Action Behaviors
Contents List
- Animation Action Behaviors
- Control Action Behaviors
- Custom
- Gesture Action Behaviors
- Property Action Behaviors
- Scroll Action Behaviors
- Streaming Action Behaviors
- Transition Action Behaviors
Configure and Play Animation
Common Properties
| TargetNode |
Candera::AbstractNodePointer |
The Node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
| Animation | Candera::Animation::AnimationPlayer | The animation that should be controlled. |
| Action | CgiStudioControl::AnimationAction::Enum | Action that shall be executed on the animation: Start, Stop, Pause, Resume, Speedup, Finish, Change. |
| Direction | CgiStudioControl::AnimationDirection::Enum | Playback direction of the animation. |
| Speed | FeatStd::Float | Playback speed of the animation. |
| RepeatMode |
FeatStd::Optional<AnimationRepeatMode::Enum> |
Defines how the animation shall be repeated. Possible values: Replay, Bounce |
| RepeatCount |
FeatStd::Optional<FeatStd::UInt32> | Count of replays. If set to 0 the animation loops till it gets stopped. |
| EventDispatchStrategy |
EventDispatchStrategyType::Enum | The way the event gets sent. |
| DedicatedBehavior |
Candera::Behavior* |
A dedicated process value behavior that will receive the animation event. This property can be set in the right side of the Scene Tree Panel. |
Advanced Properties
| FinishTime |
FeatStd::Optional<Candera::Animation::WorldTimeType> |
Finish time in milliseconds. This property is only available if the property "Action" is checked and set to "Finish". |
| IncreaseSdpeed |
FeatStd::Optional<FeatStd::Float> |
Increased playback speed of the animation. If set and Play is executed again during playback, animation will speed up (can be used only once per animation!). Zero means immediate position seek. This property is only available in the following configuration: an "Animation" is configured "Action" is set to "Start" or "SpeedUp" "RepeatMode" is not checked "RepeatCount" is not checked |
| IncreasedSpeedRevertMargin |
Defines trailing part of animation (in milliseconds) that will be played at normal speed again. If not set, speedup will last until the end of animation. This property is only available if property "IncreasedSpeed" is checked. |
| SequenceStartTime |
FeatStd::Optional<Candera::Animation::SequenceTimeType> |
The start point of the animation. [ms] This property is only available if an animation is set in the property "Animation". |
| SequenceDurationTime |
The duration of the animation. [ms] This property is only available if an animation is set in the property "Animation". |
Breadcrumb Action
An Action Behavior that sends breadcrumb action events. It allows you to control a Breadcrumb or a node with a Breadcrumb Behavior attached.
Common Properties
Action that will be called on the breadcrumb. Possible values: SetPath, BackToPrevious, BackToElement |
| Path |
The path with a separator that will be passed when the action is called. The separator is defined in the receiving breadcrumb. |
| BreadcrumbNode | Candera::AbstractNodePointer | Breadcrumb Control Node. |
Change selection
Sends a ChangeSelectionEvent to the SelectionGroup. The SelectionGroup then sends a ChangeSelectionEvent to all of its receivers. The event is emitted via BubbleEventDispatchStrategy to a SelectionGroupBehavior.
Common Properties
Conditional Action
Common Properties
| Actions | Candera::ActionBehaviorArrayProperty | The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition. |
| Postpone | bool | Set this flag to true to perform the actions after all other actions have been performed. This may become necessary if the actions alter the state and other conditional actions may be invoked due to that changed state. |
Change Drawer State
An Action that allows to hide/show the contents of a Drawer or a Node with a Drawer Behavior attached.
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
| Action | CgiStudioControl::DrawerEventType::Enum |
The action that should be performed. Possible values: Open, Close, Toggle |
| EventDispatchStrategy | CgiStudioControl::EventDispatchStrategyType::Enum |
The way the event gets sent. Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior |
Advanced Properties
| DedicatedBehavior | Candera::Behavior* | A dedicated behavior that will receive the event. Only available when Dispatch Strategy is set to 'DedicatedBehavior'. |
Set Focus
Sets the Keyboard Focus to a control.
Common Properties
Interpolate Value Action
Action Behavior which sends specific action event allows you control the InterpolateProcessValueBehavior.
