Action Behaviors
Contents List
- Animation Action Behaviors
- Control Action Behaviors
- Custom
- Gesture Action Behaviors
- Property Action Behaviors
- Scroll Action Behaviors
- Streaming Action Behaviors
- Transition Action Behaviors
Configure and Play Animation
Class ReferenceDescription
Common Properties
| Animation | Candera::Animation::AnimationPlayer | The animation that should be controlled. |
| Action | CgiStudioControl::AnimationAction::Enum | Action that shall be executed on the animation: Start, Stop, Pause, Resume, Speedup, Finish, Change. |
| Direction | CgiStudioControl::AnimationDirection::Enum | Playback direction of the animation. |
| Speed | FeatStd::Float | Playback speed of the animation. |
Advanced Properties
| RepeatMode | CgiStudioControl::RepeatMode::Enum | Defines how the animation shall be repeated. |
| RepeatCount | CgiStudioControl::RepeatCount::Enum | Count of replays. If set to 0 the animation loops till it gets stopped. |
| EventDispatchStrategy | CgiStudioControl::EventDispatchStrategyType::Enum | The way the event gets sent. |
| DedicatedBehavior | Candera::Behavior* | A dedicated behavior that will receive the animation event. |
| FinishTime | Candera::Animation::WorldTimeType | Finish time in milliseconds. |
| IncreasedSpeed | FeatStd::Float | Increased playback speed of the animation. If set and Play is executed again during playback, animation will speed up (can be used only once per animation!). Zero means immediate position seek. |
| IncreasedSpeedRevertMargin | Candera::Animation::WorldTimeType | Defines trailing part of animation (in milliseconds) that will be played at normal speed again. If not set, speedup will last until the end of animation. |
| SequenceStartTime | Candera::Animation::SequenceTimeType | The start point of the animation. [ms] |
| SequenceDurationTime | Candera::Animation::SequenceTimeType | The duration of the animation. [ms] |
Breadcrumb Action
An Action Behavior that sends breadcrumb action events. It allows you to control a Breadcrumb or a node with a Breadcrumb Behavior attached.
Common Properties
| Action | CgiStudioControl::AnimationAction::Enum | Action that shall be executed on the animation. |
| Path | CgiStudioControl::AnimationDirection::Enum | The Path that will be set when the action is triggered. Only available for 'Set Path'. The path-separator is defined in the receiving breadcrumb. |
| BreadcrumbNode | Candera::AbstractNodePointer | Breadcrumb Control Node. |
Change selection
Checks if the culture has changed and is fulfilled if this culture matches the locale.
Common Properties
Conditional Action
Class Reference</smallDescription
Common Properties
| Actions | Candera::ActionBehaviorArrayProperty | The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition. |
| Postpone | bool | Set this flag to true to perform the actions after all other actions have been performed. This may become nessecary if the actions alter the state and other conditional actions may be invoked due to that changed state. |
Change Drawer State
An Action that allows to hide/show the contents of a Drawer or a Node with a Drawer Behavior attached.
Common Properties
| Action | CgiStudioControl::DrawerEventType::Enum | The action that should be performed. |
Advanced Properties
| DedicatedBehavior | Candera::Behavior* | A dedicated behavior that will receive the event. Only available when Dispatch Strategy is set to 'DedicatedBehavior'. |
Set Focus
Sets the Keyboard Focus to a control.
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is modified. If not set, then the node where the bihaviors is attached to, will be modified. |
Interpolate Value Action
Action Behavior which sends specific action event allows you control the InterpolateProcessValueBehavior.
Common Properties
| Action | ActionTYpe | The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified. |
| AnimationMode | AnimationModeType | The Style that will be set to the Text Node. |
| TargetNode | TargetNodeType | The Node to which the event should be sent. |
Interval Switch Action
Common Properties
| TargetNode | TargetNodeType | The Node which is mofified. If not set, then the node where the behavior is attached to, will be modified. |
| SwitchState | SwitchStateType | SwitchState: IntervalSwitchState: Enum |
Keyboard Action
Keyboard action to manage keyboard control.
Common Properties
| Action | ActionType | Keyboard action to execute. |
| KeyboardNode | KeyboardNodeType | Keyboard Node. |
| Layout | LayoutType | Layout name. |
| AutoHideKeyboard | AutoHideKeyboardType | Should keyboard be hidden when node loses focus and show again when node is focused? |
Map Action
Common Properties
| MapNode | MapNodeType | Map node on which this action should be called. |
| Action | ActionType | Action that will be called on the MapBehavior. |
| Latitude | LatitudeType | GPS latitude at which the camera looks at. |
| Longitude | LongitudeType | GPS longitude at which the camera looks at. |
| Zoomlevel | ZoomLevelType | Determines how close is the camera to the groud level. |
| Bearing | BearingType | Determines the bearing angle at which the camera is rotated relative to north. |
| Tilt | TiltType | Determines the tilt angle at which the camera looks at specified location. |
| SyleUrl | StyleUrlType | Theme that describes how the map looks like and how is styled. |
Map Location Action
Common Properties
| TargetNode | TargetNodeType | Map node on which this action should be called. |
| Latitude | LatitudeType | Latitude of the location. |
| LongitudeLayout | LongitudeType | Longitude of the location. |
| Address | AddressType | Address of the location (usually street name). |
Navigation Action
Common Properties
| Actoin | ActionType | Action that will be called on the MapNode. |
MenuScreenAction
Action Behavior which sends menuscreen action event allows you control the menu screen. The operations it can do are: add, dlete element and change screen page.
