimum pinch Y value. This property is only available if pinching in xy direction is enabled. |
| PinchMaximumX | FeatStd::Optional<FeatStd::Float> |
The maximum pinch X value. This property is only available if pinching in x direction is enabled. |
| PinchMaximumY | FeatStd::Optional<FeatStd::Float> |
The maximum pinch Y value. This property is only available if pinching in y direction is enabled. |
| PinchMinimumUniform | FeatStd::Optional<FeatStd::Float> |
The minimum pinch uniform value. This property is only available if pinching is enabled and configured for ScaleUniform. |
| PinchMaximumUniform | FeatStd::Optional<FeatStd::Float> |
The maximum pinch uniform value. This property is only available if pinching is enabled and configured for ScaleUniform. |
| RotateMinimum | FeatStd::Optional<FeatStd::Float> |
The minimum rotate value This property is only available if rotation is enabled. |
| RotateMaximum | FeatStd::Optional<FeatStd::Float> |
The maximum rotate value This property is only available if rotation is enabled. |
Set Appearance
When triggered, sets an appearance on a node. This behavior is available for 3D scenes only.
Common Properties
| PropertyReference |
PropertyReference::Enum |
| Appearance |
The appearance to set on the node. This property is only available if the PropertyReference is set to "Self". |
| PropertyProvider |
Property Behavior which contains the color which has to be set on the effect. This property is only available if the PropertyReference is set to "Other". |
| UseAsDefault |
bool |
True if the image shall be used as default image. |
Send Value as Event
Example Usage
Common Properties
How the event value shall be handled by the receiving. Possible values: Absolute, Relative |
Advanced Properties
| Value | FeatStd::Variant |
The value of the event which gets sent. This property is only available when the PropertyReference is set to "Self". |
Property provider which contains the value which has to be set on the send value as event action. This property can be set in the right side of the Scene Tree panel. It is only available when the PropertyReference is set to "Other". |
| DedicatedBehavior | Candera::ProcessValueBehavior* |
The dedicated process value behavior that will receive the change value event. This property can be set in the right side of the Scene Tree panel. It is only available if the EventDispatchStrategy is set to "DedicatedBehavior". |
Set Color
Supports
- Controls:
- Text
- Text Value
- Effects:
- GlBitmapBrushColorMaskBlend
- GlFlipBitmapBrushColorBlend
Example Usage
Common Properties
| Property Reference | PropertyReference::Enum |
| Color | Candera::Color |
The color to set. This property is only available if PropertyReference is set to "Self". |
| Use For Child Nodes | bool | If set to true, also child nodes are affected by this action. |
| Levels | UInt8 |
Number of levels to step down through groups. Default is zero. This property is only available if UseForChildNodes is checked. |
| TargetNode | Candera::AbstractNodePointer | The node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
Advanced Properties
| Property Provider | PropertyProviderBehavior* |
Property Provider which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree panel. It is only available if PropertyReference is set to"Other". |
Set Image
When triggered, sets an image on a node.
See also: Set Text, Set Color, Set Control State
Example Usage
Common Properties
| Target Node | Candera::AbstractNodePointer | The node which gets the given image. If not set, then the node where the behavior is attached too, will be modified. |
| Image | SharedPointer<Image2D> |
The image to set on the effect. This property is only available for 2D scenes. |
| Use As Default | bool | True if the image shall be used as default image. |
Advanced Properties
The image to set on the appearance. This property is only available for 3D scenes. |
Property Provider which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree panel. It is only available if PropertyReference is set to "Other" |
Render Child Nodes
If invoked by a TriggerBehavior, enables/disables Child nodes corresponding to the received value and the behavior settings.
Example Usage
Common Properties
| TargetNode | Candera::AbstractNodePointer | The node which switches child nodes. If not set, then the node where the behavior is attached to, will modified its children. |
| Index | Float | Index of the child node which shall be active. |
| OperationMode | OperationMode::Enum |
When set to MultipleNodes, EnableChildNodes will enable the first N children of Group Node. When Operation Mode is set to SingleNode, only the Nth node is enabled. Possible values: MultipleNodes, SingleNode |
| Levels | UInt8 | Number of levels to step down through groups. Default is zero. |
| NormalizeValue | bool | If set to true, the received value has to be between 0 and 1 and will be mapped to the number of children. Otherwise the value has to be the index of the child. |
Set Text
Example Usage
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified. |
| PropertyReference | PropertyReference::Enum |
| Text | String |
The text that will be set to the Text Node. This property is available if the PropertyReference is set to "Self". |
Advanced Properties
Property Behavior which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree panel. It is only available if the PropertyReference is configured with "Other". |
Set Text Style
An Action Behavior that sends change style action. It allows to control the style of text Nodes.