Common Properties
| Action | InterpolateValueAction::Enum |
Action that will be called on the interpolate value behavior. Possible values: SetMode, Reset |
| AnimationMode | InterpolationAnimationMode::Enum |
Use the InterpolationAnimationMode to select the desired type of animation in the InterpolateProcessValueBehavior. Possible values: SpeedBased, TimeBased, Instant |
Interval Switch Action
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is mofified. If not set, then the node where the behavior is attached to, will be modified. |
| SwitchState | IntervalSwitchState::Enum |
SwitchState: IntervalSwitchState: Enum Possible values: On, Off, Blinking |
Keyboard Action
Keyboard behavior manages the Keyboard control.
Common Properties
| Action | KeyboardAction::Enum |
Keyboard action to execute. Possible values: Open, Close, Toggle, InvokeKey, ShiftLayout, SwitchLayout, SetConfiguration |
| KeyboardNode | Candera::AbstractNodePointer | Keyboard Node. |
| AutoHideKeyboard | bool | Should keyboard be hidden when node loses focus and show again when node is focused? |
Advanced Properties
| Layout | String |
Layout name. This property is only available if "Action" is set to "Open", "ShiftLayout" or "SwitchLayout". |
| Notifier |
Event sender. If Notifierer is invalid then default is node which has attached behavior. This property is only available if "Action" is set to "InvokeKey". |
| TextNode |
Text node. This property is only available if "Action" is set to "InvokeKey". |
| ImageNode |
ImageNode node. This property is only available if "Action" is set to "InvokeKey". |
| FocusNode |
FocusNode node. This property is only available if "Action" is set to "InvokeKey". |
| Configuration |
String |
Keyboard configuration. This property is only available if "Action" is set to "SetConfiguration". |
Map Action
Common Properties
| MapNode | Candera::AbstractNodePointer | Map node on which this action should be called. |
| Action | MapAction::Enum |
Action that will be called on the MapBehavior. Possible values: Reset, Pan, Zoom, Tilt, LookAt, CenterAtLocation, Rotate, SetRotation, ChangeTheme. |
| Latitude | Float | GPS latitude at which the camera looks at. |
| Longitude | Float | GPS longitude at which the camera looks at. |
| Zoomlevel | Float | Determines how close is the camera to the ground level. |
| Bearing | Float | Determines the bearing angle at which the camera is rotated relative to north. |
| Tilt | Float | Determines the tilt angle at which the camera looks at specified location. |
| SyleUrl | String | Theme that describes how the map looks like and how is styled. |
Map Location Action
Common Properties
| TargetNode | Candera::AbstractNodePointer | Map node on which this action should be called. |
| Latitude | Float | Latitude of the location. |
| LongitudeLayout | Float | Longitude of the location. |
| Name |
String |
Human-readable name of the location. |
| Address | String | Address of the location (usually street name). |
Navigation Action
Common Properties
| Action | MapNavigationAction::Enum |
Action that will be called on the MapNode. Possible values: StartNavi, StopNavi, ReverseRoute |
MenuScreenAction
Action Behavior which sends menuscreen action event allows you control the menu screen. The operations it can do are: add, dlete element and change screen page.
Common Properties
| Action | MenuScreenAction::Enum |
Action that will be called on the menu screen. Possible values: EditMode, Delete, SwapRight, SwapLeft, AddScreen, DeleteLastScreen |
Page Indicator Action
It is also used by PageIndicatorElement (ActivateDot) to activate clicked element and to define visual properties of the PageIndicatorElement.