Common Properties
| Action | MenuScreenAction::Enum | Action that will be called on the menu screen. |
Page Indicator Action
It is also used by PageIndicatorElement (ActivateDot) to activate clicked element and to define visual properties of the PageIndicatorElement.
Common Properties
| Action | PageIndicatorAction::Enum | Action to perform on PageIndicator (change number of pages, change active index) |
| PageIndicatorNode | Candera::AbstractNodePointer | PageIndicator node to communicate with. |
| Value | FeatStd::Int32 | Value to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions) |
| ChangeValue | ChangeValue::Enum | Type of value change to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions) |
| RenderNode | Candera::AbstractNodePointer | Render node for current PageIndicatorElement. |
| NormalImagePropertyProvider | Behavior* | Property Behavior which contains the image of normal (unselected) PageIndicatorElement. |
| ActiveImagePropertyProvider | Behavior* | Property Behavior which contains the image of active (selected) PageIndicatorElement. |
Set Control State
Supports
- Any Node with a Handle Control State attached.
Used In
Example Usage
Common Properties
| State | Candera::AbstractNodePointer | Choose the State which has to be changed to True or False. |
| ChangeTo | bool | Switch the state of the control to True or False. |
| EventDispatchStrategy | Candera::AbstractNodePointer | The way the event gets sent |
Advanced Properties
See also
Set Image, Set Text, Set Color
Start Timer
Used In
Example Usage
Common Properties
| Delay | FeatStd::UInt32 | Delay time for the timer event (specification in milliseconds) |
| Target Node | Candera::AbstractNodePointer | The target node to which the events are routed from the source node. |
See also
Custom
Click to Message
Common Properties
Copy Texture
When triggered, the texutures of an appearance are used on the appearance of the node. SAMPLE USAGE ONLY.
| Appearance | AppearanceType | The appearance to set on the node |
| TargetNode | TargetNodeType | The node which gets the given image. If not set,then the node where the behavior is attached to, will be modified. |
Transform Gesture Action
Use the transform gesture action to apply the transformation of a transform gesture event (pan, pinch and rotate) to a node. You can use tis behavior as an action or directly without an event handler.
Pan
Pinch
Rotate
Example Usage
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is manipulated. If not set, then the node where the behavior is attached to, will will be manipulated |
| Pan | FeatStd::Optional<PanGestureType::Enum> | The pan transformation of a pan gesture is applied to the node. |
| PanMinimumX | FeatStd::Optional<FeatStd::Float> | The minimum pan X value. |
| PanMinimumY | FeatStd::Optional<FeatStd::Float> | The minimum pan Y value. |
| PanMaximumY | FeatStd::Optional<FeatStd::Float> | The maximum pan X value. |
| PanMaximumX | FeatStd::Optional<FeatStd::Float> | The maximum pan Y value. |
| Pinch | FeatStd::Optional<PinchGestureType::Enum> | The scale transformation of a pinch gesture is applied to the node. |
| PinchMinimumX | FeatStd::Optional<FeatStd::Float> | The minimum pinch X value. |
| PinchMinimumY | FeatStd::Optional<FeatStd::Float> | The minimum pinch Y value. |
| PinchMaximumX | FeatStd::Optional<FeatStd::Float> | The maximum pinch X value. |
| PinchMaximumY | FeatStd::Optional<FeatStd::Float> | The maximum pinch Y value. |
| PinchMinimumUniform | FeatStd::Optional<FeatStd::Float> | The minimum pinch uniform value. |
| PinchMaximumUniform | FeatStd::Optional<FeatStd::Float> | The maximum pinch uniform value. |
| Rotate | bool | The rotate transformation of a rotate gesture is applied to the node. |
| RotateMinimum | FeatStd::Optional<FeatStd::Float> | The minimum rotate value |
| RotateMaximum | FeatStd::Optional<FeatStd::Float> | The maximum rotate value |
Set Appearance
Common Properties
| PropertyReference | CgiStudioControl::PropertyReference | The appearance to set on the node. |
| Appearance | Candera::MemoryManagement::SharedPointer<Candera::Appearance>" | The color to set. |
Send Value as Event
Example Usage
Common Properties
| Value | Variant | The value of the event which gets sent. |
| Change Value | Enum (Absolute, Relative) | How the event value shall be handled by the receiving. |
| Event Dispatch Strategy | Enum (Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior) | The way the event gets sent. |
| Dedicated Behavior | ProcessValueBehavior * | |
| Target Node | AbstractNodePointer | The target node which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior. |
| DedicatedBehavior | Candera::ProcessValueBehavior* | The dedicated process value behavior that will receive the change value event. |
Advanced Properties
| PropertyProvider | "Behavior* | Property provider which contains the value which has to be set on the send value as event action. |
Set Appearance
Common Properties
Set Color
See also
Set Image, Set Text, Set Control State
Sets the color of a node with a Color effect attached (e.g. BitmapBrushColorBlend or SolidColorBrush).