Common Properties
| Style | SharedPointer<TextRendering::SharedStyle> | The Style that will be set to the Text Node. |
Enable Rendering
Example Usage
Common Properties
| TargetNode | Candera::AbstractNodePointer | The node which gets the visibility flag. If not set, then the node where the behavior is attached to, will be modified. |
| Visible | bool | According to this value, the affected node gets rendered or not. |
Send Value Changed As Event
Example Usage
Common Properties
| Value |
FeatStd::Variant |
The value of the event which gets sent. This property is only available if PropertyReference is set to "Self". |
| Sender |
Candera::AbstractNodePointer | The node for which the event shall be emitted. If it is not set then the TargetNode or Node (if TargetNode is not set) will be taken instead. |
c |
| TargetNode |
Candera::AbstractNodePointer | The node on which the for which the EventDispatchStrategy will be applied. If it is not set then the Node will be taken instead. |
| PropertyReference |
| Target Node | Candera::AbstractNodePointer | The target node to which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior. |
Advanced Properties
| DedicatedBehavior |
Property Behavior which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree panel. It is only available if the PropertyReference is set to "Other". |
Send Scrollable Event
Enables scrolling a scrollable behavior (e.g. a ListBehavior) to a specific target position that is specified by the scrolling Type and the Value.
Common Properties
| Target Node | Candera::AbstractNodePointer | The node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
| Direction | Optional<ScrollDirection::Enum> |
The direction in which the scroll should be performed. Possible values: Vertical, Horizontal |
| Type | ScrollableEventType::Enum | The scrolling type. It can be either relative or absolute scrolling in combination of being either itemwise or pagewise scrolling. |
| Value | Float | The number of items or pages scrolled to. |
| TreatAnimationDurationZeroAsNotSet |
bool |
When the AnimationDuration is set to 0 it will not be used as a valid animation duration. If a immediate scroll to the target position is intended this flag has to be set to false. |
| AnimationDuration |
UInt32 |
Duration of the scrolling animation. |
Advanced Properties
| DedicatedBehavior |
Behavior* |
Configure and Play Stream
Common Properties
| TargetNode | Candera::AbstractNodePointer | The node which receives the event. If not set, then the node where the behavior is attached to, will receive it. |
| Action | VideoControl::Enum |
Action that will be executed on the stream. Possible values: Play, Replay, Pause, Resume, Stop. |
The strategy in which the event is sent. Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior. |
Advanced Properties
A dedicated behavior that will receive the event. This property can be set in the right side of the Scene Tree panel. It is only available if the EventDispatchStrategy is set to "DedicatedBehavior". |
Perform Transition Requests
See also: Transition Request
Example Usage
Common Properties
| Requests | ArrayProperty<TransitionRequestBehavior *> | The first TransitionRequestBehavior in the request-set. |
| Variant | String | Default Variant which will be used for attached Requests. Not that Requests can also have their own Variant. |
Transition Request
Example Usage
Common Properties
| RequestType | CgiStudioControl::TransitionRequestType::Enum |
Whether a node should be Activated or Deactivated by the transition. Currently running transitions on a node can be ended using the Finish transition type. Possible values: Activate, Deactivate, Finish |
| Variant | FeatStd::String | Variant which will be used for this Request. |
| Identifier | Candera::Transitions::Identifier | The Node or Scene that will be subject to the transition. |
Send Virtual Key
Common Properties
| KeyType | KeyType::Enum |
Choose the type of the key. With KeyCode you can select any key. Possible values: KeyCode, Modifier |
| Modifier |
KeyModifierEnum::Enum |
| KeyCode |
KeyboardKeyCode::Enum |
Set Culture
Common Properties