Common Properties
| Action | PageIndicatorAction::Enum |
Action to perform on PageIndicator (change number of pages, change active index) Possible values: ChangeActiveIndex, ChangeNumberOfPages, ActiveDot |
| Value | FeatStd::Int32 | Value to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions) |
| ChangeValue | ChangeValue::Enum |
Type of value change to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions) Possible values: ChangeActiveIndex, ChangeNumberOfPages, ActivateDot |
| PageIndicatorNode | Candera::AbstractNodePointer | PageIndicator node to communicate with. |
| RenderNode |
Candera::AbstractNodePointer | Render node for current PageIndicatorElement (used only for PageIndicatorElement) |
| NormalImagePropertyProvider |
CgiStudioControl::PropertyProviderBehavior* |
Property Behavior which contains the image of normal (unselected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement). This property can be set in the right side of the Scene Tree panel. |
| ActiveImagePropertyProvider |
Property Behavior which contains the image of active (selected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement). This property can be set in the right side of the Scene Tree panel. |
Set Control State
SupportsSupports:
Used Inin:
Example Usage
Common Properties
| State | ControlStateEnum::Enum |
Choose the State which has to be changed to True or False. Possible values: Selected, Pressed, Ennabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched |
| ChangeTo | bool | Switch the state of the control to True or False. |
| UseForChildNodes |
bool |
State change will also affect all child nodes of the target node |
| EventDispatchStrategy | EventDispatchStrategyType::Enum |
| TargetNode | Candera::AbstractNodePointer | The |
Advanced Properties
A dedicated behavior that will receive the event. This property is only available when Dispatch Strategy is set to 'DedicatedBehavior'. |
See also
Set Image, Set Text, Set Color
Start Timer
Used Inin:
Example Usage
Common Properties
| Delay | FeatStd::UInt32 | Delay time for the timer event (specification in milliseconds) |
Custom
Click to Message
Common Properties
This
Transform Gesture Action
Use the transform gesture action to apply the transformation of a transform gesture event (pan, pinch and rotate) to a node. You can use tisthis behavior as an action or directly without an event handler.
Pan
Pinch
Rotate
Example Usage
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is |
| Pan | FeatStd::Optional<PanGestureType::Enum> | The pan transformation of a pan gesture is applied to the node. |
Advanced Properties
The minimum pan X value.
This property is only available if panning in x direction is enabled.
PanMinimumY FeatStd::Optional<FeatStd::Float>The minimum pan Y value.
This property is only available if panning in xy direction is enabled.
PanMaximumY FeatStd::Optional<FeatStd::Float>The maximum pan X value.
PanMaximumX FeatStd::Optional<FeatStd::Float>The maximum pan Y value.
This property is only available if panning in y direction is enabled.
PinchMinimumX FeatStd::Optional<FeatStd::Float>The minimum pinch X value.
This property is only available if pinching in x direction is enabled.
PinchMinimumY FeatStd::Optional<FeatStd::Float>The minimum pinch Y value.
This property is only available if pinching in xy direction is enabled.
PinchMaximumX FeatStd::Optional<FeatStd::Float>The maximum pinch X value.
PinchMaximumY FeatStd::Optional<FeatStd::Float>The maximum pinch Y value.
This property is only available if pinching in y direction is enabled.
PinchMinimumUniform FeatStd::Optional<FeatStd::Float>The minimum pinch uniform value.
This property is only available if pinching is enabled and configured for ScaleUniform.
PinchMaximumUniform FeatStd::Optional<FeatStd::Float>The maximum pinch uniform value.
RotateMinimum FeatStd::Optional<FeatStd::Float>The minimum rotate value
This property is only available if rotation is enabled.
RotateMaximum FeatStd::Optional<FeatStd::Float>The maximum rotate value
Send Value as Event
Example Usage
Common Properties
| TargetNode |
Possible values: Self, Other
How the event value shall be handled by the receiving.
Possible values: Absolute, Relative
Possible values: DedicatedDirect, BehaviorBroadcast, ProcessValueBehaviorBubble, *Tunnel,
DedicatedBehavior
TargetNode
The target node which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior.
DedicatedBehavior
Candera::ProcessValueBehavior*
Advanced Properties
| Value |
The value of the event which gets sent.
This property is only available when the PropertyReference is set to "Self".
PropertyProviderProperty provider which contains the value which has to be set on the send value as event action.
It is only available when the PropertyReference is set to "Other".
DedicatedBehavior Candera::ProcessValueBehavior*The dedicated process value behavior that will receive the change value event.
It is only available if the EventDispatchStrategy is set to "DedicatedBehavior".
Set Color
See also
Set Image, Set Text, Set Control State
Supports
- Controls:
- Text
- Text Value
- Effects:
- GlBitmapBrushColorMaskBlend
- GlFlipBitmapBrushColorBlend
Example Usage
Common Properties
| Property Reference | PropertyReference::Enum |
| Color | Candera::Color |
The color to set. This property is only available if PropertyReference is set to "Self". |
| Use For Child Nodes | If set to true, also child nodes are affected by this action. | |
| Levels | UInt8 |
Number of levels to step down through groups. Default is zero. This property is only available if UseForChildNodes is checked. |
| TargetNode | Candera::AbstractNodePointer | The node which is modified. If not set, then the node where the behavior is attached |
Advanced Properties
| Property Provider |
Property Provider which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree panel. It is only available if PropertyReference is set to"Other". |
Set Image
When triggered, sets an image on a node.