Supports
- Controls:
- Text
- Text Value
- Effects:
- GlBitmapBrushColorMaskBlend
- GlFlipBitmapBrushColorBlend
Example Usage
Common Properties
| Property Reference | Enum (Self, Other) | Choose how the property gets set. Via own property or from another Behavior. |
| Color | Color | The color to set. |
| Use For Child Nodes | Bool | If set to true, also child nodes are affected by this action. |
| Levels | UInt8 | Number of levels to step down through groups. Default is zero. |
| Target Node | Node2D * | The node which is modified. If not set, then the node where the behavior is attached too, will be modified. |
Advanced Properties
| Property Provider | Behavior * | Property Provider which contains the color which has to be set on the effect. |
See also
Set Text, Set Color, Set Control State
When triggered, sets an image on a node.
Example Usage
Common Properties
| Image | SharedPointer<Image2D> | The image to set on the effect. |
| Use As Default | Bool | True if the image shall be used as default image. |
| Target Node | AbstractNodePointer | The node which gets the given image. If not set, then the node where the behavior is attached too, will be modified. |
Advanced Properties
| Texture | Candera::MemoryManagement::SharedPointer<Candera::TextureImage> | The image to set on the appearance. |
Render Child Nodes Action
If invoked by a TriggerBehavior, enables/disables Child nodes corresponding to the received value and the behavior settings.
Example Usage
Common Properties
| Index | Float | Index of the child node which shall be active. |
| Operation Mode | Enum (MultipleNodes, SingleNode) | When set to MultipleNodes, EnableChildNodes will enable the first N children of Group Node. When Operation Mode is set to SingleNode, only the Nth node is enabled. |
| Normalize Value | Bool | If set to true, the received value has to be between 0 and 1 and will be mapped to the number of children. Otherwise the value has to be the index of the child. |
| Target Node | Node 2D* | The node which switches child nodes. If not set, then the node where the behavior is attached to, will modified its children. |
Set Text
See also
Set Image, Set Color, Set Control State
Example Usage
Common Properties
| Text | String | The text that will be set to the Text Node. |
| Target Node | AbstractNodePointer | The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified. |
Advanced Properties
| Property Provider | Behavior * | Property Behavior which contains the color which has to be set on the effect. |
Set Text Style
An Action Behavior that sends change style action. It allows to control the style of text Nodes.
Common Properties
| Target Node | TargetNodeType | The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified. |
| Style | StyleType | The Style that will be set to the Text Node. |
Enable Rendering
Example Usage
Common Properties
| Visible | Bool | According to this value, the affected node gets rendered or not. |
| Target Node | AbstractNodePointer | The node which gets the visibility flag. If not set, then the node where the behavior is attached to, will be modified. |
Send Value Changed As Event
Example Usage
Common Properties
| Target Node | AbstractNodePointer | The target node to which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior. |
Send Scrollable Event
Enables scrolling a scrollable behavior (e.g. a ListBehavior) to a specific target position that is specified by the scrolling Type and the Value.
Common Properties
| Direction | ScrollDirection::Enum | The direction in which the scroll should be performed. |
| Type | ScrollableEventType::Enum | The scrolling type. It can be either relative or absolute scrolling in combination of being either itemwise or pagewise scrolling. |
| Value | FeatStd::Float | The number of items or pages scrolled to. |
| Animated | Bool | If set, the scrolling will be animated. Otherwise, the scrollable behavior will imediatelly jump to the target position. |
Configure and Play Stream
Common Properties
| Action | VideoControl::Enum | The action that will be executed on the stream. Options are Play, Replay, Pause, Resume, Stop. |
| EventDispatchStrategy | CgiStudioControl::EventDispatchStrategyType::Enum | The strategy in which the event is sent. Options are Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior. |
| TargetNode | Candera::AbstractNodePointer | The node which receives the event. If not set, then the node where the behavior is attached to, will receive it. |
| DedicatedBehavior | Candera::Behavior* | A dedicated behavior that will receive the event, in case DedicatedBehavior EventDispatchStrategy is selected. |
Perform Transition Requests
See also
Example Usage
Common Properties
| Requests | ArrayProperty<TransitionRequestBehavior *> | The first TransitionRequestBehavior in the request-set. |
| Variant | String | Default Variant which will be used for attached Requests. Not that Requests can also have their own Variant. |
Transition Request
Example Usage
Common Properties
| RequestType | CgiStudioControl::TransitionRequestType::Enum | Whether a node should be Activated or Deactivated by the transition. Currently running transitions on a node can be ended using the Finish transition type. |
| Variant | FeatStd::String | Variant which will be used for this Request. |
| Identifier | Candera::Transitions::Identifier | The Node or Scene that will be subject to the transition. |
Action Behavior which activates a culture based on its 'locale' value.
Common Properties