See alsoalso:
Set Text, Set Color, Set Control State
Example Usage
Common Properties
Image SharedPointer<Image2D>The image to set on the effect.
Use As Default bool True if the image shall be used as default image.Advanced Properties
The image to set on the appearance. This property is only available for 3D scenes. |
This property Texturecan Candera::MemoryManagement::SharedPointer<Candera::TextureImage>be Theset imagein the right side of the Scene Tree panel.
It is only available if PropertyReference is set to set"Other"
Render Child Nodes Action
If invoked by a TriggerBehavior, enables/disables Child nodes corresponding to the received value and the behavior settings.
Example Usage
Common Properties
| TargetNode |
Levels UInt8 Number of levels to step down through groups. Default is zero.Set Text
See alsoalso:
Set Image, Set Color, Set Control State
Example Usage
Common Properties
Text StringThe text that will be set to the Text Node.
This property is available if the PropertyReference is set to "Self".
Advanced Properties
Property Behavior which contains the color which has to be set on the effect. This property can be set in the right side of the Scene Tree panel. It is only available if the PropertyReference is configured with "Other". |
Set Text Style
An Action Behavior that sends change style action. It allows to control the style of text Nodes.
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified. |
| Style | The Style that will be set to the Text Node. |
Enable Rendering
Example Usage
Common Properties
Send Value Changed As Event
Example Usage
Common Properties
| Value |
SenderCandera::AbstractNodePointer The node for which the event shall be emitted. If it is not set then the TargetNode or Node (if TargetNode is not set) will be taken instead. EventDispatchStrategy
c
TargetNodeCandera::AbstractNodePointer The node on which the for which the EventDispatchStrategy will be applied. If it is not set then the Node will be taken instead. PropertyReference
Target Node Candera::AbstractNodePointer The target node to which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior.Advanced Properties
PropertyProvider PropertyProviderBehavior*Property Behavior which contains the color which has to be set on the effect.
It is only available if the PropertyReference is set to "Other".
Send Scrollable Event
Enables scrolling a scrollable behavior (e.g. a ListBehavior) to a specific target position that is specified by the scrolling Type and the Value.
Common Properties
| Target Node |
Direction Optional<ScrollDirection::Enum>
The direction in which the scroll should be performed.
Type ScrollableEventType::Enum The scrolling type. It can be either relative or absolute scrolling in combination of being either itemwise or pagewise scrolling. ValueUInt32
Duration of the scrolling animation. EventDispatchStrategy
Advanced Properties
Behavior*
Configure and Play Stream
Common Properties
Action that will be executed on the stream.
Possible values: Play, Replay, Pause, Resume, Stop.
EventDispatchStrategy EventDispatchStrategyType::EnumThe strategy in which the event is sent.
Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior.
Advanced Properties
A dedicated behavior that will receive the event,event.
This property can be set in casethe DedicatedBehaviorright side of the Scene Tree panel.
It is only available if the EventDispatchStrategy is selected.set to "DedicatedBehavior".
Perform Transition Requests
SeeUsed also
Descriptiona node should be activated or deactivated by the transition framework when the associated TransitionActionBehavior is triggered.
See also: Transition Request
Example Usage
Common Properties
| Requests | ArrayProperty<TransitionRequestBehavior *> | The first TransitionRequestBehavior in the request-set. |
| Variant | String | Default Variant which will be used for attached Requests. Not that Requests can also have their own Variant. |
Transition Request
Example Usage
Common Properties
| RequestType | CgiStudioControl::TransitionRequestType::Enum |
Whether a node should be Activated or Deactivated by the transition. Currently running transitions on a node can be ended using the Finish transition type. Possible values: Activate, Deactivate, Finish |
| Variant | FeatStd::String | Variant which will be used for this Request. |
| Identifier | Candera::Transitions::Identifier | The Node or Scene that will be subject to the transition. |
Send Virtual Key
Common Properties
Choose the type of the key. With KeyCode you can select any key.
Possible values: KeyCode, Modifier
ModifierKeyModifierEnum::Enum
Modifier Key (e.g. Shift)
KeyCodeKeyboardKeyCode::Enum
Set Culture
Common Properties
